Do you own Push pin pliers?
jerseykat1
Central New Jersey
I was watching a video of astral auto repair on Youtube and i saw how long it was taking to remove some push pins in the wheel well of a car and thought i would share what i use to help combat those VERY frustrating push pins. Some folks don't know this tool exists. There is a video if you click the pic.
youtube link
LXCam
OP those are cool but really you come here to promote your business?. Come on the least you could do is become a supporter if you're going to do this.
JJThrasher
Indiana
Have the pliers, and the little remover pry bar things for them. When that doesn't work side cuts or torch them out.
Empty Pockets
Rural New York
Those are the kind of tool that you rarely use, but when you need it, there is no easy substitute. I'll likely get either the Amazon or HF flavour
J
jerseykat1
Central New Jersey
I will. No i don't come here to promote my business. side effect yes. But no i enjoy the GJ, browse it daily, and post often. be it my own posts or commenting on someone else's.
Ign
Butte Peak ND
You're intimately familiar w these if you own a Duramax. Also buy the replacement set of clips and pins 'cause they don't always come apart like they should.
kblee27
Singapore
I have a few of these pliers including this
https://www.amazon.com/dp/B0002SRCMO/?tag=atomicindus08-20
I remove push pins frequently, and some of those tools are not that useful.
Sometimes the plastic parts are hard to force them apart and you'll need a thin, sharp tool.
For some clips with a center pin, you can push it down and it will open up.
Don't waste time trying to force it upwards.
bwringer
Indianapolis
Yep, you see these a lot on motorcycles. Unless you know the secret (push the center pin in a bit), they will drive you absolutely batty.
xjfish
Yes, I own 4 (Matco rebadged) and use them frequently. Chrysler makes the worst push pins ever made...
CrashmanS
Save yourself $10 and get them from HF for $8 after a 20% off coupon.
These panel clip pliers also work great as well...
http://www.harborfreight.com/panel-clip-pliers-67399.html
I use this style as well. Used for over 20 years. But mine are snap on and alot more expensive. On the pop up center style clips, I just use a flat screw driver to get the centers up then use these.
Sent from my SM-N920P using Tapatalk
TorKe
youtube link
Why is the video a picture? Just give us a link dammit.
Ign
Butte Peak ND
I also stumbled upon a thread I started about this in '11:
http://www.garagejournal.com/forum/showthread.php?t=119966
Others here have contended you can get at the filter from the bottom even on the LMM's but I've looked (closely) and contend they're severely mistaken. Perhaps if you had nothing but time it might be possible in the extremely literal sense of possible, but not at all practical.
And yes, I really just need to install the door on the inner fender. I know that.
And I'm going to take this opportunity to once again give a big F-U shout-out to GM engineers who EASILY could have designed the entire inner fender to be retained by one single type of fastener, instead of four different types.
