first time garaa....home owner
PurdueSD
Indiana
i didn't take any pictures of the house attic. what was already up there was very uneven. it varied from 6-14inches. i got it all leveled out and had it all about 18inches. i already noticed my furnace running less frequently. :)
edit - didnt use the full 2 pallets. think we took back like 16bails. think total ended up being ~$525 for the cellulose.
You didn't cover up you soffit vents with cellulose did you?
blitzdemon
holy haven't visited this site for a while. and didnt realize people were still following this.
Anything new done on the inside lately? Any new updates?
yeaaaaaa, about that....
when winter hits my projects usually get put on hold till spring. its suppose to be 40s most this next wk so i do intend to clean/organize so im ready to get back in the swing of things.
patiently waiting on my tax return to buy some toys :)
http://www.sears.com/shc/s/p_10153_...Compressors+&+Air+Tools&sName=Air+Compressors
no. all the ends got blocked off with leftover wall insulation. i put a bunch of Extruded Foam Rafter Vents (had to seach on lowes for their name) every so often on all the sides.
edit: picture references
http://www.icixsound.com/vb/icixnation/images/163_631.jpg
in this 1 theyre not much higher than the rafters...i pulled them up higher b4 we blew the cellulose.
http://www.icixsound.com/vb/icixnation/images/163_662.jpg
u can kinda see the batting blocking off the ends in this one.
Dan in Pasadena
Pasadena, CA
I don't know how I missed this thread before.
HUGE congrats on your home at your age. I was fortunate to do the same.
A couple comments on "trussing" your ceiling joists. When I did my overhead space on my last home (older like yours) I added joists like you did. Then to tie them to the rafters, I SLIGHTLY (< 1") jacked them up from below with my floor jack and a long 2x4 and used plumber's tape (you know that that is? Sheet metal tape with holes in it) and self drilling caphead screws. I attached the tape to the rafter with a couple screws, wound it under the joist and back up to the rafter again. I did this at 1/3's on each new joist I had added. The "lift" only served to straighten the plumbers tape and mildly preload the joist so its weight carrying capacity was increased. I only stored very light weight things up there and out toward the walls around the perimeter. Things like Christmas/seasonal decorations (what am I saying,...you're not married!), ice chests and camping equipment. Saved a TON of space in the garage.
What are your plans for finishing the interior? Paint? Color scheme? Your floor probably has no vapor barrier so epoxy may be out of the question but vinyl or ceramic tile like Jack Olsen's might work really well if you can swing it financially.
Best of luck, you're doing GREAT.
Motown 454
Nice job plumbing the walls up. When your done you'll have a great place to work. Keep the updates coming.
blitzdemon
ceiling and top half of walls will be white. bottom half light grey. and a blue strip in the middle.
the 2stall side isn't getting anything put on the floors. the other side will prolly have rubber tiles or something.
tomorrow (tues) i plan on starting to clean and then sand the osb to get ready for paint.
DavidTK
Great job! While I like reading about the guys with the uber-shops, I love threads like these because this type of garage is more typical for most of us.
