strength_and_power
- Joined
- Apr 26, 2015
- Messages
- 1,439
Vertical tubes dropped in for a test-fit after all the notching has been done
20180304_142640
Welded in some supports to keep everything square and smaller pieces to evenly space the top and bottom tubes.
20180304_160341
Everything clamped up (need more of these long clamps)
20180304_155443
Tacked the one side while it was on the ground then pulled it out of the jig and suspended for tacking the other side.
20180304_161341
Walked it out front and did a test fit and it looks really good. Of course almost all of the sections between the posts are slightly different widths, so all I have to do now is measure how long the top/bottom tubes need to be and then center it on the jig. Here’s another shot of the whole thing
20180304_163710
From this point it should be assembly-line work to put the rest together. More cutting and welding…
Anyone in the Phoenix area know a good powder coat place, other than Glendale Powder Coating? The cost of getting these coated is almost double what I’ll have into making the panels themselves, including what I have into the saw.
I’m curious if you will have any issues with the fence panel curling as the notches take a lot of rigidity away and the heat from welding will pull to the notched side regardless of how tight you clamp it.
Powdercoat is going to be pricy for sure, lot of linear feet in those panels.
I have a similar band saw. Decided early on that the accelerated wear from not using coolant was worth not having to deal with the mess of coolant. Started using a high quality bi-metal blade and never looked back
Nice shop. I grew up in Mesa and still get home for the holidays
