smschriefer
Matt Johnson has the basic idea of where I was going. I was thinking 1x2s for the framing. All you are building is an extremely shallow cabinet and dressing it up with a picture in a frame.
Trying to play with some ideas to “hide” the breaker box. Open to suggestions from the group!
Nice upgrade. We are going to need to see obligatory pics of all the tools organized inside. Looks like you did some measuring before going to the store.
Bret
I think what smschriefer is saying here would be something like this (in basic form)-
1. Use 2x4's (or similar) cut size to "frame" or box" around the panel & exposed wiring. 2x4 would be meet or be attached to the wall on the 2" edge
2. Construct a matching frame & sheet with plywood (or similar)
3. Paint frames desired color
4. Attach sheeted frame to wall frame using hinge
5. Cover sheeted area with artwork of choice
This can get more elaborate as you desire.
I helped a friend do a similar in his garage & sheeted with a discarded white board. As he liked the ability to both have the dry erase for written notes as well as magnets for paper items (like receipts). His panel was located next the door into his home , IIRC similar to yours (but I think his was a bit higher/closer to eye level)
Another option I've used in previous work was to purchase a simple White Melamine Utility Cabinet large enough to cover the outside dimension & IIRC it was about 12" deep. Then cut out the backing & hang over the top of the electrical panel. I picked it up at either Home Depot or Lowes locally.
Quick & Cheap.
Hope that helps & keep on dubbin'
Matt
looking good![]()
This is how I hid mine. Excuse all the mess, they were taken mid garage overhaul. I could have drywalled over the area above the panel, but I wanted access from the panel up to the top plate so that I could snake wires into the ceiling in the future if I ever needed to. I had to do just that when I installed my lift and had to add the 220 line for it.
Always wanted one too, but yeah, couldn't believe that you could spend $100 on one. Garage is looking great![]()
Seeing your updates on IG about sealing the floors has me thinking of doing the same before I install my yet to be purchased SwissTrax flooring. Hmm...
The lights don't look flush to the ceiling. Is there no easy way to make them flush?
What are your thoughts on the window over there? Going to box/frame it in for a simple look, or throw a sill on it and some blinds or whatnot?
I have that exact mop bucket and it has played a major role in my life for many years!
Hey man great thread! What’s you’re IG so I can shoot you a follow? Just got my garage painting as well looking into concrete finishing now and I love the panel detail!
Excellent. Now I know it was a solid choice.
Sounds great. I have two that I’m using for updates. @cleanwagen and @llylock
Best of luck with your project!
A former Irrigation controller perhaps?!
Looks like an electrical box with wires in it. Are there two wires per wire nut? Do you have any lights in the yard or any electrical devices in the yard?
Looks like an electrical rough in to service something outside. Do you have anything outside that the previous owners may have roughed power in to for the future like a shed, well pump, pool pump etc? That conduit must run to something underground.
Nice, added.
PedroA3.
Got some of my garage stuff on there. I’ll shoot you a dm in regards to the cement coating [emoji1362]
Amazing. Think you nailed it. I have two lights at the end of my driveway. Also curious as they are activated at night but I’m not sure where the photocell is.
Photocell could be on the lights them selves. If you have a non contact voltage tester you could see if the box is hot all the time.
Maybe the photo is deceiving but it only looks like there is one set of wires in there? If there is a hot set coming in and they’re wire nutted to the wires going out, then that would make sense at least.
Dubber,
Since the LED over had light panels were mentioned earlier, I'm curious how well you think they are working for you? The cost isn't too bad for them, and considering they're nearly a flush mount, they look good too. They carry them through our costco down here too. Just looking for your inputs?
Really coming together quickly, I have been so stagnant with my garage, and now we're talking about moving so I'm really set back, haha.
Looks great though! Going with a similar design to the double and single or going to change it up with the larger space?
Man! Paint, Looks great
I can’t seem to find the brand/model of those lights, help?
I can’t wait to see what’s next. We’re coming up on a year in my new house and I haven’t done anything in the garage. This thread is super motivating
Nice! You will absolutely love having the heated garage. Did you ever verify if you're walls/ceiling are insulated? I think we talked about it a few pages back but I can't remember. I only ask because you'll be wasting a ton of money in gas if they are not.
