My guess is they are handles to hold hot tools in the blacksmith trade.Need help identifying these three tools
Thanks
Dana
Or to work close to hot materialsMy guess is they are handles to hold hot tools in the blacksmith trade.
The tool on the bottom is used to pound caulking in between the boards on a wood hulled boat.Need help identifying these three tools
Thanks
Dana
Well, you will find one on eBay and it happens to be correct but in general eBay tool listings are full of sellers just repeating the incorrect listings of previous sellers.MR.X
I am still looking for a picture of auto body dolly tool. Thanks for the info.
Dana
I was thinking along those lines but don't see anything exactly like it yet.And the one in the middle is an auto body dolly ...maybe Porter Ferguson by the red color...
You're wrong about the bottom tool. Do some research like the OP did and you will see I correctly identified it.I'm disagreeing withe the caulking tools idea. Why the long handles? The caulking irons I've seen in use were simply hand-held.
I'm going with blacksmith tools. The top one a punch for making holes in hot metal, the lower one a chisel for cutting hot metal.
The chisel of the lower tool appears to have been a brick-cutting chisel in a previous life.
Excellent research RTM; with your info was able to locate some decent images of horsing/hawsing irons at:
I was thinking the same way, until RTM's post & re-looking at tape measure in the O.P.I'm disagreeing withe the caulking tools idea. Why the long handles? The caulking irons I've seen in use were simply hand-held.
Hi. Yeah, it’s a less common one.I was thinking along those lines but don't see anything exactly like it yet.
Thank-You for the original post.Thanks again for everyone's help.
I always assumed two-part tools separated the heat. Hmmm. Learn something new every day.Perspectives:
The top tool handle could be holding a cold chisel or a punch etc.
The bottom tool handle could be holding a caulking tool or a brick chisel etc.
The fact they were made indicates frequent rather than one-time use to me.
A closer examination may be required, but both handles appear to be blacksmith made rather than say, by Crescent or Utica; typical U.S. ingenuity by someone tired of burning his hand or setting his glove on fire. Reasonable certain these tools were made and used by a blacksmith, at least to the status of ‘definitely maybe’.
I missed the center tool first time, but would not rule out leather/saddlemaker use; pommel/stirrups etc.
