BMEP
I’ve been trying to decide what to on my garage floor. I used Rustoleum Professional (solvent based) epoxy w/clear coat on my last floor and it was fine. However, it was easy to scratch if anything was dragged on it. I’ve ruled out Race Deck or similar plastic tile so I’m down to epoxy (likely I’d use Wolverine) or porcelain tile. This will be a working garage.
The area I have is approx 40’ x 23’. There are numerous control joints (formed with an edger before the concrete set) in the floor and an expansion joint (fiber) aound the entire outside.
I’m figuring on a matte finish, through body, PEI5 porcelain tile, probably 12” x 12”. I’m looking for any input on laying the tile, especially things like necessity of expansion joints, floor prep, etc. I plan to use epoxy grout for oil resistance. Also, as much as I’d like to use tile with a rectified edge and small grout joints, the tile I’ve been able to find is just too expensive.
Some of my questions are:
Do I need some sort of expansion joint in this floor? Do I need to use Ditra?
Can I just lay this right on the concrete (properly cleaned, assuming no moisture problem)? I was figuring a modified thinset adhesive
Do I need to diamond grind the floor or will I get good adhesion without grinding?
Does anybody know a good source for tile? I'm in the Sacramento, CA area and haven't yet looked locally but have found a couple places online.
Any help is appreciated!
Rob
Rob
