I'm with the team that saves the most energy, and provides reasonably accurate CRI light
Trying to replicate sunlight exactly is obviously a monstrous challenge. I think it's great that a lot of R&D is going into making LED lights the best they can be.
I'm very interested in E36jon's review of the Cree LS4 here:
http://www.garagejournal.com/forum/showthread.php?t=277492
One of the items I really appreciate is what's being done with low voltage dimming and "daylight" harvesting where the lights dim when sufficient window light dictates it. We have a pile of Wattstopper ceiling sensors (like 30 of them!) here that hold banks of the TL-950s off (for example in our interior hallway which is entirely lit by Solatubes on a bright day) but they are bank specific. Having that tech on each light (and have them communicate) has great energy savings potential.
Hello Denwood, I guess I am confused here. Lamps such as C50 and TL950 are specialty lamps exempt from the efficiency standards and they're used in museums, graphic arts industry and such. These lamps are not specified for just "reasonably good color". Why are you using graphic arts lamps if you only need "good enough" ?
0-10v dimming is not an LED attribute. It's the driver. You can select this option for fluorescent or LED, but you have to select a driver or a fixture with a driver that supports it. Since places like CA now require dimmable lighting in commercial lighting code, dimming ballasts are coming down in price thanks to mass production. The efficiency is comparable with non-dimmable ballasts in latest models.
To cut it short, LED products aren't even in the same league as those lamps nor are they meant to be. LEDs can compete in the game with CFLs and U-bent lamps(which is going out of style anyways...) as these lamps are quite costly. CFL is the primary target since their efficiency is quite low and they have a long term lumen loss that LEDs have a fair chance of game against. CFLs get such a poor efficiency mainly because of trapped light since the tubes or the spiral point into each other.
CRI is just a standardized number that offers more objective view than mushy gushy sales rhetorics. I suppose we can say that CRI is a consumer lexicon these days holding about the same significance as relating powerful with the SAE J1349 horsepower rating on cars. We know that it's a marketing lexicon that means that it can produce the value when tested per SAE J1349 and the power is allowed to be somewhere in the sky high RPM that prevents it from getting utilized when used as intended.
When people want "reasonably good color" high efficacy lighting, we use spec grade bulbs like F32T8/741 (CRI 70-79, generally 78) or RE80 F32T8/841 (80-89, generally 82-86). The more significant reason for using RE80s is that they hold their light output as well as efficiency without needing the ballast to boost the power over time to make up for the performance loss like it is done with LEDs. They can get 100 LPW and remain at 92-93 LPW for the life of the lamps which can go over 50,000 hours including ballast losses. 50-95% of these lumens are utilized by the fixture. This is completely dependent on the fixture design. The high efficiency types commonly used for commercial lighting are often in the 90s.
C50 bulbs having a 90 CRI aren't used in places of F32T8/850 rated at 86 CRI for the four points of CRI as you take close to a 40% hit on efficiency. TL950 is the same deal. They have a very good actual color rendition and make high kelvin light that incandescent lamps can not make. High efficacy T8 lamps like 32W F32T8/841/HL with 3,100 rated lumens and 85 CRI or 2,500 lumens for the identical sized lamp rated at 25W. The TL950 is a full wattage 32W lamp that's only rated at 2,000 lumens. This is not the level of compromise users will accept for "reasonably good color".
Sylvania makes a full range of full 32W 2450 lumen 90 CRI. Same CRI as C50, but they don't render the color as well. They're compliance lamp that produce an acceptable lumen level in place of banned spec grade 741 lamps. Our government says they must meet 88-89 rated lumens per watt unless the CRI score is 90 or better. Despite the higher "CRI" these lamps do not cost as much as RE80s.
Although marketing wouldn't phrase it like that, above mentioned "compliance bulbs" or 90+ CRI LED lamps are not meant to provide realistic color rendition performance competitive with color critical lamps like TL950 you're using or C50. 90+ CRI spec score is a marketing ploy from the LED industry to sway specifiers to select LEDs. The lighting giants GE, Philips and Sylvania have CMH, LED fixtures, screw-in LED, fluorescent and practically anything you can name that makes light. Philips and Sylvania have 4' T8 shaped LED bulbs in various flavors just like CREE. LEDs have their place like refrigerated areas and when NSF shatter proof requirements have to be met as well as clients who are adamant about using LEDs.
In contrast, Cree only sells LED, so their clear motive for their clear technology bias towards LEDs is clear. The three are basically competing against each other + C, while the Cree is putting a fight against them and the "evil fluorescent" in general.
DLC QLP MINIMUM requirements is 1,600 lumen per lamp, 80 CRI or higher.
The actual output is a big challenge for LED drop-ins as LEDs become less efficient the harder you run them. CREE's 2,100 lumen takes a crack at meeting the phased out 700 series lamps operating on standard 88% output. You'll see in CREE's PDF that it's only a drop in replacement for 48" T8 25W which produces 2,200 lumens on a standard output ballast.
http://www.ledsmagazine.com/article...proved-performance-but-lumen-output-lags.html
When high lumens are needed, T8s can be driven harder with a "high light" ballast. You can drive six 3,100 lumen lamps in a 2 x 4 space for 21,000 lumens, or six T5 54 HOs for 30,000, eight T5s for 40,000.
When exceptional color renditions are needed in addition to just padding the CRI score, halogen, C50 fluorescent or ceramic metal halide lamps are used. LEDs can be used in place of CMH when you only can compromise with "good enough" rendition in exchange for higher efficiency since LEDs make a better use of light in spot lights.
