Malco's Eagle Grip Story
That sealed the deal, today on a test ride I found a late model set of Irwins on the road, I'm sure they were used hard but the jaws are toast!
They'll be good for welding but not much more.
Now the decision is SO for the convenience or direct for the price?
This is what we're planning on selling them at unless they try and enforce MAP pricing.
LP7R - $34.95
LP7WC - $33.95
LP10R - $38.95
LP10WC - $36.95
LP11C - $49.95
LP11SP - $51.95
These are not going to "test" 2-3X better than the Tekton, Bremen, Milwaukee.... pliers to justify the cost. You are only going to buy these if you want to support USA manufacturing.
I'll bet that they are going to be about the same as the Tekton, which from my 10 second spring loaded center punch test on the jaws are about the same, if not the same, as the Peterson I have. Taiwan and China know how to harden cr-mo steel if they want to spend the $ on it. There aren't any secrets for something this simple. It's like trying to justify SK or Snap On socket price vs Tekton or Sunex.
Thank you for that video. It made me into an Ambassador for the eagle grip. I will buy some and tell all of my buddies to buy them, and so on and so on.
If we all do this, it might just work.
Newell/Rubbermade/Irwin should be run off the face of the Earth for what they did to those workers at the old vise-grip plant. It's completely unacceptable. It should be illegal. It's fucked behavior.
Actually have a couple MALCO products. Will be adding a couple more when you get them in stock.This is what we're planning on selling them at unless they try and enforce MAP pricing.
LP7R - $34.95
LP7WC - $33.95
LP10R - $38.95
LP10WC - $36.95
LP11C - $49.95
LP11SP - $51.95
Snap-on is just over twice the price of the tentative pricing Jori of HJE posted.
https://shop.snapon.com/product/LP-Series/10"-Locking-Pliers-with-Cutter/LP10WC
LP10WC $78.95
https://shop.snapon.com/product/LP-Series/7"-Locking-Pliers-with-Cutter/LP7WC
LP7WC $70.95
IMO, if you have reliable dealer service, who will honor the warranty, SO is the way to go. Teeth are holding up very well after a month. It's weird to use them, they actually hold and grip what you lock them onto.... very nice product regardless of whose name is on them.
I'm going SO for the warranty, I have yet to have any vice grip teeth last. How hard have you beat on them? I REALLY hope they can come out with a needle nose set simply for sway bar end links....they have claimed many a vice grip on me!
For the time I've had them, I have zero visible wear on the teeth thus far. I've only used the 7" pair once, extracting an M6 bolt. The 10" pair has probably done 20 end links or so already? Most of which I used a 1/2 impact on the other side. I had a couple times it spun the link in the teeth at max rpm, no real damage, which impressed me. Only 1 of those links I ended up having to just melt the head off. It's seen a similar number of slide pins, and some light hammering on. I don't really do the two-handed baseball swing with a 3lb sledge on the vise-grips locked on the slide pin, normally the really nasty ones I peel out with an air hammer. But the mildly rotted and frozen ones (still wiggle just a hair) I may be stuck reusing, I used the locking pliers on, and they did well. Yes, there was mild wrist-powered hitting with a hammer involved. I used them today to bend some ABS wire mounting tabs on some struts I was installing. The minimal flex let me open them up to easily slide over the brackets, and bend them up slightly. IMO the ABS wire was going to be just a little too taut over the knuckle.
The jaws actually meet when closed, and meet evenly. They don't go all crooked when clamping down either. They seem to grip as well as I reasonably believe such a product can be capable of. Obviously I want locking pliers strong enough to put a cheater-pipe over and spin out honda crank bolts. But that's above and beyond what is realistic.![]()
HJE is less expensive than the Amazon pricing. They are also a small business that supports us little guys here on GJStrange that Amazon removed the listings for all Eagle Grip pliers.
I called HJE today and their shipment is supposed to go out the first week of May.
HJE is less expensive than the Amazon pricing. They are also a small business that supports us little guys here on GJ![]()
lolidk what i was thinking. all this waiting, and then i didn't even think to try to beat the rush to get them today. they're all gone everywhere, right?
should've tried when i got up this morning.
HJE said that Malco won't ship their order of Eagle Grip pliers until the first week of May. I suspect it is going to take Malco a little bit to get the product out the doors to distributors and retailers.
I doubt anyone is going to miss out just because a few retailers that happened to have stock on day one are sold out.
I see this as a good thing. It means people are buying them.
What was the pricing on Amazon for 10 and 7 inch versions? It’s been painful waiting for these to hit the market and now we have to deal with supply issues.
Yeah, because the backorder problem is so extensive we're going to wait till we're 100% sure they're on the way to put them on our website. Once I get the bill in the mail (usually comes a day or two before the shipment) I'll get the listings up there.
What was the pricing on Amazon for 10 and 7 inch versions?...
I did a quick search on Amazon yesterday and saw $42 but can't remember if it was 7" or 10"
I guess almost 2 decades of chinese irwin and snapon spanish gripon over priced and under performance has led to a user desire for proper made and good old Rona has increased desire for home manufacture .
Dewitt factory going need up the working hours/days to feed the world hunger for first class grips ...
Pliers are bit like wrenches where top quality will turn grip cut break a fixing a slightly lesser tool fails on and stay serviceable much longer .
