Someone is going to inhale profusely for that deal!This is one hell of a deal if anyone lives in OH. Facebook marketplace.
You are right on both counts but you always find really good stuff for cheap so your perspective is skewedMaybe it is just me, but not sure what is so special about it. Has a Varislow, and OEM motor, but light isn't OEM, and has the weird box on the side of the head. Can't tell what the stuff on the table is, but I'd drill bits, nothing amazing. Spent that combined for a benchtop with Varislow ($33) and a floor model '47($45). Benchtop is in the "restore for sale" pile.
Or maybe it just confirms the crazy low pricing I seem to buy these at...
Yes, very trueYeah, I understand it was a good price,but was wondering about all of "amazing steal" comments. Ohio is thick on the ground with all kinds of older stuff.
Here it has gotten to the point where I don't send it to friends if it is priced over about 125 for a floor model...If you don't "need" it now, deals are around.
I bought a Craftsman 150 the other day, a late King-Seeley model, that had an MSA pulley. Of interest, note in the first three pictures the difference between my early 1950s (left) and the early 1960s (right) MSA pulleys. The cast iron body was made far more structurally sound on the later model, also the bearings were changed from Made in USA Norma, to Made in Japan Nachi.
You can also see where the pulley was allowed to ride on the body on the earlier 1950s version.
Who besides Hoorn or Frank would ever have TWO MSAs at the same time to even be able to compare??Can honestly say I had not noticed this before. Great side-by-side, thanks for sharing this!
Indexmill, thank you so much for that, but I am not in Frank's league. Just trying to carry on with what Frank started, he did all the heavy lifting.Who besides Hoorn or Frank would ever have TWO MSAs at the same time to even be able to compare??
URW. I know he did. I sure hope he is okay.Indexmill, thank you so much for that, but I am not in Frank's league. Just trying to carry on with what Frank started, he did all the heavy lifting.
Lunarlites, here is a post from Frank some time ago:FrankLee - I have a Craftsman MSA and want to replace the NORMA bearings. The bearings seem to be stuck on the shaft. Which way do you press off the bearing or is there some procedure to get them off safely?
Your welcome. If this does not work, the nuclear option is an overnight soak in simple green. This will absolutely break down the old crusty grease inside, but it will then have to be replaced with more than just allowing oil to seep back in, you'll have to be creative as Frank was and fabricate some type of device to inject grease. There was no accompanying picture to illustrate what his gadget was as it was most likely lost with the GJ format change, but I presume it was a type of syringe. The MSA's are so valuable now, in most cases they are worth more than the actual drill press itself so it's worth preserving the OEM bearings as much as possible.Thanks Hoorn. The bearings feel like the grease is all dried out after about 70 years. I'll try the 2 day oil soak first and see how they sound after spinning.
Makes sense to me but of all the MSA pulleys I've had, I've never had to pull the bearings. I do not know if there is anything between them. Obviously they'll come off, and a press would be my first choice if they have to come off.More importantly than "three ****** knuckles, lots of swearing and a sore shoulder." is ******* up the shaft trying to get the bearings off.
Hoorn - is there anything between the two bearings? Like a shoulder on the shaft or a snap ring? If not, it seems like it should be very easy to press them off together as you suggested using a steel spacer bushing that clears the shaft and picks up the inner race. Maybe need a press with some snot but that is pretty easy.
WIthout ever having seen how Frank made a device for injecting grease into the bearings in-situ, I can imagine boring a piece of aluminum into which you put the bearings/shaft assembly. Bolt on a cover with a Zerk fitting om one end and a small week hole on the other end thus forcing grease thru the two bearings.
Make sense?
Frank! So glad to see you back! This thread was not the same without you! Hope all is well.OK guys, here are my thoughts and experiences on the MSA bearings...
Firstly, I've never removed or replaced MSA bearings from the shaft. I was recounting others that have. Someone early in the thread had slightly damaged the shaft when pressing the shaft into the bearings. I don't recall who that was. I believe a real shop press with some sort of jig should be used instead of a puller.
Secondly, I did make a jig from plumbing fittings to grease MSA bearings in-situ. The main component is a rubber 1-1/2" to 1-1/4" adapter from a sump pump check valve. The bearings fit perfectly in the large end. The pvc components were fabricated to minimize waste of grease.
Original MSA bearings are shielded. I don't believe a syringe would work well on shielded bearings. This jig will not work on sealed bearings. I also don't believe there is any barrier or washer between the two bearing sets.
Thirdly, I read somewhere that bearings should not be packed "full" of grease. I made a second similar jig for compressed air to remove some of the newly injected grease.
Lastly, injecting new grease should not be a substitute for replacing bearings when needed.
Pictures here:
My MSA bearing greaser worked so well, I made a similar greasing jig for motor, quill, and spindle pulley bearings. Again, this is not a substitute for replacing bad bearings.
Pictures here:
