Above 1200 Sq/FT Garage Refurb®
SpeedinLemon
North Texas
Re: garage refurb
Looking good NUTTs....I hadn't stopped by in while. I think you'll like that cord reel on the ceiling. Out of the way, but always close by when needed. Looking forward to seeing your air line project complete...keep it up!
Chris
N
NUTTSGT
Northern Central Ohio
Re: garage refurb
Chris
Thank you, I've used it already and it was nice not having the ext cord on the floor. :rocker:
N
NUTTSGT
Re: garage refurb
I decided to move a sign out in the garage, possibly adding an entertainment value.
I took a picture the other day but never posted it, I gave the airlines a coat of orange paint. I posted a thread previously about airline color and got some ideas. One of the factories I used to work inhad the lines painted orange so I decided on orange.
As you can tell, the floor went from primer gray to a shade of orange.
N
NUTTSGT
Re: garage refurb
This morning, my first order of business was to mount the pipe clamp I bought at a swap meet to a piece of 2x6. Mounting it allowed me to clamp it to the worktable.
As I was working, I snapped this picture of the mess that I am creating.
N
NUTTSGT
Re: garage refurb
Some of the PVC airline I removed today. . . . . no going back.
A start on the new airline. I'm running it in a slightly different area, so I had to plan some changes.
The tee is where the compressor will be plumbed in. There will be more going under that tee. There will be a drop going out to the garage shed and a drain. I'm also going to plumb the tank drain to go out in to the garage shed, so the mess will lbe out there and not inside.
IONH
Central Massachusetts
Re: garage refurb
Looking good Eric.
A tip I picked up recently from someone with hard piped lines with a leak is to put a ball valve right at the compressor so you can shut off the system for service (or just because it leaks a little and don't feel like tracking it down).
N
NUTTSGT
Re: garage refurb
Looking good Eric.
That's the way I had it before and I will be doing it the same way. I like being able to pressurize the system when I want.
JC23
Northcoast
Re: garage refurb
There wuz nothing wrong with those PVC lines! Just ask the experts on GJ!
Looking good!
ConCretin
Central Maine
Re: garage refurb
Looking forward to the air line installation and diggin the orange paint. I've never been successful in getting a 100% leak free black pipe system. I always seem to get virtually undetectable leaks that only make themselves known when the air compressor kicks on. How are you sealing your joints?
N
NUTTSGT
Re: garage refurb
Looking good!
Although, I never had a serious problem with my airlines, I did have some issues with occasionally leaks at the joints. When I did them, I wasn't aware, honestly, I was ignorant about them but I realized their time was coming to an end. I don't think anybody can deny the ease of installation or modification to them though.
:beer:
N
NUTTSGT
Re: garage refurb
Never been successfull in 100% leak free ? Great, that's all I need. :beer:
I'm using some Oatey Great White joint compound.
JC23
Northcoast
Re: garage refurb
:beer:
Then good on ya for being proactive for yer safety!
Red05GT
ohio
Re: garage refurb
Nutts, you've given me the motivation to rip out my old CPVC lines and replumb with
black iron. Getting started is sometimes the hardest part. Pipe vise is definately a great
find and will help with the cutting and threading.
N
NUTTSGT
Re: garage refurb
Here it is. . . . all of it. Gone.
I made a trip to pick up a few things this morning, put together a few pieces while crawling through the attic. Then I went ahead and pulled it all out.
N
NUTTSGT
Re: garage refurb
If you were closer, I'd tell you to come borrow my pipe vise after I'm done. You're right, getting started is sometimes the hardest part. :beer:
Thanks.
Vernmotor
Mt.vernon oh
Re: garage refurb
Other one of them things that will make you sleep better at night.. I need to re plump My deal. I got hose's run all over !! I am close so I might ask to use that vise !! lol
N
NUTTSGT
Re: garage refurb
Not a problem.
Funny thing you mention hoses. Of all the days for my daughter to need air in one of her tires, I had to drag out the 50' hose from the compressor to her car in the driveway, along with a 25' section.
N
NUTTSGT
Re: garage refurb
I've been working little by little, learning as I go, as I am no plumber either. It's been a few trips up and down the ladder running airline through the attic. Once that section was down, it was back up and down making stand offs for the line as I have it running down hill for drainage (of any moisture).
This is where the airline will be plumbed from the compressor, I know, some what obivious. The bottom valve will be a drain shut off and the other valve will allow me to pressurize the system when I use it.
You might also notice the second tee. This is going to running out to the garage shed. It will allow me to use compressed air outside the garage with out having one of the front door or windows open. This basically how I used my framing and roof nailer outside.
This is the only drop I put on the "wood" side of the garage. It worked fine before with this arrangement so I felt there was no real reason to change drop placement while replumbing.
N
NUTTSGT
Re: garage refurb
Still plumbing away here, little by little. I bought most of what I needed but I knew there would be a few things here and there that I need. Today I realized that I need a 2 1/2" ****** for the blast cabinet drop, until I get that (tommorrow) I can't go any further. It always seems the little **** is what holds me up.
Here's where the airline comes across the ceiling and through the wall to the other side of the garage. Once I have it all done and no leaks, I'll go back and caulk/paint stuff.
Coming out the other side of the wall, it drops to a tee, one side down to a drop and the left to the perimeter of the garage. The 90° will come apart and thats where the needed ****** will go. There will be a drop with a dryer and regulator for hook up to the blast cabinet.
For the older guys with the poor eyesight, here's a close up. . . . .
TRWTOW
clio mi
Re: garage refurb
just spent the time to go thru 51 pages great job looks like a great place to spend time
one question do you ever sleep lol again job well done
N
NUTTSGT
Re: garage refurb
Yes, I sleep when I'm not out there or on GJ. ;)
I've tried to make it a place that is great to work on stuff, BS with friends or just relax. It's been a work in progress since we bought the house 12 years ago.
RandoH
Re: garage refurb
Eric, Im a newbie and garage looks awesome...
Im a wanna be firefighter down here in Columbus..
Keep up the great work
WHIPOLDS
MARYLAND
Re: garage refurb
Eric - Nice job ! I ripped out the pvc and replaced with black iron. I wish now I would have painted everything before install like you did. The fittings are rusting and I need to paint . The only thing that I do not like is when I drain the lines rusty water was coming out - I extended the line to get closer to the floor and use a bucket to catch it.
Rick
N
NUTTSGT
Re: garage refurb
Thanks and welcome to GJ.
Good luck on the goal of being a Columbus FF. If you're not a paramedic yet, I'd suggest you get that certification to improve your odds of being hired.
MPOWERD
Re: garage refurb
I read your entire thread (quite a feat for me, I usually dont have the time or patience for it!) and came away fully impressed by not only your skill with your hands, but also your skill with your mind in your designs. You remind me of my father when I was young on the farm. He was able to do anything and everything. You seem to have the same capabilities. Cant wait to see what you have going on next... Keep up the great work!
RandoH
Re: garage refurb
Eric, Thanks for the info. Im actually above their age requirements now ( im in my 30s) Ill be looking to volunteer or part time pretty much anywhere
Again thanks for the info and keep up the great work, places looks great
N
NUTTSGT
Re: garage refurb
Thank you I appreciate your comments and glad you enjoyed the thread. ;)
Sorry to hear older than the max age limits. Even though, getting a volunteer dept is a great goal to have.In that case, I'd suggest starting with a basic EMT certification. If that works out fine, maybe move up to a paramedic, which willtake some time for school. Gaining a EMT-B or EMT-P, possibly affords you the chance to work a side job on a private ambulance service. Good luck on your goal.
