Compression - Show Off Your Compressor
Mr. Jean
Sparks, Nevada
Just the usual ugly looking stuff, AC, water heater, house vac. system. Put the trellis on hooks, so they swing out or can be taken down real easy. Figured it would look/be cleaner and give me more places to hang things, if needed.:thumbup:
Don't usually put up the ugly ones.:bounce: Here's a peek at just before the lattice work. It's laying on the floor.
Tantara
I've got just a smaller Craftsman 25 gallon, 2 stage. 1.6 hp.175 psi unit. One of those quiet types you were talking about. 40% quieter, is what is says.:thumbup: Works fine for the stuff I do, so far. Like having it on wheels, to put/move where ever needed.
Mr. Jean,
I am interested in that poster from 1977 with the dragsters by the door. I have the same poster is yours from Brainerd International Speedway or somewhere else?
Brad
Mr. Jean
Sparks, Nevada
Hello Brad. Mine are from my old racing days, down in So. Cal.
Here's a peek at a couple of them that I have on my garage walls.:thumbup:
mike59
Hy !
excuse me for my language but I'm French ans we 're very bad in English !!!
I wanted to know one thing
I'me watching all of yours compressor installation and I've one question
I see many time that the air tube fixed in the wall is always fixed with à piece of wood...why ???
is fore reduicing noise with vibration in the wall or it's because in USA there's no fixation for the tube ?
thank's for your answer...
GzrGlide
Wpg, Manitoba, Canada
Its probably because of different construction techniques between North America and EU.
The wood backing plates are used because the wood provides for a more solid attachment point for the tubing than the drywall thats normally on the walls.
mike59
compressor are not in the floor...I've seen several time that it is in a palette...
is it for vibration too ?
GzrGlide
Maybe for convenience, too lazy to take it off, keep it off the floor if there's moisture issues, keep it higher to be able to drain the tank easier?
MScott
Eastern Ontario
Heres my air compressor.
Its a 1949 Smith Motor Compressor.
It uses a 1931 Ford engine. Two cylinders run, two compress air.
Its good for about 50 CFM.
I am *almost* finished restoring it.
This reminded me of a compressor my brother used to have. It was a 351 Cleveland Ford V8 that ran on one bank of 4 cylinders and used the other 4 as a compressor.
I have no idea what the output was, but it was massive, enough to power several Jack-hammers.
mad57
Very interesting!!!!! any pics on how they did it?
Tantara
Thanks for the close up. I have the identical poster to your first one with the exception it is printed for the racetrack here in Minnesota, Brainerd International Raceway. Small world.
Brad
Mr. Jean
Sparks, Nevada
You're very welcome, glad to share. :thumbup: I've got a bunch of old racing memorabilia, but don't want to hijack the thread. Perhaps another thread, another time.
930dreamer
Amarillo,TX and Stinnett,TX
Atlas Copco receiver tank brand new for $85
Kellogg American 7.5 monster for .99 cents
Jaeger 6 cylinder gas project
IR with two 3hp motors
Rotary Phase Converter 10hp start
I have 3 other 15hp IR and 2 10hp Gardner Denvers
fireball 440
30 gallon 5.5 hp Craftsman. Also have a 11 gallon 1.1 hp Pro Force in the basement. Both are noisy as all hell.
Joe69
Muncie, Indiana
This isn't mine, it's my Dad's. He had been asking me for advice on buying a compressor, and I found this one at a garage sale for $30. I checked it out, cleaned it, painted it, and had a custom decal made for it, and gave it to him for his birthday. Our last name is Fowler.
It's a 220v Craftsman that runs super quiet and holds air great. I couldn't find a deal like that for myself if I had to. Dad was happy, that's what really matters.
Joe
rickey1013
Hayward, CA
I am still in the process of setting up my garage just able to purchase my home. 2 months old, sewing company going out of business picked up for $500.
the spyder
Oregon
You can never just have one :).
I current have 3.
1) Husky 30gal 2hp Cast Iron, picked it up for $50 from a painter friend. Nice little unit.
Needed a oil change and some cleanup.
2) Devbliss Pro Air 4000. Oil FREE 60gal 5hp peak. This was free from a friends father shop.
Needed a pressure switch, the armature cleaned up, and some new wiring. Currently serving duty at my fathers shop. Provides dry, oil free air for his wood working and car hobby.
3) Champion R15 5hp 80gal
Purchased this from one of my favorite junk places. I never thought I would find a air compressor there. It was sitting in the yard, looking awful neglected. Thankfully they covered it before it rained. When I asked the yard manager if I could buy just the pump and compressor, he said hell no. Well, I said fine, how much for it. I believe he was joking me when he said take the whole thing for $35. HA! I said sure. Some of the other staff weren't to happy to see me driving away with this thing loaded in the bed... He even tossed 300ft of rubber air hose :).
Its a Champion R15 pump with a GE 5hp 220v motor. The tank is a 1940's and first on my list of things to replace. I will find a better picture and a before picture when I have a chance. Should be good for 130psi at 18.3CFM. Cant wait. We tore apart the entire thing, cleaned it up, painted it, checked out the pump, new oil, new air filter, rebuilt the pressure switch, and reassembled the entire thing.
Total in to the project is around $240. Not bad for a compressor selling still for $1500+.
:beer:
*Edit found the picture! Its quite the change...
*Edit 2, better photos. And we fired it up tonight! Runs like a champ!
tonydanzah
the champagne of people
basic 60 gallon CH with the 2 cylinder v pump, I might put a 3 cyclinder eaton pump eventually. I did notice i think im the only one here using semi air system line to get air to my hose reel. Its cheaper than pvc and way cheaper than copper. It also has no corners or elbows since it plastic hose rated at 275psi. Got a 20 gallon used tank in the rafter to up my total supply, but i never use it. Also i notice all the coiled line acts like a water seperator as you can see a little water at the bottom of the coils after a few weeks. if anyone wants pics, message me i do not have a way to host images
Joe69
Muncie, Indiana
I plan on using nylon air brake line as well, when I move into my new shop. It's easy to work with, and tough as nails. Just remember, the size is OD, not ID, so I will probably use 5/8 line in case I ever want to use my 3/4 impact at home.
Joe
tonydanzah
i think without looking mine is 3/4" O/D, i got it so long ago. i believe the I/D is 1/2", at least that was the spec i was looking for when i talked to the guy at the hose shop.
sstruckguy
Paducah, KY
After many years of hands on experiance with my father-in-law, (an owner/operator of a compressor business) I purchased this unit:
It has served me well for 8+ years :thumbup:
Since that pic, I have hard lined my air, with schedule 80 pvc and a 50' hose reel.
PCO6
Newmarket, Ontario
Nice set up. Are you using the 2" yellow pipe as a knock out drum?
Thanks AK. No, it's a desiccant dryer. It seems to be working well for my sand blast cabinet. I'm setting up a painting / powder coating booth and it should be good for that too.
neverenoughtools
Near Toronto !
nice setup ! What are the specs. of the unit? I am researching a new system for installation spring next year. Currently I run a portable unit which is underpowered for my needs, especially when using a 1/2" drive impact gun.
timberseal
Just acquired this compressor, but I don't think its very practical for the shop, ha, ha.
Its an Atlas-Copco screw compressor, about 100 CFM and produces about 105 psi at peak. Powered by a two cylinder Deutz Diesel air cooled engine of 22.4Kw/30hp. My house is a log home that the original owners sprayed it with a porch and deck "stain", that thick, powdery stuff like my dad used on his deck for years. With a good coat it affords some protection to the logs, but it weathers off and looks pretty bad after a while. The only way to remove it, so a proper sealer and protectant can be put on the logs, and reveal their natural beauty is to use a commercial pressure pot (sandblaster) with ground up corn cob media. It raises the grain somewhat but apparently is the media of choice for professional log home refinishers. I had someone who claimed to have been in the business for many years come "down" (from the other side of Atlanta) to give me an estimate, that was two months ago that he was here and I'm still waiting to hear from him. Others told me it would cost $15K or so to do all the blasting, sealing and re-chinking, so when I saw this compressor on Craig'slist for a reasonable price, I bought it. Now all I need to do is find a large pressure pot, hoses, protective gear and such and spend alot of afternoons after work............
Charles
Our entire business revolves around restoring and preserving log home and other structures. Pricing is probably right in there as our average is around the same. A better media to use though is recycled glass. Cob tends to tear and raise the grain too bad. A 40/60 recycled glass leaves the surface nice and smooth and cleanup is alot easier :)
Lippyp
Shropshire, UK
Interesting, over here in the UK virtually all compressors are horizontal tank models, I don't think I've ever seen one with a vertical tank, either home or industrial models. The vertical tank looks like a much better use of space to me as it'd fit nicely in a corner whereas horizontal ones have a much bigger footprint.
PCO6
Newmarket, Ontario
Thanks neverenoughtools (good handle - I know what you mean!). It's a pretty basic unit that I purchased at Home Depot. I live not far from you up in Newmarket btw. It's a single cylinder, 240 V with 6.5 hp. It delivers 11.7 scfm @ 40 psi & 10.2 psi @ 90 psi. The max. psi is 135. I work alone as a hobbyist in my 2 garage and it keeps up with me just fine (... but I'm a bit slow). Attached is a better picture of the desiccant dryer that akdiesel asked about (sorry AK - I should have attached it my reply to you). The 1/2" pipe on the left side will be extended to the ceiling to continue the distribution system.
Bfoughty
80 gallon 2 stage. Not in it's permanent home yet. I also have a 10 gallon oil less black max at my buddies house and a 20 gallon porter cable at another buddies house. Have an old green devilbiss at dads house.
JD6619A
Mine, got her in summer of 2008, It's an eagle TT55G honda 5.5HP engine 12.5CFM @ 100psi.
I don't have a garage or a shop yet but when I do i'll likely get an IR or Eagle compressor
HarleyGraffix
Hello All.
I've been lurking here for awhile and read enough good things about the Quincy Compressors I broke down and ordered this little Jem.
60Gal
5hp
15.2cfm @ 175psi
15.7cfm @ 90psi
After 3 weeks it was finally built and arrived here yesterday.
I was wondering a few things though.
This having the 1/2 inch outlet,
Should I use a 1/2 or 3/8 regulator?
I was hoping to run the 220 to the Garage tomorrow and install a regulator, Filter and hose off the Compressor until the finances allow me to hard pipe the garage.
What would be the greatest loss in downsizing the regulator from 1/2 th 3/8? Also the hose is a 3/8 50 footer.
HarleyGraffix
Quick add.
I'll mainly be using this for cutoff tools, Buffer, 3/8 & 1/4 in guns, Blow tools and basic around the home garage stuff.
Nothing planned as of now in the paint or blasting, Well baybe a portable blaster.
