Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
Re: Garage Refurb
About the last three weeks, I've had an issue with my woodburner. It would be fine at times and then would seem to lose it's draft. I'll be the first to admit, that after using it last year with the new chimney, I never got around to clean it. I wasn't worried too much since 95% of what I burn is standing dead wood. So it's been drying for a few years and I've not had an issue since we bought the place. This year, winter came on and stuck around, no nice days, snow that never melted and just a harsher winter than we have had for a long time.
I had wondered what was going on with the wood burner and when it lost it's draft, the garage would get from a light haze of smoke to not wanting to vent. This usually occurred when I had left to go to town and would come home to this. There was a few days that it would keep me out of the garage. I knew that I needed to fix the latch on the door of the woodburner. After 60 plus years of use, the cast iron latch had wore to the point, it didn't shut tightly. As long as the draft was pulling, it wasn't an issue. I was half afraid to weld it and have it crack, leaving the door useless. Between the issues, I needed to do something.
Saturday afternoon, I broke out the ladders and made my up to the chimney. Hoping to find something but nothing too bad. The thought of a broken chimney liner has crossed my mind and that would take tearing into the chimney to fix. As I took the cap off, I saw that it appeared to have a huge build up of creosote.
As it turned out, the paint had blistered and peeled away, leaving those bulges. I used my flash light and looked down inside. There was an area right above the thimble where it had completely closed shut and creosoted up. I knocked a hole through it, it appeared to only be about a 1/2-3/4" thick. Then I put the brush on the rods and cleaned the small amount that had built up on the walls of the liner. Since we had so many single digit days, and the chimney being outside (cold) it must have cooled as soon as it hit the cold air of the chimney. :dunno:
I moved inside after the chimeny was clean to work on the door. I used some MAPP gas to put some heat in the door before welding it. All I needed to do was build it up, it didn't need to be pretty.
This morning, I went out and cleaned it up enough for it to shut tight. I wanted to get a fire going as it was cold and windy today (out of the east). Once Spring hits, I'll clean the weld up more so it looks prettier(picture makes it look worse than it is) . Right now, it works and that's all that matters.
The chimney now drafts like it should and the door closes tight. I did get the column cleaned up for the drill press and it'll get reassembled this week. :D
sreno
Eastern Townships, Qc. Ca.
Re: Garage Refurb
Good job, Eric. Thanks for sharing!
If you want to cut down on the chimney buildup, make your fire as hot as you can for the first 30 minutes or so. When you get a nice deep bed of red hot coal, close 'er up and let it burn slow. The initial heat will prevent creosote from clinging.
I bet you already knew that, though. :)
Shawn
rixtrix1
Chandler, AZ (from west NE)
Re: Garage Refurb
Good thing you caught that plug when you did, Eric. Chimney fire or CO poisoning is not a good thing, for sure. It was 77 degrees and sunny as we watched the Air Force Thunderbirds today at Luke AFB.
PS: We have an Eric in our home, too!
Vieux
Russia
Re: Garage Refurb
You did a great job! With pleasure read and watched a very interesting. Subscribe to the topic, I'll follow on.
N
NUTTSGT
Re: Garage Refurb
Shawn
Since this woodburner is so old, probably from the '50s, no kidding, it doesn't get air tight. But it does get quite warm and will build some coals going. Generally I do what you have suggested, I think the really cold winter this year is what made the difference. Lesson learned, I'll pay more attention next time, but hopefully, we we want get such a long cold winter next time.
There were a few days I did get a slight headache working in the garage. I never paid much attention at the time. I realize now, it was from the CO. I had thought about running up to the firehouse and grabbing the CO meter but just put it off. :sad: I should have known better.
matta5
Central Texas
Re: Garage Refurb
I spied those handles last week when the wife and I were there. I was also checking out the old style door handles too. Cool but a little pricey.
They can be a little high but Hobby Lobby has different areas of the store 50% off every week, it comes and goes, I caught them at half off when I got mine.
rixtrix1
Re: Garage Refurb
^^^^^rixtrix1 ahhh so GI,u one lucky dawg.wives come and go,but children are forever and the wives take them (the children) with them and ur left with a Chevelle to keep u warm,then u have to sell the Chevelle,then,thats enuff keep her,and the Chevelle and create a life worth living,love is for all,if u can find it.:dunno:watch those fingers had a pard do the same with a fan and one with a pistol,finger no hurt anymore.but the hand does sometimes,best to ya
Thanks, Bogey Won. I plan on keeping everything forever!
N
NUTTSGT
Re: Garage Refurb
I didn't think about that but I usually print off a 40% off coupon of their site before we make the trip there. :beer:
N
NUTTSGT
Re: Garage Refurb
I spent a little time reassembling the drill press today. I put the column on the base plate, along with the table and new rack.
I want to add a light to the drill press as it goes back together. I checked out a buddy's DP today and where his light is. It's in the same place that I can mount mine.
N
NUTTSGT
Re: Garage Refurb
So I did want any good GJ member would do, start to figure out how to make one. I gathered som parts and I'm trying to come up with an idea. I thinkI have one and going to make a trip to the hardware store in the morning.
Funny thing was, I was looking at the owners manual to see if there were any part numbers listed for a light and found this on two different pages.
Notice on the left side, d. Do Not Use . . . . circle (fly) cutters then on the right side, Recommended Accessories . . . Circle Cutter
:headscrat
hazexban
Boonton, NJ
Re: Garage Refurb
You discovered a glitch in the Matrix neo...lol.
Very interested to see how you make the light work. Love this thread.
Tectron
Wantah In
Re: Garage Refurb
I have the same drill press and also want to install a light, at work we have a similar model with the light so I looked it up in the manual and its essentially a socket with an l bracket attached. here is the link to the diagram,
http://www.searspartsdirect.com/par...t&documentCompId=00001517&diagramPageId=00001
unfortunately the part is discontinued, but should be pretty easy to make one.
Ive been meaning to mention how impressed I am with your garage progress, I stumbled across your thread when I was Google searching blast cabinets and read through the entire thread over a period of days, I'm going to use some of your ideas in my garage. I've never given much thought about making the garage Cool, as well as functional. :thumbup:
I also noticed your from Bucyrus, My wife's family is from the Bucyrus/Galion/Crestline area.
N
NUTTSGT
Re: Garage Refurb
Thnaks for that link. Although the picture for that part isn't very good, following the link for the manual shows a better picture. I've been wondering what Cman drill press had a bulb. Now, I know and have a link to it.
Many thanks. :beer:
BTW, do you come back to area very often? If you come to the Brat Fest, stop by the fire house and say hi.
Tectron
Wantah In
Re: Garage Refurb
No Problem.
I usually only make it out during the holidays, unless I'm out that way for work. But if I do manage to be there during the Brat Fest, I'll be sure to stop by. :thumbup:
dlc63
Hanover, Ohio (east of Newark)
Re: garage refurb
You may want to patent this idea! Fantastic one!
Oops sorry, didn't realize my comment would post at the end of your thread.....lol.....duh.....I was referring to your dust collector for your table saw.
Since I'm here, I just joined yesterday looking for insulation ideas for my metal pole barn circa sometime in the 90's but anyway it brought me to your thread. I started on page 1 around 9 am yesterday and read most the day and most of today. I was so drawn in by how you are doing things and really appreciate all the photo's. Needless to say I haven't gotten much done around my house because I am trying to get caught up with your story. I am totally hooked.
I am a DIYer as much as possible and finding you has been a God send. I subscribed to this thread so I can refer back to it in the future as I am in the same boat as you as far as budget and doing things by myself.
Thank you so much for all that you have done and cared to share on here. It is priceless!
N
NUTTSGT
Re: garage refurb
awsome build only on page 8 will be back soon lol
Thank you gentlemen for the kind words and compliments. :beer:
dlc63
Re: garage refurb
Lol...I'm not a gentleman but that's ok, I don't think I've done anything with my profile on here yet!
I just spent 3 days reading all 81 pgs and looking forward to following your adventure.
Thanks again for all the sharing!
Diana
N
NUTTSGT
Re: Garage Refurb
Wow! Awesome transformation (house/garage)! How old is that TV :p
My old 27" JVC ? I bought that while stationed in Japan, after coming back from Desert Storm in '91. It had some sentimental value for that reason and I do kinda miss it, it died last year at age 22. :sad:
N
NUTTSGT
Re: Garage Refurb
I have to admit this project took way longer than I was expecting. What should have been a two day project has turned into a 2 week project.
A few days back, I strated trying to figure out how to wire the light for the drill press. I went through many ideas in my mind, bought a few pieces to make them work. Nothing seemed to come together till I was at a buddys shop and it hit me. There is a spot for the bulb in the casting, might as well make it work. Yet I wondered if the previous owner had been inside this thing.
I tore apart an old motion light and started to fab up a bulb holder mount.
It sits right inside and fits in the casted notches.
N
NUTTSGT
Re: Garage Refurb
I extended the wiring to allow making the connection easier.
Before I got to carried away, I figured I better start more assembly so I would know how to rung the wiring inside the casting. So as I tried to wind and adjust the quill return spring, my typical luck happened. I might add, Sears no longer sells replacemnt return springs.
Thanks to the help of a buddy, we heated (very carefully) a small section of the spring and got it rebent. I brought it home and started to get back to assembling the drill press. Once the motor was mounted, I added the pulleys and leveled them so the belt would ride nice.
N
NUTTSGT
Re: Garage Refurb
Then just a few other little things like riveting the cover on
. . . . screwing in a light bulb and flipping the switch.
I'd rather the bulb not hang down as far but that is where it ended up. I'm going to pick up a new bulb though. The guy at the electrical supply store said he has some that are coated so if they break, they will stay together.
and one more pic, just because.
N
NUTTSGT
Re: Garage Refurb
You done a fine job on that ! (thumbs up )
Looks good. Maybe a "flatter" faced bulb like a mini spotlight. Good work though.
Thank you gentlemen for the compliments. I do wish the bulb sat up in the hole a little more and have thought about a spotlight type bulb. I also have an appliance bulb too that is smaller that I can try.
N
NUTTSGT
Re: Garage Refurb
Light from the light bulb does not interfere? I myself made ​​a light like this ...
http://fotki.yandex.ru/users/vieux2008/view/690808/
I had originally intended to use something like that. The only issue was finding something, which I didn't want to take forever to look. Since I had to make a repair and decided at that time to do the refurb work, I wanted to get it done.
Where did you find that light or what did it come off of ?
mdbeck1
Norman, OK
Re: Garage Refurb
if you can't find a bulb that you like better you might make/find a shield for the bulb. I would think that you could take an old metal funnel or an aluminum cup of some kind.
gasgas17
Nova Scotia, Canada
Re: Garage Refurb
Nice Job on the refurbish! I just picked up this 17" for $150.00 It has the light built in on a separate switch above the main switch. The bulb is totally inside the casting. I'm sure you could mod the bracket to get it up inside the casting further if you turned the elbow 90 degrees on the socket and drilled the 1 inch hole in a piece of 1/8" plate and used a nut on the elbow. BTW the curved side of the table goes toward the post so you can turn the table 280 degrees with out hitting the post.
https://scontent-b-lga.**.fbcdn.net/hphotos-ash4/t1.0-9/1011626_10152708056188275_117513408_n.jpg
Vieux
Russia
Re: Garage Refurb
Flexible Hose took from cheap Chinese lamp, lampshade itself machined on a lathe. As a light source using LED car lamp from fog light.
N
NUTTSGT
Re: Garage Refurb
LOL, you're right about the table. I was putting it together and never paid attention.
Tectron posted a link to another Cman DP, a 15" I believe and it had the separate switch for the light, along with the other hardware. I was hoping but disappointed finding out that those parts are no longer available through Sears Parts Direct.
Now that I have it together and see how everything is set up, I believe it'll come back apart and I'm going to mod the light bracket by shortening it. Sometimes you have to get something together to see what it actually looks like before you can make adjustments. Hopefully, that'll only be a "one day" project. :spit:
luke7734
Crestline, Ohio
Re: Garage Refurb
Been on the **** shift these past few days? Haven't seen a new project or post lately?
I just brought me home a snow blower with an unhappy ******, and I found and old swing arm double fluorescent light I might convert over to l.e.d. If I can get the right bulbs.. ;)
Ps. Nice light upgrade on the press.. I need to do the same for mine.
Sent from my SCH-I605 using Tapatalk
N
NUTTSGT
Re: Garage Refurb
Good work as always, love the work on the drill press.
I'm going to rework the light on the drill press in the very near future, just too many things taking up time right now. It'll get moved up inside about an inch or so.
I have a few pictures to upload of the current project. We are remodeling the kitchen at the fire house. When I say "we" I mean us fireguys. Our station was remodelled back in '88-89 and the kitchen has seen better days. It's had 25 years of everyday use.
Currently, I am rehabbing the base counter unit for the sink. Once that is done, I'll be turning an upper cabinet into a lower corner cabinet. I'll post some pictures up later today.
N
NUTTSGT
Re: Garage Refurb
This is the base cabinet I started on last night.
Yes, it does look nasty, the old garbage disposal smelled liek *** water as one of the guys put it.
N
NUTTSGT
Re: Garage Refurb
I'm going to throw a couple of coats of varnish on the plywood here after lunch. It won't be anything fancy but it will work.
I added some extra bracing underneath to reinforce the toe kick. I know we are using some dura-ceramic on the floor and for the baseboard too. I'm not sure if a piece will get put onthe toe kicks too but I wanted to help give it some new life.
I also had a call and was told the plans for the upper cabinet to corner cabinet plans had changed, so no need to worry about them.
