Cast-in-place Anchors
ALinCarolina
NC Piedmont
I'm in final stages of shop plans. I want to install concrete anchors when we pour the slab but only want female connectors so I don't have studs sticking up. Since I don't know exactly where my benches will be and want to anchor my metal bender only when I need to use it, I will place quite a few anchors around. Anybody used any of these:
http://www.ucanfast.com/products/de...c=4&subcategory=Precast+Inserts&productid=169
Or the B3Z anchors on this page:
http://www.williamsform.com/Concret...ncrete_Anchors/cast-in-place_con_anchors.html
Before I found these I was considering welding a nut onto the end of a piece of square tubing and setting it flush with the surface of the slab or slightly lower. I could keep a flat head screw or something in them to keep debris out when not in use. I plan on putting in a few of the chain anchor cups also. Any other ideas?
LB-1911
Northwestern Il.
Cut from a previous thread -
I used 7/8" coupling nuts with a 7/8" bolt, washers, and a pipe spacer, in the bottom side set in the concrete before finishing. The top of the unit was covered in tape to keep concrete out. The 7/8" diameter hole does not impede casters etc. I just run a 7/8" bolt into them when I want to fasten anything down. When not in use they are plugged with a slotted section of 7/8" all-thread or part of a bolt greased up with anti-seize. 7/8" coupling nuts are available at some hardware stores and steel supply houses.
https://www.google.com/search?hl=en...0l13608l12l12l0l2l2l0l127l615l9j1l10l0.efis.1.
I thought about fabricating some of the things that others have suggested, but ended up buying 4 of these,
http://www.autobodytoolmart.com/champ-floor-anchor-pot-1600-p-11538.aspx
along with the "new floor plates."
http://www.autobodytoolmart.com/champ-instant-floor-plate-new-floors-p-10320.aspx
I welded some rebar "legs" to the plates, so I could drive them in to grade, and they ended up flush with the concrete.
vision8
Southern Ontario Canada
I looked at those but to put a layout for frame straightening ( Champion Layout of 20+ ) would have been $$$$. I made 6" x 6" x 6" out of HSS tubing with a 1" Dia. round x 12" long thru at 3" so I could feed a sling or chain as a anchoring now have 6" x 6" caps as covers over them. Also put two 4" x 4" HSS tubes x 36" long with slots for bolts to use as hold-downs for my tire machine flush with the floor. Pods have 1/8" plate bottoms.
Put them inline with the doors to pull a vehicle into the shop and outside 20 feet to pull a vehicle out of each shop bay. Lots of planning !
jack stand
Lakes Region Maine
In one of my shops, I put a 5' pc of rail (railroad) upside down to weld to for some projects. In my current shop I put in several 2" reciever tubes (like a trailer hitch) for 2 legged sawhorses and/or a "Hossfeld" bender. The few times I used the rail, it was invaluable. I had bent the frame on a dump trailer, welded a chain from the hitch to the floor (rail) and a pair of hyd. jacks under the bend, with a tractor holding down the back. Worked slicker than snot!
A
ALinCarolina
NC Piedmont
Thanks for the ideas. I was thinking of using 3/4" bolts and coupling nuts. Do you all think I would need to go with the 7/8"? That's pretty big but might as well I guess.
I probably could just weld a couple wings off the nuts to keep them from rotating in the concrete.
cbacres
SW Florida
Hilti has anchors you can set in a drilled hole. They are used in commercial and industrial a lot and would be fine for anchoring benders and such.
I believe tamp-in is a name of these anchors.
Can't vouch for pull out for frame work though.
matt_i
There is no way nuts are going to be able to withstand the heavy mud pour and stay on hole pattern...unless you weld them to a grid of metal (rebar, flat bar, tube, etc) that fits the bender base exactly, before concrete pouring ever starts.
For something lightweight like that, I would personally just use drop-in anchors after the fact.
pcmeiners
As mention ,keeping the alignment during a pour is tough, any pre-placed anchors or rods need to be attached to something which will not move; nothing like having a rods 1/2" off spec, and they will be off if free floating anchors/rods are not re checked during the final crete finishing. I have set hundreds of anchors for multi story steel buildings footings and machines, very exacting, time consuming, no room for mistakes. Personally I would drill and anchor where needed, so much easier, and with the proper hardware, no loss of strength.
A
ALinCarolina
NC Piedmont
Good point about the anchors moving. Definitely would be a good idea to weld them to a square of rebar first. That will be my new plan for now. The slab will have hydronic tubing so even though I will try to measure, photograph, and diagram the layout it will be scary to drill holes afterward.
The other thought is that if they still are a little off to match the base plate I could make an adapter plate of some sort.
Nor'Easter
Maine
Go with the largest nut size you feel comfortable with. It will make cleaning them easier and you'll be less likely to get them misaligned and stripped.
Pwrgeek
Texas USA
On the tubing one trick is to either let the slab get hot and run cold water through it and you can see the tubing with a cheap thermal camera or to let it get cold (freezing) and then put water on it to make a layer of ice before running hot water through tubing. Those are the ways I've seen people find the tubing after the slab is poured. Now that I live in the tropics (Houston) it's not really a thing I have to worry about anymore so new ways may have come up in the last few years.
