Door swing
Sumboodie
AK
Replacing this window with a door as it's a pain constantly walking to the back of the garage or opening the garage door.
Right hand, left hand? Out swing would be nice for space, but I've never seen exterior doors do that around here.
Yankeefarmer
Connecticut
I’d swing it toward the overhead door, because that wall space looks more limited anyway than towards the other window. I’ve heard that you guys get snow in Alaska. If true, and you want to use the door year round, in swing is the better choice anyway.
Doug B
Schroon Lake, NY
Any good lumberyard should be able to set up an outswing door for you, but I agree with Yankeefarmer about the snow, so I'd go with a left hand inswing.
NUTTSGT
Northern Central Ohio
Out swing will place the hinges outside and those can be pulled out and entry gained. You'd have to upgrade to get something better against break-ins.
Commercial doors swing out most of the time for fire code, depending on the occupational capacity.
yeldogt
You will lose space in the garage -- especially with a narrow garage.
What's the problem using the main door? I always set mine up that way. Door in the rear ... where the work benches are.
Out swing is nothing special. Any lumber yard can order -- simple locking hinge sold that problem .... same with the lock. Deadbolt. The problem you have is the truck so close.
larry_g
oregon
You have to have a clear walkway to the door to use it, whichever way it swings. How do you lose any space if the door has to swing in across the space you have cleared for the walk way?
lg
no neat sig line
1MtnGoat
Cleveland, TN
Out swing with tamper proof hinges and a latch security plate will provide better security and more usable room inside.
steaks&anvils
Colorado
With the gas meter at the corner of the garage (between the window and the overhead garage door), does the gas line go along the wall sill under those windows?
Chapter21
North Carolina
"Security" hinges don't really cost anymore than regular ones. Outswing doors are always way better against forced entry, you simply can't force it in unless you use a pickup truck.
I ALWAYS have an outswing door on a garage/shop with anything of value stored.
The Cobbler
been said already, but out-swing doors very common in commercial. NRP hinges ( non removable pins ) are easily obtainable. no more money than regular 4" or 4-1'2" commercial hinges .
in many ways, I think out-swing doors are more secure than in-swing. mush easier to force a door open by pushing on it than pulling on it.
My shed is hollow metal out-swing, I much prefer it to in-swing. Garage, I wasn't thinking when I built it & did 2 in-swing doors
Professor Fate
Gainesville FL
Inswing doors leak when the rain blows against them. Outswing doors do not. Interlock hinges work well when the door is installed correctly and you can get security covers for the lock throws, but there is always the glass window next to it that provides easy access to a determined thief.
nadogail
Coronado, CA
I have welded hinge pins in place to keep them from being easily knocked out. There is not much you can do to keep a determined person from breaking in; but you can make things difficult and slow them down.
Sumboodie
AK
My door swings out. You can buy any swing ya want.
I realize that. I've never seen an exterior door swing out around here though. It would be a fire escape issue in the winter.
It's a PITA with the storm doors, I've had to get outside through the vehicle door several times.
Sumboodie
AK
Or they could just open the door if they wanted in.
Chapter21
North Carolina
Hmmm...kind of a unique area you're in there, it may be a bad idea to swing out if snow is going to pile up there. A swing out door is uncommon in most residential settings, but most home doors are also only held in with decorative 3/4" screws into the jamb. And I've never seen a properly installed dead latch!
Honestly probably more important to use good long screws into the studs, and a good deadbolt for any security. I once had somebody simply cut my metal out swinging shop door in half with a sawzall to rob me. To be fair, the hinges and deadbolt worked!
Sumboodie
AK
I'd probably need to lock the doors before worrying about what screws to use in a door jam.
CraigStu
Blacksburg, Va
I always think about battery powered saws when thinking about some one breaking in. If I were a thief I'd figure the quietest saw to just cut a hole in a wall. 90% of all houses and garages have a 2x4 stud wall so cutting through it is a layer each of drywall, insulation, OSB, vinyl siding. An extra long 5/8 bit for a starter hole, and a recip saw w/ a long blade and you could cut an opening in maybe 2 minutes. Heck you could just cut the siding and osb layers and push your way through the insulation and drywall.
Sumboodie
AK
Got a quote for about $1000 for door and labor. Door with knob is around $300, then maybe $75 for j channel and interior trim.
Sumboodie
AK
Truck is ~8ft away.
Sumboodie
AK
Opening an 18x8 door when it's -20* outside and 60* inside just to walk into the garage is a huge waste of heat.
yeldogt
Depends on how often and how long .... heating air is cheap. If you have the space ...go for it ... they waste in small spaces.
Showkey
"MEMBER EMERITUS"
Wausau WI
Security is a moot point as far as this door change. There’s a another window 15’ away. So if your TRUELY concerned about security there are dozens other opportunities.
Think a choice of door that “looks right”.......as in it came that way from day one would be far more important. Maybe even a service door witha window.
Bert_
NW Iowa
I would want a door also. Opening the overhead door is fine for a storage building, not a shop.
Outswing is no big deal if you want it. Might not be in stock but can easily order it. I like an in swing door. Right or left really depends on how your space is laid out.
loganb
Omaha, NE
Outswings are common for that, but in your climate I get the inswing preference as it doesn't do much good if you can't open it. Make sure you're clear with the vendor as to what side the hinges are on, industry standard is supposed to be saying "left hinge" or "right hinge" as viewed from the exterior, but not always followed. I think I'd also go with a left hinge swinging the panel towards the door as that appears to be the less usable area
K'ledgeBldr
Johns Creek, GA
Lft swing- I’ll leave the in/out to you.
But let’s talk about the Unimog! Those things are beasts! I drove a 406 occasionally when I was stationed in Germany.
Sumboodie
AK
Talked to my Dad and I think outswing will work best. Can leave door open against the outside wall. In swing would mean losing wall space in an already too small garage.
Sumboodie
AK
It's a project. Need to put an engine in it first. Current engine is seized. Have a turbo one to go in, though may not be able to run the turbo.
