Craftsman 299-piece Ultimate Easy Read Socket Set
ADSR
I contacted them about a custom foam for my box, but never heard anything back, typical small business. Has anyone used the two smaller foams which hold the 176-piece set. I don't believe it lists the drawer depth needed to support those two-pieces and, well, contacting them to get specs probably ain't gonna work.
There are other options as well. You could always buy fastcap foam which is layered specifically for tool control and lay your own out. Time consuming, but you'll get what you want in the end. Fastcap foam is dirt cheap.
http://www.fastcap.com/estore/pc/Kaizen-Foam-p13435.htm
Another thing to think about is, will you be moving these sockets to your mobile cart? I don't want to move all 300 sockets each time. I use a lot more 3/8's than 1/2. Foam is cool, but i might make my custom setup out of cutting board plastic so i can drop it in my cart. There's just too many options for what might work best.
MDSPHOTO
Oz
I do not have a mobile cart I work on my bikes in my garage right next to my large tool box and have a small Northern socket set that stays in the house for jobs in there.
That foam looks great, but I don't know that I have the patience to carve out 176 openings for my sockets.
kneeman
Send me the art file and the foam and I will cut it on my laser for you.
Mech33
This socket is in the set. No deep 20mm 6-pt though.
Ah good call. I have the parts list and was looking at the missing 20mm but I neglected to notice that it wasn't a deep socket in the link.
Maybe Craftsman doesn't make a deep 20mm 1/2" drive socket?
Nor any 1/4" drive 12-pt metric sockets at all (deep or std)?? Seems hard to believe, but maybe so.
kneeman
I think all sockets should be 6pt.
I can see why you need 12pt wrenches but not sockets.
tldavis
North Carolina
Before:
After:
Mech33
Agreed. Hence my annoyance that the 299-pc set had more large metric 12-pt sockets than 6-pt sockets.
I've run into 12-point bolt heads on rare occasions, but those have just have engine head bolts IIRC.
KinzeMech
It puzzles me why people say that. A 12 point socket can do everything, a 6 point socket can only do most things.
I routinely use 12 point sockets on 4 point (square) and 12 point bolt heads. Both situations that would result in a delay if I were only equipped with 6 point sockets.
n8n
Curtis Bay, MD
Having done a lot of work on 50+ year old vehicles, I would not use a 12 point socket on most hex bolt heads or nuts. Corrosion is an ugly thing...
This becomes less important in 1/2" drive sizes but for typical body fasteners 6 point is the way to go. I think I finally broke down and bought a set of 12 point sockets when I bought a set of ARP rod bolts for a VW Corrado engine and realized I couldn't torque the nuts :) (common for these engines to eat rod bearings but be otherwise 100% fine; I know I should have had the rods resized when I replaced the bolts but I didn't and there were no apparent negative consequences. My understanding is the stock bolts were TTY so reusing them was not an option.)
JoeMA
PA
Probably because they rarely encounter anything but 6 point bolts.
I bought this set a while ago as a backup. I use my preferred sockets primarily and have this set to cover the infrequently needed sockets, so I am glad to have the 12 points also.
OutsideMachinist
Norfolk, VA
I dont really understand a 6 pt vs 12 point argument. You need both. I will use a 6 point whenever possible. Sometimes there is a clearance issue and a 6pt wont work. Sometimes there are 12 pt bolts. Same reason I would never buy 6 pt wrenches despite if people like them. A 6 pt wrench is useless in tight spaces. 12 pt sockets seem to do just fine once you get in larger sizes like over 1'' as well.
thachman
How long does it take to get replacement sockets for missing and/or damaged ones from the set? Called them over a week ago to get the ones that were missing or had no etching, etc. Nothing has shown up yet.
af9210
Atlanta, GA
Took about a week to 10 days. I'm sure they are sending out replacements for those that got in on the deal
thachman
Thanks. I'll give it til midweek before giving them another call.
DJ_Schmo
Kettering, OH
My set came today. I have 3 missing. I called the customer service line and was told by 3 different reps I had to box it and return it to the local store for any replacements. Is there something I'm missing here?? I told them if I have to box up 299 sockets to drive to a store where they MIGHT take care of me then and there and with possible Chinese piece in an otherwise all USA set they will be giving me a refund.
af9210
Atlanta, GA
Call the apex # and give the cat number for the missing and they will ship them out
DJ_Schmo
Kettering, OH
Oops...I apparently didn't listen well to the recording. The 800-832-7494 gives out another number for tools NOT included in the ones they mentioned. I am an idiot it seems lol. They are closed now so I will call in the morning.
el_chupo_
DFW, TX
I got my missing sockets last night, so I was at 10 or 11 days to get them in my hands, but no questions or problems in getting them.
Also just ordered the foam fit tray for this, I got tired of trying to figure out a layout that was cost effective. The foam fit works, they all fit, and they seem well organized.
Thanks for the pics!
Mech33
The foam is tempting, but I'd really like a layout for these that puts the sockets flat so I can read the "easy read laser etching" on the sides. The vertical configuration hides all markings...
Plus, standing up the deep 1/2" sockets in the foam necessitates a 4" deep drawer.
el_chupo_
DFW, TX
Yes, but...
I have a 4" drawer, so that works for me. Knowing that one side is Metric, and one is SAE, I can get pretty close to grabbing what I need, or at least getting to the right spot. But seeing them would make things easier.
Also, laying these down would require more area, which would probably mean one drawer for 1/2, one for 3/8, and a small one for 1/4.
They also have a 3 piece option for the set, with many laying down, but it would come out to $120.
I might have gotten these if I were putting these in a top box.
Main page for the organizers: http://foamfittools.com/Csocketorganizers.php#sockets
3 piece set:
http://foamfittools.com/details00181.php
http://foamfittools.com/details00182.php
http://foamfittools.com/details00183.php
Mech33
Yes, but...
3 piece set:
Good call! I didn't see those. Those are a good fit for what I want. My setup uses chests of drawers that are generally 26" W x 18.25" D x 3.2" H (the Saber drawer sets), so the 22.25" x 16.25" pieces will fit with a few inches of clearance for ratchets and things.
el_chupo_
DFW, TX
tldavis posted pics of his in post 328, I believe his is a custom cut to fit the HF/US General 44" box top drawer.
el_chupo_
DFW, TX
Im showing $25 in surprise points for anything over $200 right now as well. Couple that with the ebates cash back of 6% (post 182 or ebates.com), and its a heck of a deal! Almost covers the FoamFit tray above with the savings.
kneeman
I could it find any codes that worked.
I tried all the known ones and even the ones in my coupons. Not even the 5.00 off 20.00 worked, not the 10.00 off 100.00, nor the 20.00 in points off 100.00
af9210
Atlanta, GA
It Is a hot buy item. Maybe sears.com all messed up again it seems
Sent from my Nexus 5 using Tapatalk
thachman
This set shows up as 279.96 now
I have not tried coupons yet.
Damn, just missed the 14-day cutoff on ther price protection policy. Ordered it at $299 on the 6th.
$279 is a great price for this set, especially if you've got surprise points you can use.
MDSPHOTO
Oz
Yes you're right, but they just trimmed one of the existing designs to fit his drawer I was asking about a whole new layout.
peaceonesxwai
Damn why did you guys post that awesome foam organizer right when theres a hot buy + SYW surprise points on these sockets!!
