About a week and a half ago, I decided my blast cabinet needed some love. So, I took it all apart and began the process of repairing and enhancing. I am documenting the progress at
https://www.garagejournal.com/forum/showthread.php?t=310730 starting at post 6.
I had also ordered an air filtration system for the shop.
Of course that is when one of the light fixtures in the shop failed and while I was waiting on the bits to convert that fixture to LED, the air filtration arrived with so much stuff scattered on the shop floor that I cannot attempt to install that. And, that is when my dishwasher decided to quit on me.
I really can't complain about the dishwasher, as it is over 28 years old. I opened it up to unload the clean dishes to discover water standing in the bottom. I figured the pump had probably failed. I bailed the water out, came back a while later and discovered even more water standing in it. Okay, maybe the fill shutoff valve has failed. Either way, at that age, I will replace the unit instead of trying to repair.
So, lets shut off the water under the sink so I can bail it out and remove the unit in preparation of a replacement. So bail out, come back later and even more standing water. OK the cheap 28 year old sink shutoff is leaking.
Two new shutoffs purchased (no point in replacing just one). Ideally just unbolt the compression fitting, install the new valve and tighten the old nut onto the valve. No, that won't work because the old valves allowed the pipe to insert into the valve further than the new valves, meaning the ferrule is too far from the end of the pipe to allow it to seal. There is very little pipe sticking above the bottom of the cabinet, so get out the dremel and cut off the old ferrule, so the pipe cutter will work in a way that allows removing the minimum amount of old pipe.
I am sure this type of thing has never occurred to anyone else, right? Any way , I have 2 new shutoff valves installed, the old dishwasher removed to the shop and disassembled for recycling and I am waiting on a new dishwasher.
Anybody tried to buy a new major appliance lately? Availability is a joke.
The good news is that tomorrow, I should be able to get back to work on the LED conversion and then the blast cabinet.
