Gangly
As standard procedure, I will wipe my tools down after every use, and then again with a lightly oiled rag after every couple of uses. However, there are tools that I don't typically use as as often as others, and I will on occasion dip them into a cup of clean oil and work them a few times before wiping them down for longer term storage. Living on the gulf coast, tools will rust pretty quickly if not maintained, so I do this if I know it's a tool that I don't use very often. This will generally include tools like pliers, side cutters, adjustable wrenches, etc. that get minimal use between long periods of sitting unused. Again, its typically just pliers and the like, but I have also dipped the heads of some older ratchets in oil and worked the action while submerged. I haven't noticed any adverse affects to doing this, but that doesn't mean that I'm not creating long term issues that I just haven't observed yet.
Does anybody else do the same? If so, has anybody had any bad experiences with dipping their ratchet heads in oil for storage preservation? Is there a significantly better approach?
