Started early to beat the heat...
I mowed some sections today with the new mower, Scooter. The first impressions are positive and I logged 3hrs on the meter.
First, the power of this machine is noticeable, and it is coupled with a responsive transmission. Going from forward to reverse will yank you around. It was strong up hills and very controlled on declines
Second, the steering is absolutely beautiful. It is effortless to turn, it tracks straight and doesn't yank the wheel out of your hand.
It is a noticeable improvement over the JD L130. The turning radius is impressive. I easily worked around tree trunks and tidied edges. The steering wheel is comfortable, it feels larger than the JD. I'll need to measure.
Third the differential lock is a back saver. At one point I buried the front end in some soft sand as I was reversing away from a tree and I couldn't get out. I stepped on the diff lock, gave it gas and out it came.
Fourth the seat and arms rests are comfortable. The arm rests are high enough that I wasn't slouching to use them. My back didn't hurt after I finished like on the L130.
I did have one oopsie. I ran over a gangly tree branch that I thought it would destroy, but the branch twisted, wedged up and leveraged the deck belt from PTO clutch pulley
I drove the mower up to the carport. and read the manual. I un-tensioned the pulley and got the belt back on and away I went. In the end the 3gal of fuel capacity was enough to mow 4 or the 5 sections that are taken care of with the lawn mower. And I'm going to consider purchasing some sand blades. These stock blades did ok but gosh almighty the dust they brought up was heavy. Now, with the JD the job was still dusty so I'm not certain how much the dust can be reduced. I have sand and hot dry conditions, it'll be dusty.
After the work was done I hosed off the mower and let it airdry.
While the mower dried I cut up the crate Scooter came in and loaded it into the utv to take it the current burn pit I have dug. Reason I'm not burning it at the house fire pit is there are some staples and metal ties in there. I don't want them falling into the dirt and being a flat tire hazard for the truck parking and moving about up here.
Unloading at the current fire pit. I'm really liking digging out a pit to burn. I used this method on the big oak that was cleaned up last year. Once everything is burned, it's easy to water it down and cover up. It doesn't leave a mess that takes time to degrade. Upside is the surface vegetation grows quickly to fill in the void and the organic material is beneficial to the soil too. A big plus, reduces the fire hazard when the pit it going and embers are harder to get blown out.
A few days ago I finished putting up the remaining foam board that was peeled off the wall. There wasn't enough to finish the last 2 bays but I'm not going to worry about it. I only put up the foam board because I didn't want to be wasteful. With the carport bay cleaned up and the foam board out of the way, I can now start building the workbenches. Once the plan is set, I'll move the motorcycles out while the benches go up. Then the side workbench area will be torn out. I'll put the motorcycles back in that section and up on their stands. That will eliminate 2 larger floor tools and gain some floor space to have them upright.
Well, that's all for now. Have a good one.
