Above 1200 Sq/FT Garage Refurb®
mike528
Shelby county Ohio
Re: Garage Refurb
Only took about a week to get though it all. Lots of useful stuff on here I'm going to be trying. Inspiring me to get some more progress made on mine and pics of said progress. Will have to start my own thread here soon
N
NUTTSGT
Northern Central Ohio
Re: Garage Refurb
Just seeing that stack of quikrete bags makes my back ache!
JB
Hasn't been that bad. I took a break and cut fire wood for a week to heat the garage for the winter.
Be sure to take plenty of pictures, every day take a few and post them up. While it might get to be a PITA, it'll become motivation to keep working on it and become a scrap book for you to go back to later.
:beer:
vonhef
Southern, Ok
Re: Garage Refurb
Nutt, It is great to read through your timeline and see the evolution of your shop through that past 5 years. You have put a lot of effort into this build and the attention to detail is inspirational. I appreciate even the details of minor upgrades such as your airline additions and such.
Great work and thanks for sharing.
Slycox
North Dakota
Re: Garage Refurb
Holy hell I reached the end. Impressive what you have done. I hope to one day be able to match half of your talents. Some amazing Ideas and I will be rereading when I own a garage and "stealing" some Ideas.
STINEY
Bucyrus Ohio
Re: Garage Refurb
The floor is not much more than dirt and low head space. I started many years ago to dig it out, lowering it in the process. It seems that every time I try to get started on it, something else comes up and throws me a curve.
Now that scenario sure sounds familiar. Finally got back on doing the other 1/2 of my basement.........so close to pouring and calling it done....
Huge job. Good luck with your dig!
GDPossehl
Atlanta, GA
Re: Garage Refurb
http://i6.photobucket.com/albums/y216/dv869/GEOTHERMAL/basement_zpsvttocfq1.jpg
http://i6.photobucket.com/albums/y216/dv869/GEOTHERMAL/FLOOR3_zps7pfta18v.jpg
http://i6.photobucket.com/albums/y216/dv869/GEOTHERMAL/FLOOR2_zpsg3mn2cf9.jpg
Wow, that's quite the endeavor. Any idea what a job like that would cost?
If I had dirt floors in my crawl space I'd be tempted to start digging tonight.
We have a poured concrete crawl space with ~4ft of height. I'm not sure why the original owners didn't have it dug at least 2 more feet as it was a custom home in 1971. Many other homes in the neighborhood have full basements--both neighbors included.
drivesitfar
Re: Garage Refurb
Nutts: i've hand mixed plenty of those 85 pound bags and never thought to add more cement if i wanted a smoother surface. i've always been using my cement for sidewalks and patios where i wanted it a little gritty for good footing.
Zeke: thanks for the 411
Stiney: amazing job on that basement. any chance you might be able to go in your Garage Journal profile and put a link to the build thread if you did or want to do one because i for one would like to see more pictures. good luck
N
NUTTSGT
Re: Garage Refurb
Thank you for the compliments gentlemen, I'm glad you enjoyed the thread. Feel free to steal whatever ideas you want. It has been a learning process for me also.
N
NUTTSGT
Re: Garage Refurb
[IMG]http://i6.photobucket.com/albums/y216/dv869/GEOTHERMAL/FLOOR2_zpsg3mn2cf9.jpg[/QUOTE]
You've put some serious effort into your place and it shows. I wish our cellar was that big. Did you have a way to enter/exit your basement from the outside or did you have to go back up the stairs through the house ?
[COLOR="Red"]STINEY'S PICS ATTACHED BELOW.[/COLOR]
GDPossehl
Atlanta, GA
Re: Garage Refurb
Haha, Andy Dufresne style! In his pockets so the warden doesn't know what he's up to.
N
NUTTSGT
Re: Garage Refurb
Haven't been doing much or really anything to update with, so it's been awhile.
I did mount a 24" strip light under the cabinets. When I put it in, I decided to add an outlet also when I have my laptop sitting on the bench also. My original design of just an outlet at each end of the bench hasn't worked out so well. In this pic, you can see the switch and outlet I added.
What you also see is the lighted magnifying glass sitting on the bench. I've been wantin gto move it but couldn't come up with an idea or place until this morning.
N
NUTTSGT
Re: Garage Refurb
The lamp sits in a base and easily pulls out. I thought about a shelf but then lamp arm won't swing where it needs to be. Then the light bulb came on in my little brain. All I need is a piece of round tubing to make a bracket to hold the arm, no base needed.
First step up was to measure the arm mount and found that it was just under a 1/2". I had no tubing that size so I made a trip to town. I figured tubing that size should be easy to find. Wrong, TSC;no, Family Farm & Home;no, True Value;no. I considered using a piece of 3/8 black pipe but a 1/2" bolt would quite fit in it. So I didn't know if it would work.
Last stop Fastenal, they had no tubing and he asked about a pipe ******. I told him I considered that and if he had a set of calipers to measure the I.D., it might work. Lo and behold, it was pretty much spot on.
nine4gmc
Dallas
Re: Garage Refurb
Posting to catch up on later, love the light I saw it in the other thread!
Sent from my iThingy using Tapatalk
N
NUTTSGT
Re: Garage Refurb
I dug through the scrap tote and found a piece of sq tubing and angle. A little cutting, grinding and welding and a test fit. I used a couple of lags instead of screws figuring they would be stronger.
Once I knew it would work, I ground off the corners of the angle and toss some rattle can black at it. While that was drying, I drilled through the arm mount for a cotter pin. While it probably doesn't need it, I figured it would be for insurance. If I didn't do it, one of the times I pushed it up and around, it would come out of the bracket. I also put a dab of grease on it so it spins a little bit easier.
captain14
Re: Garage Refurb
I have seen some of those lights with a clamp for mounting to workbench ends, etc. good engineering but it's a shame for making 4 stops to fight the right fitting.
Did you get anything else why you were out or was that thinking time for a new project?
STINEY
Bucyrus Ohio
Re: Garage Refurb
Thanks Eric. Your place is a far cry from what it started out as too, nicely done.
No, didn't have to ferry dirt through the house, thankfully. I have to admit it took so long I felt like poor old Andy Dufresne though.
We had 2 separate outside entries, so on the 1st half I dug out I used the one on that side. Then we bricked it up and filled in the outside part (it was the one with lower headroom anyways)
The second entry is in the far left corner in the earlier picture I posted. We had Kousma out of Willard spray foam insulate the foundation sill area and the basement entry. Made a substantial difference. I really wasn't expecting to be able to tell the difference, was pleasantly surprised.
I don't have a link specifically on the basement dig, but there are lots of pictures of it in an indirect way on my geothermal install thread on Bangshift.com - link here http://www.bangshift.com/forum/foru...quit-fooling-with-houses-and-get-back-to-cars
N
NUTTSGT
Re: Garage Refurb
Instead of a cotter pin what about hitch pin. I think that's what they're called
I think a hitch pin would have been too big. I have a cotter pin asst, so if I have to replace it every now and then, no big deal.
I didn't get anything else. Sometimes when I get in the mood and find a project to do, that's my sole intent and nothing else matters. I guess when I think about something and try to work an idea in my mind for a period of time and it comes to me, it's time to get it done.
N
NUTTSGT
Re: Garage Refurb
Great idea mounting the lamp! :thumbup:
Nice mod for the lamp!
Thank you gentlemen for the compliments.
I think that is who did the neighbor's spray foam also. I'll check out link too.
N
NUTTSGT
Re: Garage Refurb
I guess it's time for a bit of an update, mostly to clear up some floor space. I've had these Sansui speakers for several years. They belonged to my step-dad and he got them when he was in the Navy in Holy Lochs, Scotland, 40 plus years ago.
They are going to replace these little speakers but I'll need a larger bracket to hold them up there.
N
NUTTSGT
Re: Garage Refurb
I picked up some steel a few weeks ago but kept getting side tracked then the holidays rolled around.
I started with cutting some angle for the frame of the shelf. Unfortunately, I had over stoked the wood burner up when I came back out this after noon. Between it being too hot and the UFC fight starting shortly, I decided to call it a night as I did get a few other things done too. I was going to lay the speakers on their side but I decided to stand them up.
big_dan
Tennessee
Re: Garage Refurb
Been following this thread a while - like what you're doing. My dad and myself have both been through Holy Loch during our Navy days - was your dad a submariner?
Enjoying the transformation from the start till now. Keep it up!
Dan
N
NUTTSGT
Re: Garage Refurb
Dan
No, he wasn't a Submariner but he did work onthe dry docks, as an electrician I think.
N
NUTTSGT
Re: Garage Refurb
Got the brackets all welded up last night
Wiped them down and hit them with some black spray paint. They're upside down drying.
N
NUTTSGT
Re: Garage Refurb
While the paint was drying, I removed the old corner shelves and started to check for studs to run the lag screws into.
After I drilled on hole, I tried to probe it to make sure there was a stud behind the OSB. I hit something soft, almost rubber like or plastic. I was afraid I hit some wiring, so I cut open teh wall to make sure. Fortunately it was just an old 1x6 behind the osb. I patched the area and brushed on some white paint.
Something you can tell is that is area is above the wood burner so it does get hit with some smoke. There's been a few times the wood burner has lost it's draft and smolders filling the garage up with smoke. That's one of the bad side of having an old wood burner. For what I can heat the place for during the winter using wood, I'll take the dust/smoke from the wood burner. My plan is by next season, have a new wood burner in place.
N
NUTTSGT
Re: Garage Refurb
I lagged the brackets in place. I hung from one to test it's strength.
Fabbed up this little gig to pull new speaker wire with....
and started to pull some wire.
dlcwent
Member Emeritus
coastal maine
Re: Garage Refurb
I still think we need a "like" button on the GJ. But then again, it might keep people from actually making a post. Nice "quick" wire pulling gig. Looks like the new shelves are more than adequate to support the larger speakers with no problem.
drivesitfar
Re: Garage Refurb
Nutts: well done. did you test the old speakers before deciding to do this? i'm betting you did or maybe i skimmed over where you said so. looks like the shelves are built to hold a big vise and if they held you that says it all.
also agree with DLC that was a cool idea for pulling speaker wire.
Have a great 2016
N
NUTTSGT
Re: Garage Refurb
I was goping to try to take a picture of myself hanging fromteh shelf but my arms aren't long enough. I'm not sure the wife would take a picture of me hanging. . . . Sometimes she still doesn't understand me. :D
Have a great 2016
I've used the speakers before in my old bedroom at my parents house. Trust me, they work. :D
I wanted to make sure the shelves are built well. If that one fails in the picture above, the speaker will fall on to the drill press, then onto the Mustang. :sad:
Techie1961
Pickering Ontario Canada
Re: Garage Refurb
That's a great shop that you have there. Not too far away is an old garage that is sitting on a rural corner and every time I drive by it, I want it to be mine. There's just something about those old auto garages and yours is coming along very well. Your house and porch are beautiful too.
I don't think you should be so hard on Teflon tape though. It always works well for me and I do a lot of work with it.:bounce:
drivesitfar
Re: Garage Refurb
Nutts: my Dad wasn't fond of my music either. I think one night i fell asleep with Iron Butterfly's In a God a divida (sp?) playing and he wasn't happy when he came in my room to turn it off. i'm guessing by your remarks your music might have been a bit loud or a tune your Dad wasn't fond of or both.
i can't remember my kid's music ever bothering me maybe because i wouldn't let them play that RAP ****. :D
how's the weather this winter after that wet summer you had?
BBChevro
Brisbane, Qld., Australia
Re: Garage Refurb
I still think we need a "like" button on the GJ. But then again...
I've often thought the same thing - particularly if your keyboard skills are as slow as mine. :lol:
I love the look of those speakers Eric - I have some very similar looking ones (but mine are Radio Shack).
Great work. :thumbup:
N
NUTTSGT
Re: Garage Refurb
It just seems that teflon tape and I just don't get along. I usually roll it on the wrong way so it comes off as I'm threading the fittings together. Between that and it getting into a carb when I used it on fuel line, I try to steer clear of it.
Thanks and I have slow keyboard skills also. :lol:
N
NUTTSGT
Re: Garage Refurb
I never cranked the music while my parents were home but I know they will work in my garage. ;)
We finally had some snow stick but it was just a dusting. The temps finally dropped into the teens for a couple of nights. So far,we still have plenty of fuel oil for the furnace. Usually in January, we are getting our tank topped off with 150 gallons or so and I have used a bunch of fire wood heating the garage. Unless Winter continues into late Spring, we should be ahead of the game.
Techie1961
Re: Garage Refurb
Next time I'm in Ohio, I'll drop by with some beers and give you some pointers on using it. :beer: Little tip though, never let it get on the first complete thread and you'll be alright.:thumbup: There's more to it than that obviously like the correct direction but that is one thing I always have to show people.
