Drill press light
drifter_r6
I'm looking for a drill press light. Would like to have 360' lighting of the work space without having to have long goose necks dangling in the way. Maybe something along the lines of this... possibly adjustable brightness. Open to ideas or other suggestions.
thanks in advance.
Chucktin
Neat idea. Could you use one of those inspection lights (has a ring FL tube) and remove the lens?
marinusdees
Edgewood, Washington
You can buy led ring lights in almost any diameter on ebay for cheap. Dimensions called out in millimeters, typically. I bought an appropriate power supply and
put it inside the head of the drill press and wired it in with the existing lamp. I glued small rare earth magnets (Dollar store) on the back of the light to hold it around the bottom of the quill.
This was cheaper than a made-for-the -purpose light.
Bill C
Portland, OR
My Craftsman 100 had lots of open space in the middle of the main drill press casting in front of the column and behind the quill. As such, I used this internal space to mount a LED bulb on a flexible arm. The light is hard-wired with a switch and controlled independently of the drill motor. The light is completely out of the way and can be adjusted if needed. It provides plenty of light directly onto the drill table.
Here are some pics:
Here it is lit up:
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Here are some pics:
Here it is lit up:
AZ Dean Great work:thumbup:
tarbellb
Oregon
Good suggestions above.
Ebay ring LED lights are cheap, and easy to install if you have basic low voltage experience (plus is low voltage, easy to experiment!)
But if you want a easy plug and play non360 option, a "LED sewing light" off Ebay or Amazon is a excellent quick/cheap solution.
txvwnut
Bedford, Texas
thanks in advance.
I have one of these on my mill. I made small brackets and mounted it directly to the body of the mill head instead of the quill like shown in the pic. It does a good job of giving light to the area but does leave a shadow directly under the quill.
JRC3
Southwestern OH
My cheapo bench-top blue Ryobi has a light built in. Might be time to find a nice bright LED to screw into the E12 socket.
Ratchet Guy
Richmond, BC
Here are some pics:
Here it is lit up:
That's a very nice drill press you have there
rharman
SoCal
Here are some pics:
That's similar to my Craftsman floor model but the light was built in with a plastic lens covering it. Replaced the bulb with a 5000k LED and it is awesome.
ndnchf
Fredericksburg, Virginia
I made an LED ring light from a cheap headlight ring off ebay. I used an old computer power cord that stepped down the voltage. Very simple and cheap to make. It is the best upgrade you can make. It is VERY bright and there are no shadows.
endangeredspecies
Here are some pics:
Here it is lit up:
I have a floor standing version of this press, soon to be rebuilt. I’ve been wondering how to get shadow-free light onto the workpiece. This looks brilliant, and I’m going to steal it. Thanks!
no704
Tried one of those ring lights on the mill. Was less than impressed.
FrankLee
seMI, 48317
Nice install! Not to hijack the thread, but gotta ask how you did the cut-a-way pic FrankLee? Very impressive.
Thank you.
I used a circular saw with an abrasive metal cutting blade. For areas that the abrasive blade didn't reach, I used a recip saw with a metal cutting blade. Another cutaway in a short video here.
Rockable
Oak Ridge, NC
I use this one on my drill press. The magnetic base is very strong, so you can actually plant it on the head of the press and adjust it. Also, you can use it for other things. The light is plenty bright for this use, too.
endangeredspecies
I hadn’t even thought about that. Getting this delivered today to light the deep dark recesses within my storage cabinets.
I can just grab one and stick it on the bottom of the drill head when it’s time to make some holes?
endangeredspecies
Loving all the ideas.
When I begin the rebuild I’ll see if I can snake an LED in there like FrankLee and BillC. If it’s beyond my skill level, I can make sure the Milwaukee flood light has a good spot to rest, and a strong enough magnet to hold.
Davefr
OR
I guess it depends how you mount it, but I've never had a gooseneck style actually get in the way. I thought about microscope lights but I don't like the idea of any quill mounted light with a power cord in the way.
