Crusher run=recycled concrete?????
Cobra5150
GA
My shed is ready for delivery and the guy I was talking to quoted $850 for #57 and $450 for crusher/run. He then says the C/R is recycled concrete. Is this OK or go with the 57?
I always thought the C/R was the last bits left after grinding.
PCustoms
VT
I think the term is used differently depending on region.
I'm assuming this is a small shed on skids (no details were given), so more then likely any sort of permeable gravel/rock/concrete that will compact (hold together ) is fine
racecougar
Missouri
Uh, "crusher run" is stone (limestone here in MO), not recycled concrete.
Is this a garden shed, or something going on a pad or foundation?
yelchevelle
Hoover, AL
I consider crusher run as 3/4 minus, but they sell it different ways. 8910 is like either 3/8 or 1/4 minus i think. I have a place that sells concrete, and they screen out the 3/4” material and sell it separately from the dust (8910). Anything that has the dust(8910’s)that is going to be a foundation or base layer should be compacted. 57 stone should get you 90-95% compaction right off the truck, hope this is helpful
finn
The UP, God's country
Not specifically about recycled concrete, but I was talking to the landscape contractor who was installing pavers at the house a couple weeks ago. We’re in the extreme North of the UP, he was originally from Southeast Michigan, ie Metro Detroit..
He rattled off three names for what we refer to as CMR, or Crushed Mine Rock. Each term is predominant in different parts of the state, but describes essentially the same product. You really have to talk to your local material supplier to understand the lingo in your own area.
I had the same discussion with the pit Forman about a different product maybe five years ago.
kwb
PNW
Recycled concrete can be a great base material. Watch for leftover bits of wire mesh.
It packs well but finished appearances isn't as good as actual crushed rock. I have used it and then topped with a small amount 5/8minus.
C
Cobra5150
GA
Yep, it's a 12x20 garage on skids. I think I'll spend the extra $400 and get actual stone. The guy is delivering some C/R close by but I will go by and check it out just to see.
firebirdparts
Kingsport, TN
Crusher run packs down well because it's not sorted to size. As a result, it has a small void fraction. Good base to pack down. That's what it's for. It doesn't have anything to do with recycled concrete.
FWIW I wouldn't want to pay extra for 57. There might be some reason why that would be better for you, I guess. Might be better on a slope.
C
Cobra5150
GA
This is what he’s been getting lately. Looks like something that’ll just mix in and make a big mess
FTG-05
TN
My rock guy won't lay down recycled concrete on roads anymore. Too much of this:
Recycled concrete was put on part of my one-mile gravel road in 2019. Those pics above were taken April 2025.
C
Cobra5150
GA
Got the load of 57s this afternoon. Tomorrow skid steer is being delivered and building setup Monday.
Also got some “stones” for some landscaping for Mrs C.
jblnut
In the Middle of MN
Around here the “crusher run” product like you pictured is just about given away from the only local guy that crushes waste concrete. Basically you’re paying for the hauling. I’ve gone with my dump truck a bunch of times to pick it up and give them around $4/yd. I like to put it on muddy field roads where it mixes in and packs decently with just farm machine traffic.
Not what I’d use under a shed though. Good call of getting actual stone !!
sgrammel
The 'couv
The small pic of the 'stones' at first glance looked like some 'product' Tony Montana would have.. :)
abfish
A few comments on crushed concrete: If the crushing is done properly, the material will pass DOT specs for ABC (Aggregate Base Course or crusher run). That means it has the right gradation of fines and larger pieces to compact properly. We built some subdivision streets 10 years ago with crushed concrete and they're in perfect condition today.
We did get a couple of flats from rewire that was in the concrete. The crusher has a magnetic separator but it's not perfect. Once the guys on the ground with shovels started looking for wire, we had no more issues.
I agree with your use of #57 regardless.
Mike65
Horse Pasture, Va.
When we got our shed it was built on skids. We made a boarder from PT 4x4's pinned to the ground with rebar, laid weed block & a layer of river rock. The shed was the site built on the rock.
Renegade1LI
long island ny
The local crusher run around here is all stone, 3/4 minus & packs real well. I put down 6" cr & then topped with a couple inches of 3/4 works out great, no weeds. The cr makes a great subase as it compacts so well & adding 3/4 on top locks in well & gives a clean surface & can always place concrete on top.
Renegade1LI
long island ny
Pad i did for our pontoon boat storage, going on third year and have had zero problems.
finn
I brought several loads of crushed concrete for my driveway with my little 3 yard dump truck about a dozen years ago. At the time the pit master said some people didn’t like it because of the white color.
It’s still holding its own, but could use a fresh topping.
Interesting, the color has morphed to regular gravel color over the years for the most part.
