So.....the second set of "OER" hinges finally showed from CamaroDepot.ca.
I thought "Great, I can't wait to install them and set the gaps on the door and quarter!" But let me just make a quick check first....
"Are you serious?!" Yes, yes they were.
Look at how different the front flange is sitting here on the two OER hinges vs the OEM/original hinge in the middle:
Check the height difference! This is the part that butts up against the inside door shell, which sets the door in/out from the post/fender:
Could they be any FURTHER OFF?
In 30 years I can't recall seeing parts so different, then the supplier saying how they found the issue and will send a set from another production run - and they be just as bad! Of course I didn't bother installing the latest set, but here's how it looked the first time I installed the first set CamaroDepot.ca supplied:
So, just to be able to move on, I decided to bush the original set of hinges and install them (check the original green paint):
And here - minus about 6 hours of wasted time - is how the door SHOULD fit:
With the original hinges, there's enough room that I actually have to adjust the door OUT:
And finally, the side looks like a Camaro again!
Now does that make any sense
