Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
Re: Garage Refurb
As always coming along great Eric. Can you provide more info on this j-pole antenna?
The only thing I know about them is what I learned from our fellow GJ members. I started this thread hoping many of them would chime in with information.
http://www.garagejournal.com/forum/showthread.php?t=294533
If you have a question, post it up in that thread and hopefully one of them will provide some of their vast knowledge.
xjjeepman
Upstate NY
N
NUTTSGT
Re: Garage Refurb
I got a little time in the garage this morning and got a couple of things done. Last week, I had my air hoses out and made a bracket to hang them on. They used to stay buried in a wooden box, under another box behind a few things. It was a PITA every time I needed them for a project and had to get them out. I decided to add a bracket to hang them on.
I welded this up out of some steel from another project. You can see in the previous project, I welded the sq tube together and had some holes drilled in it. It wasn't good for much else so I put it to new use.
I decided that behind the compressor was free space and no reason to waste that area. The next time I get into that box, I have a 100' extension cord that will be coming out and hung up also.
N
NUTTSGT
Re: Garage Refurb
It's a little hard to see through the glass due to the reflection but the new receiver and DVD/CD player are now mounted in their home.
I thought about buying a Blu-ray player instead of a DVD player but figured I'd cross that bridge when the path gets me there. The small Sony DVD was only $35, so it's not a big deal if I don't get much use out of it.
Strouty
Southern Maine
Re: Garage Refurb
Looks like the hose hanger is almost overloaded, you should have used 1" plate and 2" solid rod, then it would be secure forever. :D
The cabinet came out nice, it looks like a fire extinguisher case on it's side.
Bob Heine
Boca Raton, Florida
Re: Garage Refurb
I like your solution, mosly because it's not too expensive.
I had a couple of 50-foot hoses coiled in a tool chest drawer along with a few shorter ones and like you say it's a pain to get them out when you need them. My shed is about 100 feet from the garage (where the compressor is located) and I sometimes need air down there. Every time I took the hoses out they turned into a rats nest. I bought a hose reel (~$35 at Northern Tool) and a vise hitch mount (~$20 at HF) for the receiver on the side of my garage. I originally installed the receiver for a pneumatic paint shaker. When (not an "if") a paint can comes loose, I'd rather clean up the mess outside.
N
NUTTSGT
Re: Garage Refurb
Thanks but that 1" might be overkill for the 2x4 wall stud. You're right it does look like an extinguisher cabinet.
N
NUTTSGT
Re: Garage Refurb
Generally these hoses are for construction work and get hooked to the air nailer/framing nailer so they don't get out much.
Where did you get your paint shaker ? I'd love to have one.
Bob Heine
Boca Raton, Florida
N
NUTTSGT
n9lah
Re: Garage Refurb
My God, I finally reached the end after off and on reading for a week. Great thread and great rehab Eric. Lot's of good ideas I want to try and incorporate in my small 24 x 24 attached.
C_F
Utah...SNOW BLOWS!
Re: Garage Refurb
Whew, I finally caught up today! :)
I love how the attached garage ceiling turned out. One of these days, when (if) I have a garage I just park cars in, I'm definitely doing that.
rixtrix1
Chandler, AZ (from west NE)
Re: Garage Refurb
So Bob you are not a fan of Jackson Pollock?
Great reply!
Sent from my SCH-I435 using Tapatalk
Bob Heine
Boca Raton, Florida
Re: Garage Refurb
Strouty, sorry I missed your comment. I think Pollack's style of work should be confined to canvases in a studio. I often fail to close tool chest drawers so they collect dust and dirt. Can't imagine cleaning paint out of a drawer full of sockets, screwdrivers or pliers.
I've been out of touch since "Upgrading" to Windows 10. Screen goes blank, recovers and ten seconds later goes blank again. Twenty or thirty cycles of this and the system shuts down. Using an old laptop but it has a weird keyboard....:shocking::headscrat:confused::wtf:
N
NUTTSGT
Re: Garage Refurb
Thanks for the compliments gentlemen and glad you enjoyed the read.
N
NUTTSGT
Re: Garage Refurb
I made a little update to my airline inthe garage. I accessed my airline for outdoor work via a air hose shoved through the shed wall. Somewhere there is a picture showing this with a outdoor electrical cover covering up the hole. A while back I changed things up and the other day started to plumb a new branch line off the system.
I went out through the wall into the shed. I caulked around the hole after testing for leaks.
Coming through the wall with a 90 and a downward angle towards the drain I ended with a quick connect.
Now, I no longer have to crawl around/behind/under some stuff to attach an airline.
drivesitfar
Re: Garage Refurb
NUTTS: was there a possibility that you could put the compressor outside your garage in that area you just piped to? it might be quieter or is it too hard to turn it on and get it there? or maybe you said and i didn't go back enough pages to see where you did?
nice work on the piping.
N
NUTTSGT
Re: Garage Refurb
Possibly but the shed is small, about 5x9. Once the log splitter is parked in it, it's quite full as I have recemtly added a power washer to the clan.
drivesitfar
Re: Garage Refurb
Nutts: if there is a way to put the compressor out in the shed and turn it on from inside the garage the log splitter or other thing you might have to move inside your shop might be a lot quieter.
your choice and just saying because i'm half deaf from using power tools without ear protection and I didn't have a big noisy compressor to work around all these years.
IONH
Central Massachusetts
Re: Garage Refurb
Plus, being in Ohio, if the shed is not heated, you could run into lubrication troubles in the coldest of winter.
N
NUTTSGT
Re: Garage Refurb
Nah, the log splitter is staying the shed. It spent a few years in the house garage and 75% of the reason to build the shed was to get the splitter out of the way until needed, right now, it's at my step-brother's place.
My air compressor is loud, an oil-free unit, but being in the back room helps with the noise reduction. I have thought of making a "quieting door" out of some peg board or slats to reduce it a bit more. That might be a Winter project though.
drivesitfar
Re: Garage Refurb
Nutts: i suppose ear plugs are an easy fix, but i think i remember you hooking up some music to play in the shop. whatever you decide i'm sure it will be fine and just thought i'd throw out an idea.
hope you had a great weekend.
captain14
Re: Garage Refurb
How long are you going to let it sit On the floor like that? Won't moisture weep up into the bottom bags?
Sidewalk? Too blurry on the phone. I can see a different bag on top for a skim ( or whatever it's called) called?
N
NUTTSGT
Re: Garage Refurb
No on the sidewalk. Our house being a 100 years old, basically has a cellar in the front of the house and crawl space in the back. The floor is not much more than dirt and low head space. I started many years ago to dig it out, lowering it in the process. It seems that every time I try to get started on it, something else comes up and throws me a curve.
The different bag on top is portland cement. I have a 32oz gatorade bottle that I have cut off where it starts to neck up. I put 2 scoops of Portland cement in with every 80 lb bag of Quikrete when I mix it.
Vieux
Russia
Re: Garage Refurb
Judging by the bags of cement that we're both in the same work. I started doing garage floor :)
I have a question - how to say in English what I have marked with a red arrow?
N
NUTTSGT
Re: Garage Refurb
Generic name ? Air reel, retractable hose reel, or just about anything.
Brand name ? It's a Flexzilla brand and they call it a Zilla Reel.
Since you're in Russia, I'm not sure what you have for television show but if you have ever seen the old Japanese Godzilla movies, I'd guess this is where they took their "zilla" name from.
Vieux
Russia
Re: Garage Refurb
NUTTSGT motofool33
Thank you! I was wondering what the name of this mechanism. The answer was simple - hose reel. I want to do the same yourself.
motofool33
Currently North of Houston
Re: Garage Refurb
NUTTSGT motofool33
There's two kinds spring retractable, or manual with handle.
Brands that are long lasting cox reels, and reelcraft. I just got 4 used reelcraft.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Zeke
Re: Garage Refurb
I seem to have better luck doing that and it generally comes out looking better.
Sack crete is not rich enough. They short the ratio of cement to aggregate. Good enough for most projects but if you want to trowel it to a real nice finish you need more cement. You can get the same effect by sprinkling dry cement on the freshly placed concrete and floating it into the surface. But for a stronger mix and the advantage of a better finish, just add it to the mix.
N
NUTTSGT
Re: Garage Refurb
Thanks for throwing in some experience Zeke, It's always appreciated. I do know that when I first started using Quikrete, (brand preference over Sacrete brand and locally more available) it always seemed to have a gritty finish and not much cream on the top. When I did larger projects, if I was hand mixing rather than getting a redi-mix truck, I'd rather mix my own formula, 1:cement, 2: agragrate, 2: sand. I did all the sidewalks like this and they have held up well over the last 7 years including some very cold winters.
Since I'm doing small batches and HD had 80 lb bags on sale, it's a bit easier for me to use pre-mix Quikrete doctored up rather have a pile of stone and sand sitting around too.
