split150
Here's mine. I just finished it last night and fired it up. Complete rebuild. Had it for 40 years.
Jim
Jim,
Those gauges are really awesome. I'm also curious where you got them from.
Jim
Jim
"New" garage came complete with the 4.5HP Kobalt (anyone know who actually made this unit?)
Mine. It needs a check valve, its leaking ever so slightly. Where do I find one?
Had this one for a little over a year now, -
View media item 35273
Runs great! Does everything I needed it to do. Once it gets past the filters lol. -
View media item 35261
More pics here, -
http://www.garagejournal.com/forum/album.php?albumid=3262
If it is the in tank type 3/4" this may be a good deal for you;
http://www.ebay.com/itm/19061204856...AX:IT&_trksid=p3984.m1423.l2649#ht_1649wt_880
I have no connection with this seller.
Nice! 321 or 331?
Pull the check valve out, disassemble and clean.
Where did you get your regulators/filters? I want these.
See it this will help page 43 & 44
https://www.miltonindustries.com/uploads/Milton_Catalog_August_2011.pdf
Are you sure the gauge is correct??
The motor and unloader shouldn't have anything in common causing the compressor to bog down I wouldn't think???
wow i lost track of this thread....
Doesn't seem like it would get good air circulation with the flywheel right up against the wall...
But the bigger question is, how would you change the oil? Seems like a major pain to have to pull that thing out.
As pressure builds, it takes more power to turn. As it bogs down, the speed slows to the point that the centrifugal unloader is spinning too slow to keep the valve closed. Thus, it opens.
I ran it a few times to 145 psi. Next time it bled off, it had the problem. I kept bleeding off the tank to lower pressure to see if it would pump again. I could not get it to pump until I completely drained the tank and it ran until about 15-20 psi. Open the drain valve and it will run.
This finally came in today!!!! It is beautiful. I would love to move it into the living room as display only.
[/URL][/IMG]![]()
[/URL][/IMG]![]()
It sure is a monster compared to the ole POS it replaced!
[/URL][/IMG]![]()
I have finally joined the Q club![]()
