Above 1200 Sq/FT Garage Refurb®
jbmatth
Northern Ok.
Re: Garage Refurb
Rather than white Teflon (PTFE) tape you could try the yellow tape for gas line, it is double the thickness of the white tape and is less likely to fray than the white tape thus reducing the likelihood of strands getting into the liquid or gas stream in the pipe. Also when using the pipe dope on a joint that may have to come apart in the future you are setting yourself up for having to spend a lot of time cleaning out the threads. I've always done tape at home as it is just cleaner to work with and haven't had any problems. Now when I start my air line instal I may change my ways as I'll be using lots of unions.
JB
drivesitfar
Re: Garage Refurb
Nutts: i'm pretty good at plumbing when i'm doing a project that is more than a couple minute or half hour job. since i don't do it often just finding the tools and remembering what i probably almost or did forget is the issue. of course the trips to the hardware store to get parts 3 times during a small job is the pain.
once you get used to the teflon tape it's pretty nice to work with or a little jar of plumber's putty with a little brush might last for years and just have a wet rag handy.
hope the speakers work and you get to crank some tunes in the shop. i'm still playing VHS taped movies in my shop, but it makes time pass ok.
cheers and have a great day
N
NUTTSGT
Northern Central Ohio
Re: Garage Refurb
JB
Thanks for the advice. Hopefully the airline is done for me and it doesn't have to come back aprt any time in the near future.
Unfortunately, I got sidetracked and didn't get any garage time. Unless something drastic happens, the speakers should be in use tomorrow.
:beer:
N
NUTTSGT
Re: Garage Refurb
Well a few days later due to my issue of not figuring up the correct length of speaker wire, I finally got the speakers wired up. I honestly though I bought a spool of shortened speaker wire. I took the section I already had put up completely and pulled it down. I measured it along with the leftover piece and it was 100' long. Some how, some where I screwed up my math or measuring and felt like a *******.
Right speaker
Left speaker
Hopefully when I go out to the garage tomorrow, they are in the same place.
Strouty
Southern Maine
Re: Garage Refurb
The mounts look great, as for the wire it ***** when you have a brain fart, but we all do it.
Instead of teflon tape I use rector seal, it works well and you do not have to worry about what way you put it on.
N
NUTTSGT
Re: Garage Refurb
LOL, I'm not sure where the talk of teflon tape came from, maybe when I was doing my airlines 2 years ago. :dunno:
Thanks for all the advice.
:beer:
BBChevro
Brisbane, Qld., Australia
Re: Garage Refurb
The golden rule (measure twice, cut once) is something that we all forget sometimes Eric - which is one of the reasons why I prefer building with steel (have you ever tried to inconspicuously make a 3x2 longer??? :lol:).
The speakers look good up there. :thumbup:
drivesitfar
Re: Garage Refurb
Nutts: so the stands work ok. right? do you still need to buy and re wire them to crank some tunes or did you say they work?
hope you had a great weekend.
N
NUTTSGT
Re: Garage Refurb
LOL, I have a buddy that thinks the same way. He leaves the wood building stuff to me and says he can always weld another piece steel in if he makes something too short. :lol:
Even after measuring it, it still doesn't seem like a run that is 69 feet long. :dunno: the tape measure doesn't lie
N
NUTTSGT
Re: Garage Refurb
I bought another roll of wire and the project is done. They work and are still up there this morning when I started a fire in the woodburner. :thumbup:
drivesitfar
Re: Garage Refurb
Nutts: gotta love when another item off the TO DO list is completed. now you can rock on while playing and working in the garage. congrats.
you also have some extra wire to hook up a couple more speakers if you find some more in your travels and want to. :D
N
NUTTSGT
Re: Garage Refurb
I have two on the other side but they are just cheaper book shelf speakers. I'll keep my eyes open for something, garage sale, auction, Best Buy open box for some replacements.
N
NUTTSGT
Re: Garage Refurb
I started yesterday with breaking out the older Lincoln arc welder I got from family that had passed away. Little did I realize or just a lack of memory, recall that it needed a 50 amp circuit. After digging around inteh garage, I found wire, a new plug and receptacle. I was missing the breaker so I picked one up last night. Once I came in, I realized an error I had made and along with some advice of some great GJ members, the problem was resolved this morning after a trip to towm.
New 50 amp breaker for the circuit, which required a trip to Menard's and side trip to Starbucks for a coffee for the wife. . . . 2 slices of lemon pound cake for me.
I mounted it below the breaker box. I can reach where I normally weld and outside if need be.
EDIT: Thanks to posting a picture and advice from Wylie over in the electrical section. He pointed out that the receptacle I put in is wrong. It was something I had along with a plug and thought it was for this project but I might be wrong. The receptacle shown is a 10-50 but what I need is a 6-50R (like the outlet on the right) and corresponding plug for the welder. I will be getting the correct parts and swapping them out this weekend.
Macguykc
Berlin Center, Ohio
Re: Garage Refurb
It's taken me almost a week but I've finally finished all 100 pages. It's quite impressive how you were able to transform the old shop into what it is today. I think you're being more than a little modest calling yourself a hack with a hammer though. Thanks for a great read and a ton of useful information.
JC23
Northcoast
Re: Garage Refurb
I have one location for the welder/cutter plug. But I also have an extension cord for the 220 line. It will reach anywhere in the shop and pretty far outside the door.
The trick is to not make it too long.
N
NUTTSGT
Re: Garage Refurb
Thank you, I'm glad you enjoyed it.
I already had a spot to plug in the wire feed but that only required a 20 amp breaker. It wouldn't have been enough for the Lincoln arc welder so I had to put in another outlet. I do have an extension cord for the Hobart but not one for the Lincoln. I'll cross that bridge if and when the the time comes.
:beer:
Strouty
Southern Maine
Re: Garage Refurb
Keep an eye out on cragslist, you may be able to find a large SO cord, that is what I use for my extension cord.
N
NUTTSGT
Re: Garage Refurb
There's a recycling place about 15 minutes from here I need to get back to and check out. It's where I bought the cord for my Hobart and a buddy bought an 8/3 cord for his welder there.
http://www.ctr-surplus.com/
Honestly around here I doubt there is much on CL, most of that stuff goes right to the scrap yard due to the thieving drug addicts. I can check out the scrap yards too.
captain14
Re: Garage Refurb
I know you metioned earlier in the thread the entire garage project is funded by OT, but does that funding pay for the lemon pound cake? If is fuel for the working man.
N
NUTTSGT
Re: Garage Refurb
Actually, the wife paid for the trip to Starbucks. I paid for the BK we had on the way there. I didn't finish the last third of my chicken sandwich as I found a hair. Appetite gone at that point but came back a short time later.
I'm not a coffee drinker but Starbucks Lemon Pound cake is some seriously good stuff. If you've never had it, I would recommend trying a slice.
N
NUTTSGT
Re: Garage Refurb
A small update for today. As mentioned in a previous post, I needed to swap out a receptacle for the welder. That has been today along with the correct plug for the welder. I appreciate thet help and advise from the guys over in the Electrical section, they have been awesome in the past few days of my relentless idiot moments.
Strouty
Southern Maine
Re: Garage Refurb
I couldn't resist, the real funny part is that is how I always do it, otherwise the cord goes up the wall. It drove me nuts at my Dad's shop, all of mine are upside down.
nine4gmc
Dallas
Re: Garage Refurb
Or that little,depending how you look at it. A cup of coffee cost more, literally and physically(health). At least with a lottery ticket you have a chance to win something.
Sent from my SM-T230NU using Tapatalk
slackgt
Boyertown,PA
Re: Garage Refurb
a Marine that doesn't drink coffee,oh the horror of it all ! lol, my youngest is going on his 3rd year and doesn't drink coffee either,but the Stumps made me a coffee drinker for life,Semper Fi brother.
N
NUTTSGT
Re: Garage Refurb
Still not a coffee drinker but Stumps did make me start drinking. :drink:
