Craftsman Drill Press
Use the same gauge as the cord to the wall, unless you have an excessively long cord and needed it to be heavy gauge to minimize voltage drop...
ndfan6464
All over
The cord is not long at all. In fact it's actually been changed. The motor is wired to a double two prong outlet box and a foot pedal plugs into that turning on the DP. Like a foot pedal you would find in a factory so the machine operator doesnt the have to keep truning the machine off and on. I posted a picture of the pedal a few post back..
But I'll do what you suggested and wire the motor inards the same as the cord. I'll have to dig out my wire gauge measuring tool.
F
FrankLee
seMI, 48317
Exactly. I buy the 9' 14 gauge power tool replacement cord at Home Depot and use pieces of that to replace the internal wiring when needed. Heat shrink tubing is also very handy to repair cracked wiring insulation.
There are several Craftsman motor reconditioning threads on GJ. Use the search function or there are several links in my first two posts.
rrich1
Well just thought I'd share the progress on my journey of my first restoration. Finally got everything off even the bearings. Took all the cast iron parts to the sand blaster so I can work with a clean canvas and had it primered. I have been sanding and polishing parts by hand and painted some of the small parts. I decided to go with a charcoal grey. It's not to light nor to dark. All in all it's been going very smoothly. Will be starting on the case and tables tomorrow.
The part I am most nervous about its Working on the motor. Never ever done one so fingers crossed. I'll post more as I go and thanks again to everyone who's been helping me.
Any reason you didn't tape anything off? I'm thinking dark shadow gray from ford for mine.
Sent from my Pixel XL using Tapatalk
ndfan6464
All over
I've definitely been going over your post during this journey and they have helped a lot and when it didn't cause mine is a different model I asked on here and you all answered.. I got some CRC cleaner today and hosed down the motor with it. It'll sit and dry for a few days before I go any further..
ndfan6464
All over
I didn't tape anything off cause I was short on time. The only blaster in town willing to do it called me last second with and opening so I just took it straight over. He got it all done and back to me in less then 24hrs. So I'll take the effort of wire wheeling everything for quick service..
ndfan6464
All over
Well just thought I'd share some of today's work. All the main parts are done and ready to go back together tomorrow minus the motor. The lettering will get a second coat of red tomorrow. Patched 6 holes in the casing and big chunks that was taken out of the top right corner of the main working table
rrich1
Makes sense. I got mine primed today. Testing a color right now on the underneath to see if I like it.
ndfan6464
All over
Looks good buddy. Can't wait to see it all painted up.
rrich1
Re: The Classic Craftsman 100/150 Drill Press
First coat of paint47ac9edbaae0eca5b7947a8bb3733ad1.jpg8a8c677150d7153887489d53a4b2bc43.jpg1fe92479ce42adcd81c9606a1314fd3f.jpg
ndfan6464
All over
Man that's going to look sharp. Is that automotive paint?
rrich1
Yes. The duplicolor spray paint. I'm going to need at least another can maybe two. I still need to paint the motor housing plus the drill press collar.
I wanted something that wasn't in your face but you could tell it wasn't factory.
ndfan6464
All over
Well everything came to a grinding halt today. Damaged a bearing while removing it from the main housing spindle. Didn't see it till today. So on that note how do you know what size bearing will fit the 103.0305? The bearings that are on it are marked MRC 204 SF googled it and only one option came up and that was from eBay. I've also seen on other threads that they are 6204. When I google that a lot comes at you I.e. 6204 ZZ, 2rs, Sff etc. So any help in this would be great. Thanks guys
rrich1
Try this
http://wiki.vintagemachinery.org/ReplacementBearingListCraftsman.ashx
rrich1
Thanks rrich1. I saw this one before but it didn't list the DP I have. I am working on a 103.0305
OK. I looked after. Is the 103.0303 a different press than yours? If not they are probably the same.
ndfan6464
All over
You know not sure. I googled both the 0303 and 0305 and it comes back with images of the same press and some forums showing the press I have labeled under 103.0303. so I guess they are? One guys post shows the exact press as mine (looks to be anyway) says the bearings are 6204. But brings me back to my question. What 6204 are they? If you google it there are a ton of 6204's..Lol.. these came out of mine. One is good and one got damaged when using the puller
rrich1
I think the model numbers are if they are opened ended like the original. I just ordered motor bearing for mine but got the ZZ model where both ends are closed instead of one exposed.
ndfan6464
All over
That makes sense. I did see the ZZ type. I've never replaced bearings on anything or any tool I've owned so all new to me.. I managed to find a place on eBay who had the exact same ones that are in mine. Sent them photos of mine..
ndfan6464
All over
Also found a guy who makes water slide decals. I put a order in for some. Here's the decal he's reproducing for me. If you need one for yours or if anyone else needs one I'd be happy to send you one. Not sure if yours has this one or not
Cruzan80
Denver, CO
I could use one of the ball bearing decals. The 0303 and 0305 are the same drill press. IIRC, the '42 was 0303, and '43 was 0305 (though it is odd there are more 0305's out there given the restrictions placed on them at the time). There is also the very rare 0304 model, which is the floor model version (same head, larger base).
ttpete
Dearborn, MI
The 6204 2RS has two rubber seals and is a good idea for that application. When that was built, those weren't available yet, and they used metal shields that weren't really sealed.
ndfan6464
All over
Thanks Cruzan80. Makes plenty of sense now then why them press comes up when searching both numbers. I can't imagine how hard it must be to restore a 0304 then if it's a rare model.. As soon as the decals come in I'll hit ya up on here and get your mailing address..
ndfan6464
All over
Ahhh OK. So as long as it's a 6204 it doesn't matter then? The last two or three digits/numbers just represent what type of seal it has? Just like rrich1 said
I guess I'll have to look into that. I found an exact bearing on eBay. Guessing I should have held off.
I would recommend sealed bearings if available. Basically bearings come:
  • Open
  • Shielded one side (not a seal)
  • Shielded both sides
  • Sealed
bearing tech has generally improved and the seal bearings wil live linger in a dirty environment.
ndfan6464
All over
  • Open
  • Sealed
Thanks Outlaw.. I am seeing that now. Did some more reading on bearings and identification. Found a cool website that breaks it down for guys like me...Slow...Lol.. embarrassed to be 40 yrs old and not know anything about bearings. Other then how they work that is. But I've never had to mess with bearings..
Cruzan80
Denver, CO
The rare part is the base. The head unit is the same as the 0303 and 0305, so parts are available. I don't think the table is any different either. The 0304 was never in a catalog, and since consumer production ended due to WWII, they never re-offered the design.
Sent from my VIVO IV using Tapatalk
ndfan6464
All over
So basically Craftsman gave you a longer pipe, a different base and tagged it as a 304.
I could just put a longer pipe on mine and make it a floor press.. just have to make sure it's bolted down or it'll tip.. that would hurt and ****..
Cruzan80
Denver, CO
Pretty much. Most of the floor model versions are like that, even the 100/150's. There is much more behind the pole than on the benchtop base, to counterbalance. Take a look at OWWM, and there are a couple pictures.
ndfan6464
All over
So while on the topic of bearings what grease do you guys all prefer to use when your repacking them?
Sealed bearings don't require packing.
If I'm doing an open bearing it depends. if it has oilers I use the recommended oil. if it doesn't I generally use Mobil1 synthetic axle/bearing grease.
dw1
Ky
O.K a question for you "Pro's" although not a "Craftsman Drill Press" I have a Delta/Milwaukee, I disassembled it about a year ago. I have been sanding on the base pole to get it clean of rust ect, what or how are you all cleaning this thing up. I have used Scotchbrite pads, I have used abrasive pads on my air grinder, I even have scotchbrite pads for the air grinder, the top of the post is clean, the bottom still has a way to go. Anyone have any tricks or tips for cleaning it? I would like to put this back together, I am idle at the present time and finally feel like doing something.
Tks!
dw1
Ky
A few pics of what I am working with might help!!
Warped5
Northwest Indiana
If I were to do mine over, I would look around here for a couple of posts that addressed this very issue.
IMHO, the best one was the member who got some large casters and mounted them so the column could be laid down on them and freely rotate. He then attached an electric drill to one end and used sandpaper on the column while the drill spun it.
Indexmill
Central NC
Exactly. You have to find a way to spin it. Like above, or in a lathe. Any way that will let you spin it by motor and then just hold emery with WD40 against it while it rotates.
Just make a plug with a 1/2" bolt that you can drive into one end that you can attach a drill to. Get a buddy to hold the drill and spin it. You then manhandle the column in both hands with the emery cloth... Lot's of ways.
rrich1
Main pieces are painted, cleared, and on. Still have to paint the table collar and motor and motor pieces. Loving it so far. More pics in my build thread. 8c9f13c7966344ebc0edcf5de5af8b29.jpg2fd7521d88470eac5095e3d9e3125c86.jpg
F
FrankLee
seMI, 48317
Very nice! Great choice on the color!
The head band trim cleaned up nicely. How did you do that?
2/7/2017
Passed the 100,000 views milestone today!
rrich1
I used this. I buffed too much in one spot and took out some of the sheen. [emoji30] do it by hand and you shouldn't have any issues. 233b95b451be162fbdf84904f5ff9345.jpg
bagged89s10
CT
Good work saving the turning design on that trim piece.
I used 0000 steel wool on part of my table saw and it took the engine turning off. Oh well. My drill press is missing that trim piece so I think I'll just make a brushed version.
