Bluehealer
How do you bypass a safety switch on a garage door opener, I dont care about it may be illegal or that may be unsafe, I bought the damn thing I want the sensors disabled PERIOD!!!!!
I mounted the sensor and reflector facing each other above the spring with enough wire to mount them in the normal place if someone in the future wanted them. In the old house they were a pain but they are not a big deal here.
The way the openers are designed, your have to have the sensors in place. You do not need to have them 12 inches of the ground.
My garage guy mounted them on the mounting bracket for the motor. He just aimed the light at the reflector.
Me too.I did the same as Old Man Roger. I mounted them facing each other above the opener motor.
I used to keep pipe in the corner and it constantly hit the reflector.Mine work fine also.
Not sure why anyone with the least bit of mechanical aptitude can’t make them work as designed.
The issue is sunlight. If your door is oriented is such a position that the sensor is hit by early morning or late afternoon sun, the door won't close. I've had to take a remote and stand with it while blocking the sun for the door to close. Doesn't happen that often, but it's annoying. I've heard of people fabbing some type of sun shield for the sensor.
Just finished putting one in. The above is what the manual says if sunlight is a problem. My sensors lines up perfectly the first time with no adjustments needed. I have grandkids. Could not live with myself if something happened. You know kids you can't watch them constantly.Pretty sure the installation instructions direct you to switch sides with the sensors if sunlight is an issue.
When I go out to walk the dog and put out the trash can I can't push the button on the wall, crab the trash, with the dog on his leash, and simultaneously dive under the descending door, while jumping over the blasted electronic beam. Something has to give. That's the beam.I really don't understand the problem with the sensors.
You can simply swap the sensors and the wiring at the opener to solve that issue. Only the receiver is sensitive to sunlight.The issue is sunlight. If your door is oriented is such a position that the sensor is hit by early morning or late afternoon sun, the door won't close.
I stand outside and reach into the garage. The jamb is, what, six or seven inches thick? I mounted a switch on the wall about four inches from the track.
My arms are probably somewhere around thirty inches, so the reach isn’t difficult at all.
Like I said, anyone with the least bit of mechanical aptitude can figure out a better solution than disconnecting or bypassing the safety beams.
Different set of safeties and different openers on commercial doors. And, when I do facility inspections on commercial facilities, I do red tag the doors if they have residential type springs and openers, and no safeties. OSHA inspectors may also.
The safeties are there for more than just kids. A small, but very real probability is that the springs will break and the door will slam down. Doesn't matter who or what is under it, it's a hazard then.
It's just like seat belts and guards on saws, crotchety old men can find all kind of silly reasons they don't want them, but more rational people use them as intended.
Okay, public service announcement over, you all can go back to chasing the kids off your lawns.
I did the same as Old Man Roger. I mounted them facing each other above the opener motor. We don't have children and the only time the garage doors are open I'm eather parking a car or working in the garage. I hate big brother telling me how to live my life.
