Garage Step/Stair Ideas
D45
NW INDIANA
I am removing the two step stairs going into my garage this week, so the garage floor concrete can be resurfaced with a flake epoxy finish
I have to paint the stairs every year, so I will likely not be building new stairs with a mmaterial that will need any maintenance
Plus, the old wood is spongy in spots and some areas the partical board (yep, old) is falling apart
Is it easy and possible to have a step level with the bottom door threshold and then take a step down? Almost like a platform step?
I think that I also want to build these stronger, with 3 stringers instead of 2 that are currently used
Any tips, tricks or suggestions what I could do here?
larry4406
Northern Virginia
I did a house with concrete steps in the garage for a customer. Broom finish for all surfaces. Customer loves it.
I plan to replace my similar garage stair with concrete this summer when I install my Race Deck floor.
Yes you can place a platform (landing) in the stair, it will need to be 3'x3'. It could be flush with the bottom of the metal door sill, 1 rise down from the metal sill, etc (wherever you want it in the flight). Looks like you are stuck with a 3-rise stair (3R).
In new construction (at least in my region), the stair total rise is measured from the floor to the top of the door adjustable sill (not metal sill pan). Measure this and divide by your 3 risers to get your rise height.
The number of risers remains the same whether you have a landing or not. IRC Code today will limit you to a max of 7.75" rise height. Many areas (including mine) take exception to the IRC Code and allow a max rise of 8.25" and a minimum tread depth of 9". Old building Codes typically enforced the 8.25" max,
The number of treads is one less than the number of risers, in your case 2.
If your slab is pitched, this affects the total rise measurement. Treads are typically in the 10.5-11.5" depth range for comfort, so recheck your total rise measurement at around 22" out from the adjustable sill. If you add a landing (and have a pitched slab), this pushes your stair out even further thus increasing the total rise.
Adding a landing may push your total stair out enough that it encroaches on vehicles, so be mindful of this.
Youngandfree
VA
If you're cool with having the steps extend further into the space, go for it. I'm a fan of having stair risers as short as possible, and would try to add an additional one myself. I redid front porch steps and made risers minimum height and treads wider, and it's much more comfortable to go up and down.
larry4406
Northern Virginia
As the riser height gets smaller and smaller, it reaches a point where you feel like you are tripping. I don't like the feel of risers under 7". I do like deeper treads (11-12"). The Code minimum of 9" depth in my area is too small for my feet.
egdede
OP You can make a step at the same level as the threshold, just keep it at the same level as the floor in the house. As others noted, that will extend the steps into the garage. I would take Larry's suggestion and just make new steps with a little more run (depth). You don't even need a stringer. Build one platform for the base na then a second smaller platform for the top step. I used to have a link to a winding stair diagram that showed how to do this in a corner. The one below kinda =hinbts at what I;m saying. Much easier for you : )
Youngandfree
VA
My old dog and aging mother both appreciate the 6.5" rise. I replaced 8" rise. I know as I get older I will appreciate them even more.
billconner
Thousand Islands NYS
For myself, I prefer risers closer to 6" than 7" - 8 1/4" is code maximum in NY. And treads at least 12" - 9" is code minimum in NY. Research shows stumbles increase as the rise increases, but around 6 1/4" it starts to increase faster.
Visibility and handrails are probably more important.
D
D45
NW INDIANA
Stairs are out for the concrete coating company
D
D45
NW INDIANA
Looks like the aluminum threshold is about 22-7/16" high off the garage floor
larry4406
Northern Virginia
To be code compliant, you don't measure to the aluminum threshold.
You measure to the raised adjustable sill that is under the door slab. Typically this sill is about 1.5" above subfloor.
mike93lx
Richmond, VA
For small steps, I don't do stringers. I'd do it with boxes, stacked on top of each other. I can't find an In-construction Pic, but this is three rectangles, cut to the right riser height, all screwed together. It has bracing where needed and is wildly solid.
Not sure how much better it is, but it keeps the sides closed off and removes the complexity of cutting stringers
larry4406
Northern Virginia
The stacked box method also removes the complexity of trying to get the stair cut proper on the stringer. The few times I have tried this I always seem to be off by 1.5".
bdbecker
Iowa
For small steps, I don't do stringers. I'd do it with boxes, stacked on top of each other...
+1
Totally agree. While you end up using a little more wood, the increase in cost is typically not really an issue because it is a small project. The added benefit is that the box method gives you an overbuilt, very stout set of steps, which is perfect for a high traffic area like this.
D
D45
NW INDIANA
So other than the ground level "box", how do the other boxes sit/stand on the ground?
I'm assuming they are all then screwed together?
mike93lx
Richmond, VA
The sides and back line up and I use 2x4's on the inside to connect it all with screws
Walkers
Cave Creek Az
Are you telling him to put the top landing that he wants higher than the threshold?
Walkers
Cave Creek Az
Sure the top step would technically be a landing, but it doesn't need to be any bigger than a step. As far as height, within a quarter inch of the threshold height is fine. The door seal could be argued as a within 1/4" protrusion instead of tread height, but in all the stairs I have built it has never come into question, just my experience.
mike93lx
Richmond, VA
In the stairs I pictured, I used three deck boards for the top and had wished I used four. It's nice having some room to stand if you are opening a door while carrying something, but in the OP's case, the stairs are so short that it may not matter
larry4406
Northern Virginia
No.
If he installs a 3’x3’ landing at the top flush with bottom of the aluminum sill, then you can ignore the raised adjustable sill. Then the balance of the stair is calculated from the landing height. A true 3x3’ landing breaks your cadence so the riser heights can change and be unequal.
To count as a landing, it needs to be 3’x3’. Codes typically allow a maximum variance of 3/8” within the flight. Since the adjustable sill is typically 1.5” taller than the bottom of the sill, it’s out of bounds.
The OP is likely not getting this inspected so he is free to do as he pleases.
D
D45
NW INDIANA
I have around 30" - 32" in overall distance I would like the entire stairs to extend out to
A full 3' x 3' landing isn't an option
billconner
As long as door swings in, code (2021 IRC) does not require a landing. I think I'd do 3 treads as deep as possible, and divide total rise by 4 - so ~5 1/2" risers - so no step at threshold level. I think you could reach door knob from floor and not have to pause. 10 1/2" treads or so.
  • Like
Reactions: D45
gahrajmahal
Cincinnati, Ohio
D
D45
NW INDIANA
Those metal stringers are 41" high for a 3 step , won't work
The metal 2 step is 22.50" tall, also won't work
Fav Onefour
MN cold and hot
I've done box steps. Concrete is rarely perfectly flat.
My recommendation is a solid first box that you can shim to keep from rocking. That means you need a solid box. The framing will sit on shimmed locations vs. the entire box sitting on concrete.
Wood expands and contracts differently than the floor. I use a good flexible adhesive when I install the shims. That will prevent future rocking around and hold the shims in place.
  • Like
Reactions: D45
D
D45
NW INDIANA
Yes I have thought about and looked at composite boards
I built my 12x20 patio with Apex and it's held up nice
CTyankee
CT
I agree with others on the "box" method. It's only a couple of steps. FWIW, staple/stick some I&W to the bottom platform sitting on the concrete.
mike93lx
Richmond, VA
If doing composite and running stringers, I would add a 4th. It's easy to make another and will keep it feeling really solid. I like 12oc for composite
