isb cornbinder
This little vice opens to 1.75 inches. It is made of about 10 pieces and all held together with machine screws. It was a High School shop project from back in the day when our schools offered the shop class option.
Now don't laugh too hard but I found the need for somehow making it easier for my little 14 hp Power king tractor to pull big logs out of the woods and up to my wood pile. I was using a short piece of chain and the 3 point hitch but it was really hard on the little hitch. I had this old axle with wheels and tires out back that I was going to use for something else and I married it to an old engine lift that had a bent bottom frame and wouldn't roll around on it's own anymore.
I bolted the lift to the axle and turned the lift arm around pointing backwards then welded me a toung on to the two newly weds and bingo!! a back yard log skidder was born.
Floor cut and framed and I now have a working elevator!you can see more detail on my build thread
-Made something but am a bit embarrassed to share a photo. I have to construct an enclosure from XPS foam board that's 12 feet long and has multiple angles along the length. Being a retired toolmaker, I wanted to pin the sections together for location, several of these pins are from 12"-14" long and using a hand drill just isn't a good method. I needed a horizontal boring mill or a gun drilling machine for depth of the hole. I had an old mini mill I seldom use so I unbolted the column and mounted it on a rolling carriage I had made years ago for cutting long, heavy lumber with the horizontal bandsaw. I made an ersatz table to mount everything so the center of the drill axis is at center of the 2" thick XPS foam board. With my Rube Goldberg Hor-Bore I can now drill a hole 14" into the foam board without breaking out the top/bottom, aluminum rod serves as a dowel pin and the fit is good. I can reliably assemble/disassemble the enclosure several times for fitment/rework while maintaining panel alignment.This has been dormant for 4 years.
Surely someone has made something worth sharing during that time...
