75gmck25
I have 2-2-2-4 aluminum SER cable running from my main electrical panel over to the exterior wall closest to the garage. At the wall I need to transition to 2-2-2-4 MHF so that I can make the buried wire run over to my detached garage and connect to a sub-panel. I will be using a 60 amp breaker at the main panel, so the wire size is well within the specs for amps and distance.
What do I buy to make the interconnection between SER and MHF inside the junction box? Do I buy an empty plastic or metal junction box and then use approved wire splices (barrel splice?) inside the box? Anyone have a suggested brand/type of wire splice that will be code compliant for #2 aluminum wire?
Thanks,
Bruce
Thanks,
Bruce
