mdbeck1
Forgot about this one. Did this a while back because I needed to clean a bunch of rusty hardware (from a crowntop craftsman table saw), but didn't want to spend the money on a tumbler. All stuff I had, nothing permanently affixed. Worked really well.
I took a aluminum coffee can (with screw-on lid), cut a few pieces of scrap aluminum (from a second can), bent them into a few _||_ shaped "fins," and epoxied them to the inside wall of the can, at an angle. To attach this to the drill, I drilled a hole in the bottom of the can, and ran a bolt through it, tightening a nut onto the other side and chucked the threaded end of the bolt into the drill. The drill was clamped into a drill press vise, and the can rested on 4 ball-casters. I kept the can from jumping off of the casters while spinning with a piece of broken belt from the aforementioned table saw (screwed to the wood), and used electrical tape to keep the casters from eating through the can as it spun. I then let the drill run for a few hours with $3 HF tumbling medium ('green pyramids'), and voilà: shiny rust-free nuts and bolts.
I built one based on plans found at this URL: http://www.ar15.com/forums/t_6_42/344986_How_i_built_my_own_rotary_tumbler.html&page=1
The tumbler chamber is 6" PVC. I had most of the stuff laying around.
The primary use is for tumbling brass for reloading. I usually use ground corn cob or ground walnut shells. ...although ground walnut shells sure shine up chrome sockets.
