#FabSpace
L
lilscorpion
Colorado
i just just mean knee pads that are rounded on the sides, kinda like a motorcycle tire - so you can lean left and right and roll on the knee without the bump that happens with the style that's more like a car tire, with a defined/squarish shoulder.
or, for the super-fly, get rolling kneepads.
Oh gotcha. Makes sense. I think I weigh too much or my pads are too squishy to do any rolling.
On your “roller” idea, I’m visualizing mini set of car skates. [emoji12]
loganb
Omaha, NE
beelsr
NE PA, USA
nota bene!
rolling kneepads will really work out your adductors (inside of the thigh) muscles. bungee cord/strap at the comfortable spread distance will go a long way towards helping break them (you!) in...
damhik... :(
L
lilscorpion
Colorado
Awe daym, they’re real?! Thought that was a joke..
L
lilscorpion
Colorado
Got started on the cabinet additions tonight. Started with some 5x5 prefinished Baltic birch plywood.
Machined the bases, cross braces, counter top supports
Cut the sides with toe-kick reliefs for the 2 different heights
And got to assembly. Here’s a cheat for locating the base - I made a T that’s the same height as the toe-kick and clamp the side to the saw fence
The base rests on the T which gets the height right and staples are landed to hold the base into place while I counter sink and screw it together.
The front counter support is added which now allows me to measure for the back which can be dropped into the dado groove and the rear counter support can be stapled and screwed into place.
With these in place, next step is to join them together and take final measurements for the filler cabinets. Between the two on the left will be the wife’s new desk opening. The original will fit between the two on the right with a filler cabinet made to fit the delta perfectly. Toe kick braces get installed on the very last step during install.
Fairly quick build. Sheet to 3 cases in about 3 hours.
stinkity stoink
New Jersey
Are the cabinets going to be same color as the uppers in the last picture? They look good with the glass contrast . I’m not showing my bride
L
lilscorpion
Colorado
Yes, they’ll be finished the same. The color is a dark espresso and the panels are 80% opaque white lexan. Face frame process come next. Finishing always takes the longest tho.
L
lilscorpion
Colorado
Got a few hours in before mandatory Friday happy hour...wife will need some outlets for the laptop and peripherals between the two new cabinets.
Did a little drywall excavation and ran a wire through the 2x4’s between the existing outlet and where we really need it. #NowItsHappyHour
As the wife says, any progress is progress.
L
lilscorpion
Colorado
It’s been a busy and hectic couple of weeks but I figured I should do a quick update -
Wife got the wall prepped for paint. Like how we painted around the cabinets last time?
I wanted to spray the whole room this time so we got the new floor covered and I got after it with Light French Grey in the airless sprayer.
Then we hung plastic on the walls so I could spray the ceiling white.
After given plenty of time to dry, we got the wall cabinets re-hung and the base cabinets set in place.
Gonna have to pause on the office so I can make some progress on the Powder Coating booth...
L
lilscorpion
Colorado
Got started on the powder coating booth, planning on a simple design. The idea is to creat a vacuum in the booth and vent the exhaust outside using a fan. Parts will hang about 12” in front if a filter that will hopefully strain out much of the dust.
Here’s what I picked up for the evacuation fan. This is a 20” variable speed attic fan that pushes 2220 cfm (at .25”) of static pressure. I used a fan like this at my old house to evacuate the smoke off of my plasma table. Worked very well until the motor inhaled too much plasma grit and seized a few years later. I’m thinking that I’ll mount it somehow to the top of the evacuation hood and pull the air up and out.
I ran down to the local big box to see what they have for a filter. Initially I was thinking I’d get the biggest and best filter they had. After walking up and down the isle a few times, And saw the cost of the “better” filters, I realized it might make sense to run two - a cheapie in front if a good one. Let the cheapie take the brunt of the dust and prolong the life of the better one. I ended up picking up this cheap cleanable filter and an equivalent sized MERV 12.
Now to figure out how it all goes together..
L
lilscorpion
Colorado
I’ve been doing some calculations and running large evac ducts outside (40-ish feet) from the booth isn’t going make any (financial) sense. So a change in direction - I need to figure out how to filter the air we’ll enough that I can breathe it and vent the hood inside. These home air filters ain’t good enough for that.
Not sure why I didn’t do it sooner but I started looking at smaller PC booths another the market to see how they set up the exhaust. Here’s a booth that Eastwood sells which design-wise is like most of what I found.
I can do something like this but with my space constraints, I’ll need to vent out the top instead of to the rear.
I found this cool site called PowderCoatingOnline- https://www.powdercoatingonline.com/the-super-specials-showcases/ . It has a listing of a bunch of different distributors and manufacturers for everything powder coating. . I started calling through the list until I found a supplier that both builds booths and sells filters. I landed on http://www.powdermarket.com. A Short conversation with these guys was beyond enlightening. Not only were they happy to answer my questions, they also made some design recommendations (along with some education) for my booth filtration and design.
First - my fan must pull 100 cfm per square foot of booth face/opening. That was helpful. My opening is 50”h x 38.5w so I’ll need a fan that’s ~ 1350cfm.
Second - in order to recirculated the air back into the room, they recommend using a 3-stage filter assembly just like they do on their coating booths. Each and a specific purpose and together they keep the consumable cost low yet yield breathable exhaust air.
Stage 1/. Called a blanket filter, it looks an awesome lot like insulation. It is sold by the roll and you cut it to size. In the size I’ll be needing (25-ish x 25-ish), the math ends up ~$8 per fikter. In a 40hrs/week setting, they last about 2 weeks.
Second stage is a wind sock looking filter that’s called a pocket filter @ ~$130. Typical production usage @ 40/week they last about a month or so.
Third stage is a hepa filter which looks like a traditional filter but on steroids. They cost ~ $250 each and last ~ 3 months in a 40/week environment.
I will not be coating 40 hours per week, probably more like 4 hours per month...so filters should last me WAY longer. PowderMarket sells a slick little vacuum gauge (a Manometer) that can help tell you when the filters need to be addressed. It has two pickup tubes which you can place on either side of a filter to understand what airflow loss you have. Initial readings are used as the baseline and then once you get to ~ 50% reduction in efficiency, you change the filter.
Though you could install one on either side of all three filters and know exactly when to change each, I think I’ll only put one with the front side pickup somewhere in front of all filters and then after the second stage.
Filters inbound.
loganb
Omaha, NE
Been awhile since I supported our finishing cells from an engineering standpoint, but the filter recommendations you got align very closely with what we used across 30+ finishing cells in multiple states for spraying of water based paint/stain/topcoat for wood parts. We exhaust thru the roof and spraying a different material so the actual filter media varies...but same concept.
Comment I'd make regarding the changing of the filters, first off the manometer is the right way to manage change interval especially in your environment. Unless your doing a very consistent, high volume usage a change schedule fixed on time is very hard to get right, filters get either too loaded or not used enough. If you want to to take it a step farther(as we know you do)...put a variable speed fan in. It gives you the additional ability to only spin that fan fast enough to get your desired flow in the booth based on your part and the condition of the filters...as the filters load up, crank the speed up.
Once that fan is maxed out and hollering for mercy...then you change the front filter media only(the blanket roll) and see what the new pressure drop is. Acceptable...move on....if not start changing some of the secondary filters. You'll likely find that the filters in the "middle" of the filter wall field get loaded up much faster than the others, so you can either direct swap the middle ones...or toss the middle filters out, move upper/lower rows around to fill the now vacant spots and put new filters in those upper/lower rows.
The final filter's (HEPA in your case) only then need changed when the primary and secondary filters are all fresh and you're still not getting suitable airflow....in which case congrats, you got all the "goody" out of the filters and time to swap out!
BoilermakerFan
Indianapolis, Indiana
<snip>
The Columbia Coatings setup I have might be a little more than I really needed. They have their older generation (HyperSmooth) for $500 and its many times better than a hobby gun. With a used basic kitchen oven and a HyperSmooth, you could be pro-quality coating under $600. That’s insane.
And you have the shop space to build a real oven...one that could do bumpers, suspension parts, etc. There exists DIY PC oven build guides that give you step by step for full Size ovens for under $1k. This is my latest rabbit hole...
I was planning to build a DIY PC curing oven in my garage too. Take it a little step further with insulation and heating elements and you could also do ceramic coatings from Prismatic/Cerakote. Since it's the same company, you can order any of their colors from any of the palates. So you could actually color match exhaust headers to the Jeep Bright White if that came from Prismatic.
The tech support at Prismatic is amazing.
Could you run a pleated filter for the first stage to capture the powder for reuse? I know clean powder can be reused. You would have to change that filer for each color, but it could potentially save a fair bit of money over time.
We're going to finally be moving sooner than later, so my powder coating / ceramic coating setup will have to wait until after we move, but thanks to your lead on the Columbia Coatings setups, I have all the pieces planned out for my future setup. :rocker: Thanks Matt!
L
lilscorpion
Colorado
Looks like Columbia Coatings is doing a giveaway. Go and get signed up for chances to win an HD Kool Koat system (2 models up from the one I got). No purchase necessary. Registration link - https://wn.nr/69fxkr
L
lilscorpion
Colorado
So it turns out that the attic fan likely won’t work the way I’d hoped. An attic fan Is designed to move it’s rated free air (unconstrained by ducts and what not). They’d just not designed to have resistance so there’s a good chance that it won’t pull the rated volume and it won’t last. Since it wasn’t cheap, it goes back and back to the drawing board I go.
I used a huge squirrel cage fan for my 5x10 CNC plasma table years ago so I think that will work for this application well too. Seems some of the industrial BC booths use them as well. They ain’t cheap though - roughly $1400 or so for one that pulls the CFM I want with a balder motor.
Downside to these units is that most of them have what appears to be non-standard intake and exhaust port sizes. You can’t just go down to the local HVAC store and get a 9 3/4 x 8 5/8 rectangle flanged duct off the shelf. When I installed a large squirrel cage fan in my shop I had an HVAC company build the transitions but it wasn’t cheap so I’m not wanting to go that direction. Even if the ducts weren’t difficult, these damn things are heavy...well over 100 lbs.
Noticed on a site that many paint and coating booths use what’s called a tube axial fan which is an in-duct fan which eliminates the need for transitional duct work or funky adapters.
Interestingly enough, these fans are much lighter and flow much more with much less amp consumption than squirrel cage fans in a comparable horsepower. Looks like I can get into the right fan (~1400 cfm) perfect for my use-case for about $1k ($650 more than the attic fan I previously purchased)
Great idea and this fan does have the added benefit of having a second speed @ ~2400 rpm!
Fan on order!
L
lilscorpion
Colorado
I plan to build a larger oven once I get everything up and running and am confident that I can actually coat with decent results. That said, every time I spend more money on this setup, the closer I get to it having to work...so I’ve started shopping for parts. It does look like it’ll be fairly easy. Amazon sells a fairly high quality oven controller unit that comes mostly turnkey (‘cept I have to assemble it).
Here’s the link: Powder Coating Oven Controller Kit w/ Light and Fan Control, 240V 50A 12000W (KIT-PCO402) https://www.amazon.com/dp/B073X1CCY1/?tag=atomicindus08-20
Like you said, simple oven elements (4), this controller, a small high heat blower motor (to crest convection), the frame, and some insulation is really about it...well other than doors and hinges which is just a fabrication detail.
Am I missing any pieces that you have in your plan?
BoilermakerFan
I signed up for the giveaway. It would be so sweet to win it, but I certainly don't have any high hopes of winning.
A pneumatic rivet gun if you don't have one already. The steel studs and sheet metal need to be attached with rivets. You'll need the high temp door seal too, and rockwool insulation. I have a 1/4HP-1/2HP 230V VFD I plan to use on my fan motor so I can adjust the convection speed while running a TEFC 3phase motor and have a very soft start on the fan.
You might need heat sinks for SSRs included in the kit too. It definitely would not hurt to add them regardless. The cooler they run, the longer they last. If the temp probe is a RTD type, you can usually add a second one to the temp controller and it will average the temp between the two so you don't have a chance of hot spots. The convection fan helps a lot, but I have about 10 RTD temp probes so I was going to use two with probe wells to make changing the probes easier when they fail.
I'm planning to build a 3'x3'x5' sized oven mounted on a 2x2 square tube frame on the heavy duty leveling casters. That's about the largest size I would need and it maximizes the material use based on 8' studs and 4x8 sheets of sheet metal. The extra sheet metal will be used to make a cover for the blower motor on the outside. The casters will let me push it up against the fold up spray booth when not in use. I'll have my fan and filters on the back side permanently attached to the wall, the sides, top, and bottom will be able to be folded down or back against the wall in order to minimize the floor footprint when not in use.
csp
Franktown, CO
I don't know if a furnace blower fan is big enough, but I have a friend that's an HVAC guy who has a scrap pile full of blowers within a mile of Lincoln and Jordan. This assumes he hasn't taken scrap in for a while. I'm welcome to anything in the pile if that's a possible source for you.
L
lilscorpion
Colorado
Dang, that might have worked and I might still take you up on it if the one I just bought doesn’t work. I was able to get down to Grainger get it -‘s there’s not much to it-
It isn’t very heavy or large though. The up-side about this one is its simplicity, it’s round and router jigs make round holes easy...that said, I need to figure out how to mount it in the cabinet that I built months ago before I had any plan. Being able to pull from a pile of HVAC blowers of various sizes might end up the ticket. Thanks for the offer, I’ll let you know.
L
lilscorpion
Colorado
Who knows how they will pick the winner. I never trust drawings are on the up and up but that’s mostly because I’m cynical. Hope you win, it’s a sick unit.
Looks like my list is pretty close to your list so I’m close. Haven’t picked a riveter yet but pneumatic will be important. I want an oven high enough to fit a slider off of a Jeep so probably 6’ tall x 3’ wide x 3’ deep interior dimensions. The dimensions are diffidently not material/sheet optimized but important for the stuff I’ll be coating.
The two temp controllers is an interesting idea, hadn’t thought of that though I am worried about hot spots. Through the playing I’ve already done with powder there are some coatings that are temp sensitive. Anything Prismatic sells that has a PMT of 400* seems to be ok if temp flashes up higher. They have some clears that will yellow if you cure them over 375*. I coated my jack stands which have varying thicknesses if metal in their design which prevents them from heating and curing evenly. The upper parts cured at 375 but the bases ended up around 410* for last part of the cure process...mostly to do with how the oven maintains heat (fluctuates 20*). The bottoms were slightly yellow (no one else can tell) and the uppers stayed clear.
I suspect similar things may happen with translucent powders but that’s a guess.
L
lilscorpion
Colorado
Here’s the starting point of the powder coating hood. I added a little structure in the top thinking it would be enough
The fan is going to mount to the top of the hood something like this.
I used a circuit cutting jig to rough in the fan mount and thru-hole.
While I was set up, I cut another piece with the same sized hole cut in the center for building the fan mount for the upper filter box.
Can’t tell in the picture but the offset to the rear is exactly the same which will hopefully allow me to attach the filter box to the wall as well.
Mocked up.
I need a transition from the fan to the filter box. This took a little figuring and I cut meters backwards a few times...LOL
A little practice at some crafty miter saw work and I managed to get there.
Test fit the assembly.
Now for the filter box.
I can use the filter itself to alight the birds for the box.
Attached the filter box to the transition.
The entire assembly is only Brad nailed together so the final step is to screw everything together and make it permanent.
Filter box done.
quadrcr87
Travelers Rest, SC
Your progress is looking great. This powder coating setup is really going to be convenient for the jeep projects! Taking small parts to a powder coater and paying their minimum is always a pain. I am usually not patient enough to save up projects to get done in a batch with the same color.
L
lilscorpion
Colorado
Thanks! I’ll admit that I was a little worried about two parts of the build - building the transition between the fan and the HEPA filter and the internal air flow routing (ducting). Getting past the fan -> filter part is awesome. If I can figure out the internal ducting now, I’ll be home free.
I’ve done fairly well working with the local powder coating companies but they just have too many bad business practices. No matter how much stuff I take them, sometimes thousands of dollars of work, and I always get pushed down the priority list. I never get my stuff back faster than 6 weeks even when I say it’s a hurry job and willing to pay faster. That said, I’m already ecstatic with my choice to PC (most things) in-house going forward. We’ve done a few batches of parts for projects in-flight already and being able to fabricate, coat, and install within a single afternoon was amazing.
So much better than spray paint and even better that I have powder that matches my Jeep OEM color code. I can only imagine how nice it will be with dust management once the hood is done.
quadrcr87
Travelers Rest, SC
Exactly. It allow you to raises the quality of everything you fabricate making the final install custom and professional.
BoilermakerFan
Mocked up.
Filter box done.
Are you putting a pleated filter inside the booth in front of the fan? If not, the fan will be sucking in a fair amount of powder.
L
lilscorpion
Colorado
There will be two filters before the fan and the Hepa after the fan. Once I get the next post and pictures up, it might start to make more sense I think. I probably should have done a drawing in advance but I’m kinda figuring my way as I go.
L
lilscorpion
Colorado
With the upper hepa filter box done. I now need to shift focus to the booth face, pocket filter mount, and internal ducting. The pocket filter is 24x24 so I cut a slightly undersized hole and recessed the edge so there was a place for the pocket filters wire frame to clamp to.
This will serve as the face plate for the hood and just barely slides into the case.
I want to keep the internal ducting simple so I just box in the fan hole and use complementary angles on the miter saw for the angles (like 35/55).
And then cut two pieces to 30/60 to ease the transition and then build a mirrored copy.
Since I made the hood the same width as the craftsman cabinet, I decided that the o stall design needed to be symmetrical. I added a little cabinet at orate to the left between the hood and the oven.
Hoisted the fan and the HEPA filter up top into place.
I decided to make a matching cabinet to the right.
With the fan wired, I was now able to close out the internal ducting making the hood now fully functional.
And the filter presses into place. So close now.
L
lilscorpion
Colorado
Controlling the two fan settings was something go hand quite solved until I couldn’t sleep the other night. I’d been thinking about a two position toggle switch until I found this cool selector switch.
It’s a simple design that lets you connect A/B to various (or the same) inputs.
I needed a place for the various switches the cabinet needs so I built a switch box into the drawer assembly.
I’ll keep my various masking material in these drawers. Stuff like high temp silicone plugs and caps.
The switch panels are machines out of 6061 plate I had laying around.
Two of the three panels done. The upper one is for the fan selector. The middle is to control the power to the Powder Coating box itself instead of using the switch on the back of the box and the second switch is for (the eventual) lights in the booth. Since the powder coating gun connections are also on the back of the box, I’ll use the lower plane for cabinet facing gun hookups.
On the other side of the cabinet received shelves, 3 drawers, and the accessory panel
The accessory panel is a 1.25 wide piece if aluminum which will host dual gun connections in the future. For now it will just be plumbed for compressed air.
The panel attaches to a few wood strips that are attached to the cabinet. This should give the panel some stiffness and make attaching accessories much easier.
At this point, the booth is fully functional so it was impossible to prevent a little powder coating from happening in the shop. Andrew sized the opportunity and coated about 100 flat head hex bolts s a side job.
We temporarily attached the pre-filter to the booth during the coating. As luck would have it, the 2600 cfm setting worked perfectly without the sides we had previously planned on attaching.
Slightly over 100 bolts, delivered and installed. Matching the bolts to the armor gives this blacked out Jeep that next level finish when compared to how it would have looked with uncoated stainless.
L
lilscorpion
Colorado
Matt, I see the black armor on a black LJ. Did you have your son's yellow LJ painted black?
Andrew’s Jeep started out with the black oxide stainless fasteners. At the time it was the only way for us to have them black.
As a test he did match coat his fasteners to the yellow of the armor just to see what it would look like.
With all of the corners and sliders matched, we’re now not totally sure matching was as cool looking. That said, he’s not yet switched them back. Not the best pic but it’s easy to see how muted the armor looks now. Clearly not as cool.
L
lilscorpion
Colorado
Nice PC setup! If you were located in Indiana I would be sending all of my work your way.
Thank you! I’m almost setup to the point I could do some side work. That said, I have a mountain of work I have to do for my Jeep on short order so if I did take work I’d end up a few months out. [emoji3061]
Got a few of my parts done as well. Interestingly enough, the powder I use that color matches the Bright Dodge White Laura down beautifully..
29f438ebaf69f9de0813dcf49a5695dd.jpg234b0669a9a38cf8cc96596113e72306.jpgbb36652610c78d5bca9aaef88dc14773.jpg
L
lilscorpion
Colorado
Nice.
I just saw the last couple of pictures in post # 471 and thought you painted Andrew's LJ black.
Oh hell no! Though I do wish I had the shop space to have a booth. Maybe someday but a bigger oven is first. His Jeep is done for now. Next step in it will be a turbo but that’s a few months away.
That black LJ is the GM’s latest personal build at a local 4WheelParts.
zmotorsports
Northern Utah
Gotcha. I thought the paint looked pretty damn good on Andrew's Jeep and was surprised when I saw the black one.
rattle_snake
Chandler, AZ
Jealous of the powder setup. :drool:
Quite the undertaking, you did a great job on all the pieces., keeping it compact, organized. Great work.
:bowdown:
