Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
Re: Garage Refurb
I bought the K4 master system. Here is a link to the one that I bought at menard's.
http://www.menards.com/main/tools-hardware/fasteners/jigs/kreg-jig-k4-master-system/p-2043919.htm
I spent some time trying to sand the water marks out of the shelf and used some 400 and 600 grit paper. No luck. I was afraid to go much farther and get through the polycrylic and into the veneer of the plywood. Since the veneer is only like 1/32" thick, I talked to the wife about it. Needless to say, it's sitting in her office right now.
captain14
Re: Garage Refurb
I am sure she is happy with it and proud that you made it for her. The marks just become part of the history of the woodwork now. All the antique pieces you see all have their own marks and history behind them
Good looking piece and thanks for the link.
N
NUTTSGT
Re: Garage Refurb
Honestly, It'll probably get coffee spilled on it and dinged up.
It also already had one character mark on it already. If you notice the dark gray streak, apparently, the Maple tree had a nail in it when it was cut for veneer. There's a small hole in the streak, both top and the middle shelf the same.
jwh
Rochester NY
Re: Garage Refurb
Eric, finally got all 78 pages read. Great looking job!
From one firefighter to another, stay safe!
John in Rochester NY.
IONH
Central Massachusetts
Re: Garage Refurb
I got one of those for Christmas and just used it recently. Having a built in clamp to the jig has made life much easier. Before that I would use a cheap HF squeeze clamp and have to press pretty hard to keep it in place.
My wife's actually gotten really good at using the Kreg Jig and definitely likes the built in clamp more.
N
NUTTSGT
Re: Garage Refurb
I just used it again last night to make a frame for a access door. Talk about making a job alot easier. :thumbup:
IONH
Re: Garage Refurb
Absolutely. The only thing I need to perfect is to keep the board from sinching a hair away from the pocket side when the screw snugs down the last little bit.
N
NUTTSGT
Re: Garage Refurb
Eric,
Read this thing from start to finish. :bounce: Congrats on the success you have achieved, nice work! :thumbup:
Just read the whole thread. Really nice job. thats a really nice shop.
Thanks for the compliments guy, it's appreciated.
I guess it might be time for a little update, nothing major though. I'm sure somewhere I had mentioned buying this Cman drill press off CL awhile back. I ran into some issues with it and wanted to do some restoration on it anyways. I'll be posting a little of that too.
N
NUTTSGT
Re: Garage Refurb
I started a thread in the General Tool section so I won't rehash that but I will toss in a few pictures and the link.
You can see some of the rust on the handles, they were this way when I bought the unit.
I cleaned them up with a roloc disc, follwed by a gray scotchbrite and some polishing with Mother's.
Drilling out the shaft for a new roll pin.
Roll pin in.
Roll pin issue link
http://www.garagejournal.com/forum/showthread.php?t=238275
N
NUTTSGT
Re: Garage Refurb
When I lowerd the ceiling, I reused a few of the T12 lights. This was an ongoing issue, one side would all ways burn out not long after they had been replaced.
I bought aballast last night at HD thinking I could change them over to T8. Once I took the light down and apart, I realized they had no ballast but a small circuit board and a transformer on each end.
N
NUTTSGT
Re: Garage Refurb
I made a trip back to HD and returned the ballast. I picked up two more 2 bulb T8 strip lights. I had purchase the other two prior and was going to buy one at a time and replace a few other fixtures inthe garage.
To keep up with the other light fixtures that I have up, I cut and painted some pieces of OSB to act as stand-offs. They will be dry by Monday and I will start hanging the new fixtures.
N
NUTTSGT
Re: Garage Refurb
Lights up and ready to be wired, which I'm dreading.
Pulling some wire for a short run. Since I have the wire going through the insulation, I'm running it up through the lights so I don't have to look for it in the attic.
N
NUTTSGT
Re: Garage Refurb
Wired up and shining bright. These new lights do make a difference over the older T12s that I had.
This light has to sit offset from the rest due to the attic access.
N
NUTTSGT
Re: Garage Refurb
Now you might be wondering why I mentioned earlier that I was dreading the wiring portion of the project. It wasn't really the wiring, it was where it was at. If you remember, I lowered the ceiling and created an attic space, which isn't very big.
Where that junction is sitting is 14" between the rafters and ceiling joists. To the left when I had to fanagle my **** through to get to the other side and wire, is 18". I was none too worried about making the wiring neat as I normally do.
I also took a picture of the lower gray that I have been repainted little by little. I actually picked out a slightly lighter gray than I had before. The original paint I used was from Big Lots and was Battleship Gray and reflected almost no light.
ODIS
Re: Garage Refurb
Looking at all that pink insulation makes my neck start to itch.... The lighting looks like it will serve you well.
Nice addition to the already great shop.
Best,
Ody.
kald
Central Fl
Re: Garage Refurb
I haven't spent some time on the site in a while. Everything sure has come along nicely! I love the "budget" builds for lack of a better description like yours, Jack's etc......
N
NUTTSGT
Re: Garage Refurb
Thank you but mine doesn't come close to Jack's. :beer:
matta5
Central Texas
Re: Garage Refurb
I have really enjoyed your build, you do amazing work! I was looking at the pulls you put on your refab cabinets and figured I would show you some I picked up the other day, They have a few different styles at Hobby Lobby and can even get ones that look exactly like the door handles from 60's Mustangs!
N
NUTTSGT
Re: Garage Refurb
I spied those handles last week when the wife and I were there. I was also checking out the old style door handles too. Cool but a little pricey.
noelalford
Re: Garage Refurb
Slather on some baby powder before you fool with the insulation. it will help keep it out of your skin. You've done a great job on yer shop! And on chronicling it on here as well, that's not easy to do.
N
NUTTSGT
Re: Garage Refurb
Thanks for the compliment and the baby powder advice. ;)
N
NUTTSGT
Re: Garage Refurb
Can never have too much light. Looks good! :beer:
You're right, better to be able to switch off the extra not needed light than not have enough. :D
I worked on my drill press today, getting it apart for some cleaning and paint work.
Once I had stuff apart, I sanded and scuffed it, wiped it down and painted it. I'm using some Rustoleum Hammered silver. I've seen a few GJ'ers use it and their projects that came out looking nice.
Then sometime tomorrow, I'll get started on the column and base.
N
NUTTSGT
Re: Garage Refurb
Sorry for the lack of updates in the last few days guys, I've been at the fire dept longer than expected. I went to work Saturday morning thinking I was working my regular shift. Once I got there, I realized that I had to pay a guy back 12 hours on Monday of "trading time". After finding that out, I was up for a 24 hour OT spot on Sunday (short shift after a retirement) which left me at work from Sat at 0700 til Monday at 1900 (7pm) then right back in Tuesday for my regular 24 hour shift.
I didn't get this picture posted before I left home Friday. It's where I am at this point, everthing is painted.
I can clean the column and start reassembly later today.
Lazylaser
Pittsburgh
Re: Garage Refurb
Read all 79 pages, at work. (boss was off) I really enjoyed the Do it Yourself attitude, its just the motivation I needed!
Can you share some pictures of the tool that you use to put the tapcons up around the outside? Also I may have missed it but were the size tapcons you used?
N
NUTTSGT
Re: Garage Refurb
I believe the tapcons I used on the outside for the firring strips were 3/16"x 2 1/4". Putting them was nothing more than a Dewalt 18V hammer drill and then I used my 18V Dewalt impact driver with a hex bit.
Thank you for the compliments. :beer:
ODIS
Re: Garage Refurb
How much wood have you been through this winter to heat your garage? Work on the DP looks great!
Trust you have been well.
Ody.
rixtrix1
Chandler, AZ (from west NE)
Re: Garage Refurb
U can redo my DP when Ur finished with Urs,mine just needs a bit of paint.
I was laffn at the word fanagle,now there's a word,wonder if they use that word north of the Mason Dixon line?? or Fandango,prob more familiar to folks,finagle,mmm makes u wonder at 322am Tx time don't it,check out my derail post nuttsgt you started it and i couldn't got to sleep till almost 8am remembering couple of my derailments :lol_hitti
I don't know if Nebraska is considered north of the MD line, but I learned growing up that if you can't finagle on a farm, you ain't gonna make it!
N
NUTTSGT
Re: Garage Refurb
Ody.
More than normal. :lol_hitti
Seriously though, I have had more of a regular fire going the majority of the time rather than a small fire or letting it go out.
I still have plenty to last another month easily only because I cut back what I had cut. I had some left over from the previous year and wanted to get it used up so I didn't cut as much this past fall.
N
NUTTSGT
Re: Garage Refurb
fanagle or finagle, as long as you knew what I meant. :lol_hitti I remember trying to figure how to spell it a while back and did a Google search, my main form of spellcheck. I came across fanagle in the Urban Dictionary and thought good enough for who it's for. :beer:
crimegods
Re: Garage Refurb
wow man, this was really inspiring. in the past three days ive read every page. i feel like ive been along for the whole journey. i'm a relatively young and technically dumb man, 29 and engaged, just bought our first house. im not too tech savvy, but i have a detached garage and man if i don't feel like i should insulate it and make it look real nice this summer. i am inspired, thank you for your education and inspiration!
N
NUTTSGT
Re: Garage Refurb
Welcome to GJ crimegods. Thank you for the compliments. This place is full of knowledge and I have learned more from this site than I could ever share.
Enjoy your garage and learn in your garage before you try something in the home was my theory. Make sure to take plenty of pictures when you start work on it.
autonaut
Re: Garage Refurb
Great job is an understatement.. Really.
Looking like the perfect shop..
Will you be installing a lift of some sort when you get the time to fiddle with new or existing fox bodies?
I ask because it seems like you dont settle for half in any other place of the build, and because you seem to have the roof height required to do so as well.
/Autonaut
N
NUTTSGT
Re: Garage Refurb
No lift for me. While it might seem nice and big, the bay area of the garage is narrow. I think it's 21 or 22 feet. Small and I'd rather not two posts in the way of the small area.
rixtrix1
Re: Garage Refurb
fanagle or finagle, as long as you knew what I meant(Quote)
I had your thoughts down from the beginning. Funny how these words come and go through the ages. I've been enjoying your posts for some time now. Please continue sharing.
^ u lost any fingers on that farm yet?? (Quote)
Oh, and yes, I did lose a fingertip, but not on the farm and I did marry a farmer's daughter. General service person( i.e. oil change guy) started a car while I was working under the hood and I got my left hand out of the way except the fingertips. Doc was able to save all but the middle one. FWIW, I'm an ASE Master Auto Technician specializing in computer diagnostics and driveability. Wife isn't blonde, but Japanese and the light of my life!
autonaut
Re: Garage Refurb
Thank you for posting the thread. It's a good read.
