#FabSpace
L
lilscorpion
Colorado
Damn Matt, that thing turned out freaking AWESOME! You and Andrew should be very proud and pleased with that build.:bowdown::bowdown:
It has a great stance and yes, those 40" tires make your 37's look small. As for uptravel, 5" is pretty respectable but for rocks might be a little much. Lift height is a balancing act between enough to clear the belly yet not too much as to induce that tippy feeling when off-camber.
In my current configuration on my JKUR I am sitting right at about 4.25" of total lift height over stock and have 4.5" of uptravel in the front with 5.25" of droop for just under 10" of total travel. In the rear I have a balance of 4.5" uptravel and droop, 9 inches of total travel. So far with the two trips off-road in this configuration I feel it is about perfect for my style of wheeling. I'm not into the bumpstops hard in the front like I was with the ACOS spacers and the rear is much more controlled in both drop-offs and climbing ledges. All in all I feel it is performing perfectly and seems to flex enough for the trails that we hit and still keep things planted.
Thanks Mike! Your JK is dialed in for mid arms, that’s really good and a nice balance. Can’t wait to get into mine shortly. Parts are starting to show up even!
Agreed (too tall). We have a bunch of options in regards to height adjustments. The springs we installed are about 4" of lift and the PO had an OME lift on it with 2 1/2" springs which really only net about 2" of lift. I purchased some "budget boost pucks a while back that add 1" and together with the OME springs, we're right under 3" so we chose to try this setup. Andrew got busy as soon as he got home and disconnected the shocks and sway bar. I took some reference notes on the existing setup so we'll know exactly the change after any adjustment.
We worked a corner at a time swapping springs and adding in the boost pucks. Had to bore the rear pair out on the lathe because they wouldn't fit around the after market bumps but they cut like butter.
Originally, we had 5" of up-travel at all four corners. We replaced the factory isolator (about 1/2") in the front with the 1" budget boost, and added the budget boost on top of the isolater in the rear - thought process for leaving the isolator in the rear is it adds 1/2" which we'll need to compensate for the rear bumper/tire carrier combo. We now have about 3 7/8" up-travel in the front and 4 1/4"-ish in the rear.
Think this height is just about perfect. Can't wait to get it out in the sun next to the JK again so we can compare.
I have a question Matt, in the picture where you are machining the raidus on the pitman arm I don't see that you are using a rotary table for this, is your mill a CNC? For some reason I thought it was a manual milling machine.
Nope, gave up manual machining back about the time I founded TNT. Used it to machine quite a few of our parts a few of which I've done here on this thread. I can manually build just about anything as a one-off given enough time but CNC plasma, mill, lathe, tubing bending, and press are really key for building repeatably accurate parts at scale. I kept only the CNC Mill and a manual lathe after leaving the business. The rest went with it and I miss all of them.
I do have a rotary table and an indexing head that I use occasionally when I run into a largish part that needs to be indexed. Sometimes it's actually faster to set them up than it is to build a fixture that allows you to build a larger part in quadrants.
Arclitgold
Wow this has been an awesome journey and the finished product looks fantastic!
zmotorsports
Northern Utah
That turned out fantastic Matt. That's almost too pretty to put on the trail.:bounce:
I don't think you'll miss that 1.125" of uptravel compared to the lower stance and COG.
Thanks for replying to my question.
rattle_snake
Chandler, AZ
Because I can't help myself, I'll just go ahead and type it;
'you know, you could have just put bigger tires on instead of lowering'
Of course this is not a good option given your goals for the jeep, but what pops into my head, in addition to adding a nitrous kit to anything and everything.
Might have to steal the 1-5/8 DOM steering tube idea, I was wondering what the magic material was for 7/8 rod ends. I don't like the weld on ends much, 'cause my welds ****.
L
lilscorpion
Colorado
Ha! That’s not just funny, it’s situationally appropriate. Yesterday, right as we were about to roll the jack under the Jeep, I looked at Andrew and said - “ya know, we could just move these 40’s to the JK and go to 42’s”. He looked at me like I invented candy...
L
lilscorpion
Colorado
Somehow made a duplicate. Can’t delete so I made it fun.
glockman
Northern Utah
I followed your initial GJ thread years ago and was amazed by your tool organization. Just found this thread and read it all the way though tonight. Very nice work. Oddly enough, I'm just about to start an LS swap into my 06 LJ. I pick up the transmission today which is the last piece needed before I start pulling the stock drive train.
L
lilscorpion
Colorado
Outstanding work and great story. The time spent together teaching, learning and sharing time is priceless.
I think we both got more out of the time together that. I could have possibly imagined. I. 6 months he changed in ways I couldn’t have predicted. I wanted him to appreciate tools and the shop. He didn’t before but now he’s looking for reasons to go out there. Super cool dad moments.
L
lilscorpion
Colorado
Thank you. Speaking of which, I’m about to kick off another organization project hopefully tomorrow and will be updating the thread.
We’re already talking about an LS for ours. We’ll follow along if you’re going to document it.
L
lilscorpion
Colorado
Steal away. They’re all I’ve ever run on my rigs and work great. It works for trac bars too if you plan to run one.
zmotorsports
Northern Utah
I love the Forest Gump meme Matt. I may have to steal that one.:lol_hitti
You mentioned that you were already ordering parts for your JKUR, what are your plans for that? Are you sticking to 37's or going to jump up to 40's?
I don't think you'll be disappointed if you decide to do an LS swap. I know the LT's are all the rage right now but I am still very pleased with my choice on the LS as it has less moving parts and is a simpler engine, just what I wanted for an off-road rig. I still smile every time I hit the ignition and get to drive my Jeep and it's been over a year now.
L
lilscorpion
Colorado
I’m planning to do something similar to the LJ. I’ve decided to use the motobilt crawler fenders (stubby, almost non-existent), sliders, and bumpers. I pickeD them specifically because I have some customizations I’d like to do and their format should make what I want to do possible. Guess we’ll see.
I will go up to 40’s but only after the motor. Given Colorado just announced it is following California for emissions control this year, I’ll probably need to have Motech do the swap so I can get the California Executive Order that comes with it (more or less a certification). I’m not sure which motor I’ll be doing yet but the discussions I’ve had with them thus far led me to believe there’s a $6k difference between 450 and 730hp. Gonna be difficult to not go big for only $6k more. I’m still working through the details but I’m thinking mid-summer.
I don’t really know the complexity difference between the two generations of motors. I’m assuming simple may reduce potential complications?
For suspension I’ll run the same YLink suspension up front with coil-overs and I’m not yet sure on the rear. I’m still researching.
L
lilscorpion
Colorado
Stroll wrapping up some tasks. Got the hood patches mounted. Drilled the holes in the powder coated parts (ouch).
Then cut 1/8” black silicone gaskets out of a sheet to put between the patches and the body. This will keep them in place.
And a little polish on the hood.
After a few trips to the store, we found one of the brake lines to the passengers side was leaking. Apparently I nicked it while cutting brackets off a few months ago. Who knew. Couldn’t get fittings to slide over the coating on the factory brake line so we had to re-make the entire line. Got to use my new fancy brake line flaring kit.
Almost idiot proof and beautiful double flares.
And the new line is in, brakes re-bled after removing the oring on the proportioning valve.
L
lilscorpion
Colorado
Spilled some brake fluid so we rushed to the car wash. Andrew landed this awesome picture while i pressure washed it...
slodat
Central-ish, WA
That's badass!!
If this is your son's build, I can't wait to see what you do! As a guy that's never been into the 4wd thing, I'm blown away by how much I like this Jeep. Thanks for taking the time to document it so well for us!
zmotorsports
Northern Utah
Matt, if you're needing an EO (Executive Order) for emissions then you really only have two options currently. The 5.3 liter LS (I think it is the LMG) Robbie just received the EO for a couple of months ago but I don't think you'd be happy with that option. Although a pretty nice step up from the Pentastar it will struggle with your heavy JKU in the mountains of Colorado.
He is just awaiting the EO for the L94 6.2 liter LS engine now which he is expecting any time. This is the engine I have and is really all one needs, probably more. I was going to go with the L96 which is the 6.0 liter truck engine thinking it would be all I would need but I just happened to stumble across this 6.2 L94 for nearly the same cost.
In my opinion the truck/SUV engines such as the L94/L9H (6.2) or even the L96 (6.0) are the perfect engines with their VVT, tall intake manifold with long runner for low end torque and will idle all day long at 550 RPM smooth as glass. The LS3 (6.2 engine that comes in the manual trans. Corvette) is a bit simpler engine not having any VVT but idles a bit higher and torque comes on a bit higher in the RPM range. There is also the L99 which is the 6.2 Corvette engine with auto trans. also found in the Camaro. IF you want all our HP for desert racing or the sort then the LS3 would be the engine and can be had in stock form of 430 HP or 480 and 525 HP versions right from GM Performance but it will come at a cost of emissions and have that rumpity rump idle. While that does sound cool I must be getting older because I wanted mine to idle dead smooth with little to no detection of anything "hot rod~ish" under the hood. The LS3 in stock or higher HP versions won't have an EO and he isn't applying for one for that engine. Also, not sure what your intentions are (if any) for axles but with the 6.2 LS engine and normal driving, even off-road trails, the Dana 44's will handle them up to 37" tires. With 40's or with the 6.2 liter LT's I would be looking at 60's/80's.
THe LT's are the next evolution of the GM engines with direct injection and CVVT but again, fairly new in the swap world and no EO yet or application. Robbie was discussing or possibly swaying me towards the LT with the 8-speed but I kept going back to the thought of having a simpler engine for off-road and I didn't need that many more moving parts in an engine which is why I stuck with my original plan of the LS and 6L80 six-speed transmission.
Now all that being said, it doesn't mean you have to have Motech do the swap in order to benefit from the EO. It just means you have to use ALL of the parts that are referenced in the EO and prove their origin when the time of state emissions testing rolls around for a certificate of compliance.
ALL things right down to wiring harness, CAT's, intake duct and even the transmission must be used. Yes even the transmission because they have what is called VCN (Vehicle Calibration Numbers) which tie the engine and trans together to form a unit and the ECM and the TCM are connected.
Utah's emissions are getting as bad as California's and it's sad when I can go into the State Air Quality Board and know more about the USEPA laws and compliance than they do. I went in armed with my copy of the USEPA with the highlighted sections and had to prove mine was already a certified "package" from the 2012 GM Denali it came out of.
Anyway, sorry for the lengthy diatribe. Back to your regularly scheduled awesome work on the LJ and I will be watching for the same on your JKUR.
L
lilscorpion
Colorado
All of you’re feedback is appreciated, I’m still learning...still at the point where it’s fairly overwhelming but that may pass. I need the EO so that does limit which ones. On the call with Robbie he mentioned that he should have the EO for the LT4 by fall 2020. I think he’s started the process and is way at the beginning. I was leaning toward the motor you put in yours but Robbie kinda pointed out how much power I’d give up at altitude...then he pointed out that the LT4 is only $6K more. I probably need to call him again and re-have the conversation.
I don’t need stump pulling power for the Jk but, admittedly, I’m still kinda in the hot rod phase (clearly given what I just did to the LJ) and I somewhat miss racing, so I’m not against going stupid big. The JK has DynaTrac 60’s under it too, and I plan to swap the t-case for a 3.0 Atlas so I should be able to handle the bigger motors. Suppose you’re right though, a Dana 80 may be a needed if I go too big.
I’m nervous about doing the swap myself though I probably shouldn’t be. Since I don’t have a lift I know the swap will be much more difficult. It hasn’t been that long since I installed the 4L80E in my old Chevy pickup and that’s not something I feel like doing again on my back. Maybe I’m just being a wuss. There are a few things I’m content paying others to do, I just haven’t decided yet if this is one of them.
zmotorsports
Northern Utah
Matt, I'm not doubting the EO application on the LT but I would be a little skeptical he will have it this year. I know the one for the L94 was submitted early 2019 just after the 5.3 LMG was and it still hasn't gone all the way through yet. The LMG EO just barely went through a couple months ago so I'm expecting the L94 EO any time now. Luckily I was able to converse my way through it here in Utah by explaining the USEPA law to the testing station and how it is really written vs. how they were interpreting it. Also, I think he was looking at getting the EO on the L83 (5.3) and L86 (6.2) first as they are the most popular right now. Yes there is additional power and more importantly torque with the LT's that's for sure. My L94 has around 425HP/435 lb/ft of torque and I think the OEM tune on the L86 puts it right around 460HP/485 lb/ft of torque right out of the box. Couple that with the 4.6:1 first gear in the 8L90E and that thing is a stump puller without any power adders.
Although I don't need the EO as mine has passed Utah emissions, I would still like the EO to just have on hand. When I did my swap I used all of the same parts that Robbie used when he submitted the EO application as he was nice enough to send me a parts list that he used for the application. Rather than buy everything in kit form from Motech I sourced most of my parts myself with the exception of the billet brackets, bolt in motor mounts, integration wiring harness with CANbus module and radiator. All other parts I sourced locally.
The LT's are awesome but again more moving parts with the CVVT phasing and the high pressure fuel pump for the direct injection and not as rationalized as the LS's although I'm sure they will be eventually. Power in the mountains of Colorado is still awesome even with my little 6.2 LS. At the normal loss of 3%/1k feet in elevation loss I still have just over 300 HP at over 10k feet elevation which is over a hundred HP more than my OEM V6 had at sea level and more than double what the V6 had at altitude.
I agree that you won't want to go more than 3:1 on the transfer case. I sold my RocTrac 4:1 (NP241OR) and went with the 2.72:1 NP241J and love it. Enough wheel speed for either sand or snow yet still with my 4.02 first gear in my transmission to crawl.
The Atlas will be a bullet proof setup but I don't like the gear noise from them in a daily driver. The chain is plenty strong and much more street friendly for cruising down the highway than listening to the gears in the Atlas but that's just my opinion and rather subjective at that.
I have no doubt that you would be able to complete the swap yourself in your traditional high level of craftsmanship manner and if I were you wouldn't hesitate to do it in-house.
zmotorsports
Northern Utah
Also Matt, I didn't realize you already had D60's under your JKUR. That would make sense to go with the LT where you have already addressed the axles. Not only do you benefit with larger ball joints in the front but also larger ring/pinion which is what I feel is needed with the L86 (6.2) just because of the massive torque numbers being produced and that super low 4.6:1 first gear. That is where **** can go wrong if you get bound up but with the beefier axles you should be fine.
I was (still am) criticized for running D44's under my JKUR with my LS. If you believe all of the critics I should have snapped them in half just merely backing out of the driveway. I have 16k miles on this powertrain now and many off-road miles between my South Dakota, Ouray and two trips to Moab this past year and nowhere did I have any issues. If I were to put 1-ton's under my Jeep I know I would be pushing that 7k pound mark and I don't feel they are needed for my application, especially because I drive my Jeep respectfully and don't flog on it. Others who are hard on their equipment may not be as fortunate with my setup. I don't let my Jeep hop on climps and don't use the skinny pedal to climb obstacles. I prefer to crawl and if I slip I will usually reset and pick a different line vs. hammer down on the throttle. I have spun a little on a few obstacle and had no worries but that's not the norm.
Either way, I think if it is pure power you want then the LT/8L90E (Gen V)would be the right choice but seeing as how you need that EO right now you're pretty limited to the LS (Gen IV).
Keep us posted and I look forward to the build. IF you are going to have a shop perform the swap then Motech is the shop to go with and Robbie is as knowledgeable of a guy as there is.
L
lilscorpion
Colorado
MMy L94 has around 425HP/435 lb/ft of torque and I think the OEM tune on the L86 puts it right around 460HP/485 lb/ft of torque right out of the box. Couple that with the 4.6:1 first gear in the 8L90E and that thing is a stump puller without any power adders.
Mike - this is all I really need to be honest. Maybe I'll dial it back a notch and work through installing a more simple setup. How does the EO work? Is it something (like a pre-negotiation) that Robbie has with California which he makes available to his customers as part of the purchase process or is it something that anyone can get if they have a matching setup (matching to the specs)?
Ok, easy enough. Is it reasonable to assume that the swap could be done on the floor (without a lift)? I see most of the swaps actually lift the cab to get the motor and trans in. It's really this step (and programming) that has me apprehensive.
350HP in town is really more than enough. I want to be able to set the cruise control at 80, pull the I-70 hill into the mountains, and have a little something something when I need to merge into traffic. Those are the real requirements. (silently I just wanna feed my up coming midlife crisis).
I've had 2 atlas t-cases. 4:3:1 and 3.8:1. The 4.3 was horrible. Had to switch back to Hi-range between obstacles, just couldn't stand going 3 mph. The 3.8 was marginally better but I still felt like low was too low and used it less and less especially when wheel speed was needed...and in some cases, Hi was still too much making me want to be even higher. Think 3.0 will be a good choice.
Neither of my atlas' made noise but I suppose it's been a few years and it's possible that I've forgotten. Is this a common thing?
L
lilscorpion
Colorado
Meh, web wheelers. That being said, I've broken a few axles on a Dana 44 with chromo shafts. The problem wasn't the axle's durability, it was, as you pointed out above, the driver. Before that I broke a few c-clip style axles. It's for those reasons that I have subscribed to the "go much bigger than you really need" mentality. I know the Dynatrac axles come with a big price tag but the failure rate is much less as long as they're maintained. Maintenance to me is the key. I think just about eery failure I've had has been the result of me not catching a necessary maintenance item and, as a result, the part fails. It's not fun doing inspections after every trail ride and once a month but it's necessary.
Jo Diesel
St. Johns MI
Can't you use a Hemi that is installed in the newer Jeeps? They already have emission approvals. I am under the understanding that you can swap any thing newer, you just can't go back. Sorry I believe Mopar or no car and Cummins
zmotorsports
Northern Utah
The EO is basically a certificate from the ARB (Air Research Board), in California it's known as CARB, that states this application has been approved and has been proven to pass the USEPA guidelines for use by the EPA. Things like air intakes, exhaust systems, etc from the aftermarket all have to go through this process in order to sell items that are CARB compliant.
Robbie went through the same process where he used certain parts and submitted them and a vehicle to the ARB for evaluation and ultimately, approval. I think it was made slightly easier due to the fact of using all OEM components which were already certified by GM at the time they were developing said vehicle(s). This is why using "hot rod" or custom wiring harnesses won't pass ARB certifications for use in anything other than hot rods or off-highway vehicles. Granted some states do not have such emissions laws so pretty much anything goes but those states are becoming few and far between. Plus I also wouldn't want to have a car that isn't legal to drive on the street unless it was race only.
When the Executive Order is approved it will be basically a certificate that states as long as all of these components, (X, Y and Z) are used it will be USEPA compliant and more importantly must be accepted by the county or state you are dealing with. It is not specific to a certain shop performing the work but specific to the components being used.
Yes, the swap can be performed without lifting the body, although a bit more time consuming and a few more clearances must be dealt with. If you were to use weld in motor mounts I don't know how possible it would be but if you use Robbie's bolt in motor mounts I can see there being enough clearance if you remove the front core support and if using the truck/SUV engines, remove the upper intake plenum.
The L94 has nearly 350 lb/ft of torque just off idle and tops out on torque around 4k RPM. Coupled with the 6L80E transmission having a 4.02:1 first gear even my heavy JK @ 6k pounds leaves the light like a go-kart. As for cruising on the interstate on grades where my V6 would downshift and scream to around 5k-5500 RPM in second or third it now stays in 6th gear and with the cruise control on will hold within 1 MPH. On some grades however, if I'm slowed due to traffic or such it may downshift into 5th but that about it unless I am really slowing and then it is just getting into the optimum gear. The new generation of dual clutch GM transmission being torque sensing are always trying to get into and stay in high gear as quickly as possible for efficiency reason.
The difference between the LS and the newer LT engines will be the LT's have the ability to phase the cam continuously during the RPM range to maintain cylinder pressure whereas the LS engines with VVT will be in static position until around 3k RPM where they phase and shift the cam profile to retard the cam. It allows the cylinder pressure to be higher at lower RPM for torque but also why they require premium fuel. The LT may phase the cam slightly rather than a downshift for a slight addition of power whereas the LS may merely downshift to a lower gear. That's the biggest difference I've noted between driving the two. Again that may be a bit subjective but has been what I have experienced as far as power availability and driving impressions. Both engine generations have pro's and con's as far as I'm concerned. One uses more technology to improve performance (LT's) and one uses advancements but still based on the proven small block Chevy engine (LS's) but in the end both are a HUGE step up in performance.
Also on a side note, I really like the closed EVAP emissions system of the LS's and LT's vs. the ESIM (Evap System Integrity Monitor) of the Chrysler operating system which is pretty basic and primitive. It uses a spring loaded shuttle valve to shift between venting and/or purging whereas the GM system uses an actual FTP (Fuel Tank Pressure) sensor and a vent valve at the rear and the purge valve up on the engine to monitor and adjust the EVAP system continuously. NO more smelling fuel on the trail after an off-camber or steep climb like the OEM Chrysler system and much more precise.
I've had gear driven NP205's as well as been around the Atlas TC's and have always noted a slight gear howl from them but with the heavier GL5 gear lubes the noise has been minimized. For shear strength and durability the gear driven TC's get the nod but still rely on the splash system for lubrication. However, for daily driving, especially in really cold weather, I prefer the chain transfer cases with their pressurized lube systems and ATF fluid. The chain TC's are still very durable and I like how smooth and quiet they are.
I also agree with your thoughts on the gearing. With my OEM 4:1 Rubicon case it was great for climbing off-road but it kind of needed it due to the 2.8:1 first gear of the 42RLE automatic Chrysler transmission. I didn't have enough power to run in 2HI between obstacles so I usually had no choice but to leave the car in 4LO pretty much any time I was off-road. Now with over 400 horses on tap and my 2.72:1 TC I have found that I usually reserve 4LO for the actual obstacles and much of the time shift back into 2HI once over an obstacle and run down the trail at low RPM, less sound, less heat and smoother all around.
If you look at the numbers alone, with my OEM V6 setup I had a first gear of 2.8:1 and coupled with the 4:1 transfer case had an overall first gear of just over 11:1 (11.2 actually). Now with my 6L80E having a 4.02:1 first gear and the non-Rubicon TC ration of 2.72:1 I have just under 11:1 (10.93 actual) but with twice the available power.
I've taken slack for giving up my 4:1 TC but even calculated out further to include final drive ration I'm not that far off of what I had from the OEM but much more power and definitely more actual usable power due to what it allows when off-road. My OEM setup with the Rubicon TC and my old 5.38:1 gears I was around 60:1 crawl ration whereas now with my GM powertrain and 4.56:1 gearing I still have around 50:1 crawl ratio, but again twice the available HP and torque available. I am still able to crawl easily over obstacles at barely over idle. I also like the 2.72:1 TC for the mountains of Colorado as well as sandy washes and snow wheeling, although snow wheeling isn't my favorite thing to do, but it allows for better wheel speed compared to the more restrictive 4:1 ratio.
I hope that is helpful and I didn't confuse you but I tried to relay my experiences for comparisons. Again these may be a bit subjective but I feel like I have a pretty decent grasp on what these swaps involve and the results.
zmotorsports
Northern Utah
Don't get me wrong, I'm not knocking the axles you have, in fact I'm a bit jealous but really don't need more than my ProRock 44 now and built D44 rear for my driving habits.
If I were to upgrade Dynatrac would be my choice as well as their components are top shelf all the way.
zmotorsports
Northern Utah
This is what my local emissions station tried telling me to do but technically if you really get down to the nitty gritty, a Hemi swap is not USEPA compliant. Yes, it is staying with the same parent company but you're not using a pure operating system. With the GM LS/LT swap you basically bring over the ENTIRE powertrain system which includes the certified emissions and EVAP system and more importantly the GM operating system which includes a pure ECM program and TCM. Both the ECM and TCM are required for the VCN (Vehicle Calibration Number) which technically is required for USEPA qualifications. In the end you have a GM Denali, Escalade, truck, etc. certified EPA package now in your Jeep.
IF you go the Hemi route you have an adulterated system by having to import a Hemi tune into an operating system that was not programmed nor setup for that. Some call it a hack & patch but by importing a Hemi tune into a V6 operating system that doesn't recognize some of the parameters in order to alleviate engine codes and some safety features of the engine these are disabled. Mode 6 data becomes unavailable and this data technically is necessary for the package to be USEPA compliant.
We have a lot of Jeeps running around here locally with Hemi's and they have basically BS'd their way past the emissions stations by stating they are of the same manufacturer but if you read the fine print in the USEPA guidelines they shouldn't be allowed to pass. They will not pass in some states such as California and now Colorado due to not having this Mode 6 data and correct readiness monitors to provide data.
As for your understanding of newer, you are correct. The new powertrain must be of the same model year or newer and the same weight class. But the Hemi conversions are technically a hybrid being that they have an imported operating system and parameters.
Your assumption of already having the certifications from the EPA are actually more true for the GM swap vs. the Chrysler Hemi swap for this very reason.
L
lilscorpion
Colorado
Here’s what’s wrong with a double triangulated 4-link rear suspension - the exhaust. There really is no good way to run an exhaust so the best you can do is cork-screw around the upper arm and hang the muffler off to the side just up under the bed. Pie’ing an exhaust together is easy(ish) usually but this time I had some challenges welding the pie pieces together. The material is 304 stainless so it’s more difficult anyway with MIG but having to weld together pieces mid-bend means that I’m also **** welding where the material is stretched during the bending process resulting in a much thinner wall making it much easier to blow through.
Hind sight - should have gotten .024 wire instead of .030. Also should have taken the time to make up a few practice pieces out of the drops. As always, hindsight is loaded with common sense which was both known and ignored because I was trying to go fast.
Total cost for the entire exhaust (precat y-tube, cat, stainless mandrel kit, muffler, etc) - ~ $1k
300 bottle + tie-mix - $550
Spool stainless MiG wire - $100
Time - 5 hours
Savings - probably lost my a$$
Street Cred points - +5
L
lilscorpion
Colorado
Though when there’s enough meat, stainless is satisfying..
zmotorsports
Northern Utah
Exhaust looks great Matt.
I know what you mean on fitting those exhaust system up under a triangulated 4-link. When we did my son's WJ it was like trying to fit a round peg in a square hole to make it look decent as well as functional without hitting the suspension during cycling.
Yours turned out fantastic Matt.
L
lilscorpion
Colorado
Andrew’s friend came over last night with his 2002 Jeep TJ. Apparently he and his father had installed some headlights but hadn’t figured out the LED halo’s yet. Andrew helped him get them hooked up to the turn signals and ignition so that everything worked as they should and then they adjusted the headlight’s height too. He didn’t need my help, guess he’s learned a Thing or two. Wish I had a bigger garage, felt bad they had to work in it in the driveway.
About 11pm I get a call from Andrew - “Dad, can you come help us? My friend and I were driving over snow piles and he got stuck.” When I got there I was introduced to his parents who weren’t all three amused. Took only a little tug with the Jk to get him free.
I guess Andrew’s friend got grounded for a week. I thought it was funny. There’s so much worse things the boys could be doing.
Monza Harry
Windsor ON
Don't Matt, that there is "Character Building action" right there
About 11 PM I get a call from Andrew - “Dad, can you come help us? My friend and I were driving over snow piles and he got stuck.”
That sounds like a "From Personal Experience" quote
Harry and I'll take the fifth on personal experience part! :shocking::confused:
zmotorsports
Northern Utah
That's awesome Matt. It's a great feeling to see your kids work through issues or problems on their own and a sense of pride knowing they must have been paying attention at least a little bit. My son had a similar situation with his friend's XJ a few years ago. He had brought it over to our old place and was having starting issues. My son was able to walk him through the process and found an ignition problem. I stood back and my chest filled with pride as I watched my son diagnose the issue.
As for getting stuck in the snow, yeah, there are worse things boys could be doing than that.
L
lilscorpion
Colorado
Harry - oh yeah. When I got home I told my wife some stories from my teens. A friend of mine had one of those old Jeep Grand Wagoneers, the ones with the fake wood panels on the sides. He'd put a lift on it with slightly larger tires. A few other friends had the radon smattering of 4x4's too - 'yotas, a really nice '69 Ford bronco, a 1978 Ramcharger, and a 1977 Chevy pickup. We all used go to down to this place just south of the airforce base which was kinda like a suburban off-road park for teens. We'd wheel around for a while then park and hang until we were chased off by either the local police or the military police (depending who we caught the attention of). Initially there were only a few ways in and out of the park but over time, to avoid capture, there ended up being maybe a dozen. Looking back it seemed so innocent really, nothing bad ever really happened.
Then there were the street races...similar story, much faster escapes. :lol_hitti
I was bummed the other kid's parents came down so hard on him. After talking to Andrew this morning I learned that the only reason they were there was that they were monitoring their son on Life360 (kid tracking app) and had noticed their son had stopped in a parking lot and not moved for a while. I guess they assumed he was up to no good and decided to drive to the parking lot to see what he was doing. They arrived unannounced to see him stuck in the snow.
Wish your son was around when I got my first XJ. Probably had the same issue.
Fatherhood is a very interesting thing. There are different moments just like you're describing throughout the years. All of them I would classify as moments of pride but all distinctly different. Where the become really special to me is when they resonate as what my wife says are "just like dad" moments. There's something about that moment when they look at you, as if bragging, and say "I figured it out". It's just awesome.
gearhead1960
Matt,
Damn helicopter parents.....sometimes letting the kids make mistakes and learning from them is a much more valuable lesson than being grounded for those mistakes. My sons have done their share of stupids things, just like the rest of us when we were that age, but they learned from them and won't ever repeat them....
Glad to hear your son has listened and put to practice some of your tutelage...
Bigblue&Goldie
I look back at all the dumb things we did in high school in our Jeeps and thank God I'm still alive. A lot of things were fun, a lot were stupid, some I'm really ashamed of. I hope someday my girls can keep the stupid to a minimum, but I really have no ground to stand on if they dont.
Bigblockyeti
Upstate, SC
The difference between the LS and the newer LT engines will be the LT's have the ability to phase the cam continuously during the RPM range to maintain cylinder pressure whereas the LS engines with VVT will be in static position until around 3k RPM where they phase and shift the cam profile for more lift and duration.
How do they accomplish greater lift and duration? I was under the impression that the cam was simply advanced or retarded based on load, engine speed and throttle position.
