Garage wall poured to high
steveo1o9
Eastern MD
Vinyl? Why.
Personally, I hate the stuff. Yea, I know it's a good inexpensive product....but at the end of the day....it still looks like vinyl....for a new house like that, I'm surprised you didn't go with LP Smartside or Hardi Cement board. Looks like real wood...but without the issues.
My house is stucco....except for the front. It 'used' to be 1x6 T&G boards across the front. Yanked it all off...insulated...cleaned up....redid the plumbing...modified some electrical and covered it with ledger stone and LP Smartside. I don't have a basement....but I'm on a raised foundation. I just painted the footing below the ledger stone a darker color.
Love the stone veneer, I have been thinking about eventually doing the same. My house has about 30" of exposed CMU foundation showing all the way around. Previous owners never did anything to coat or cover so it just bare CMU. How was the veneer cost? I saw prices varied widely in my brief searching. I have a total area of about 675 SF to cover ultimately.
EDIT: Yikes that would cost me about $7k looking at home depot prices. Guess I'll just parge and paint.
wrenchguy
NW Indiana
Thanks for the replies, maybe I'm just having a hard time seeing it.
imagine the grade brought up to 12" all around the foundation and garage floor fill being brought in to have "x" number steps into the house. ur tar line is low now but should be brought to 12" below sill plates. my foundation looked identical to yours when i built it 30 years ago. you always want a positive fall away from foundation for drainage.
BillK
Beautiful Southern Maryland
Like the others said.... it matches the house. What are you going to do with the house foundation that is exposed ?
Either way you can run the siding down all the way to the ground if thats what you want.
TommyK
CT
Forgot to add I'm not at finish grade yet. I need some fill. Set the house in December.
What would be the best way to attach vinyl siding down the concrete?
Furring strips attached with Tapcon screws.
Parrothead
Earth
A stone or brick veneer will really set that off and look fantastic. That will change the look entirely. Love it!
Bigbrew
I agree, I just don't want to do that down the 28' side and the 28' back. Vinyl would be cheaper. Even if i could bring it down 12-18". Ill get some better pictures this weekend.
ddawg16
S. California
Is that raw material price?
I think I paid about $600 for the stone veneer....about 450 sq ft
The stone caps were about $6 each...I think....
The special mortar was about $30/bg.
ddawg16
S. California
Lets see if the pics will post
Jlbc212
Northeast MA
^^^ this, except I would leave about 18" of exposed concrete. Slope the finished grading up the foundation wall so that water easily sheds away from the house and the garage.
tthornto
I would do the stone veneer on the front only that way you get the look you want where it's most visible and it would only use a small amount of stone because the garage doors make up the majority of that wall. The side and back I would just extend the siding down over the concrete so there is 12" or less of the foundation showing above final grade level.
rjeep1995
My foundation person poured my wall too high. I feel like it will look like my garage is hovering in the air. A little to late to have him cut it back down a bit. Can you guys share some ideas to eat up some of the space between the ground and the bottom of the garage. Was thinking of doing stone on the front. I want to bring vinyl siding down the concrete a little. Garage gets framed Monday. Any help would be appreciated.
Can't upload pictures, security token error message.
Could always do a little bit of wainscoting around the base
Sent from my SM-N950U using Tapatalk
Tejay
Do some features on the house and complementary on the garage and once your done final grade and landscaping it will be just fine. I like it being out of the ground-solves a bunch of rain water/ snow issues , drainage . Once your wife is done with flower beds,shrubs etc it will all disappear. Thank your contractor
steveo1o9
Eastern MD
Home Depot and Lowes has the veneer ranging from $60-$120 for between 8 and 10 SF, and about $60 for per corner piece. That all adds up really quickly. Do have any links for what you purchased?
johninct
HE DID YOU A FAVOR!!!! You can't beat a concrete wall inside of a real working garage.
kelpaso1
MEMBER EMERITUS
New Brunswick
Building a house (and garage) in the beginning stages often looks way out or high. They matched the house foundation. After grading and landscaping it will look fine.
bczygan
DETROIT! Arsenal of Scrappers
Your house is ruined!!!
You need to move out immediately!
Leave a signed and notarized quitclaim deed in the mailbox and email me the address so I can bring all my stuff!
Bill
Bigbrew
Bill
Hahaha
Thanks, i appreciate that. This is my forever home and I want it to be perfect, it hasn't been a picnic trust me. They set my house on Dec 18 th. The basement had 4-5" of ice in it. 30x52, that's a lot of ice.
Put my meter box on the house, inspector didn't like it. Replaced it and before i got the green tag to turn my power on we got a thaw and had 4" of water in my basement.
Builder built my walk in shower backwards.
Fun, fun.
CraigStu
Blacksburg, Va
I agree w/ others that a little bit of attention paid to grading, and a few shrubs here and there and you will have beautiful house when it's done. I would live in it for 6 months before doing anything to the foundation. If you paint it, you will have to keep fixing that paint every few years. Maybe a stain that soaks in and changes the color a little but doesn't have a surface layer. We are in the initial design stages of a new house. The builder usually does manufactured stone on the foundation. But since he knows we are already over budget, he offered to skip the stone. I couldn't say yes fast enough. So about 8 months from now I will be in a similar situation. Not worried at all. This will be one of those deals in the back of my mind and one day I expect to come across something that will do the job and not cost too much.
KenC
oklahoma
It's a lot of work, but real stone can be split/cut to use as veneer. And, In my area is cheaper than the fake. Also consider, there are now companies that specialize in repairing failing 'stone' veneers due to some poorly manufactured products.
oo
Hilltopmasonry
oo
Be a lot easier buying a real stone that is already cut for thin veneer. There are several manufactures but I will warn you that even though thin veneer stone is only an eighth of the material is just about the same price as full size stone.
Here is a real thin veneer that I just did in a basement. This is a halquest product
Most veneer stone failing is due to improper installation techniques
Junkman
Northeastern CT
When I built my home, I wanted a 10 foot basement after the finished floor. Everyone, including the concrete contractor thought that I was crazy, but I was paying for it. 35 years later, I am still glad that I have the extra height in my basement, and the few steps to get into the home from the garage isn't a problem. I only with that I had more height in my garage, since I only have 11 feet. I could use an additional 3 feet so I could get the cars up on the lift a bit higher. When you are building, if you add a 10' x 10' overhead door, with a 14' ceiling height, there is nothing to regret later on, except for adding more square footage. Once it is done, you will appreciate the height. If the concrete sticking out of the ground bothers you, then put some fill up to it, and taper it down to grade. Tell us next year, if you still feel that it is too high... :thumbup:
Caterpillar Cowboy
Wyoming
From the pictures it looks like it will match your home. Which I think would look normal.
I agree. If you're afraid your garage is going to look like it's floating your attached house is floating too. I'd just do whatever you are going to do for your house.
byoung1219
Harrisonville ,Missouri
Just a few thoughts
With the foundation as is, I would think you would have to use a landing to turn the steps from the house towards the garage doors to keep from blocking the walk through door at the back.(taking away floor space )
My suggestion would be to raise the floor of your garage.
You might also want to use some sorta retaining wall to divert water away from your door openings, even if you raise the floor.
Just my opinion in what i see that would concern me.
Bigbrew
Framing started today. Trusses and flooring tomorrow. Should have a roof by Friday.
Orionrising
Western Maine
remember theres no particular reason they cant carry siding down over the wall other then it would be annoying to do... are they insulating the outside of the garage?
SALIV8
chicago and s/w michigan
That looks great.
I would put a front deck on that house, if budget allows.
Nice build. I wouldn't change anything. At least not until living there for a year or two.
Bigbrew
I'm actually going to do the siding to try and save a little money, i under budgeted for the garage. They are going to wrap it. Ill start messing with siding once we are living there in a couple weeks. I'm trying to get things inside squared away. Mother nature held up our septic system so i was able to get the whole place painted.
Bigbrew
That looks great.
Not sure what I'm doing on the front. Going to build a 24x20-24 on the back. Haven't made a decision yet. Need the ground to dry up a little. Sunk to my knee the other day.
wrenchguy
NW Indiana
2 me looks like cluster of madness, why isn't grade being brought up? how many steps into the house from the garage. if grade was going to stay where its at why not put larger windows in basement.... u got over 9' ceilings down there for some reason i ain't figured out yet? it ain't because they hit shale. good luck... time well tell.
Bigbrew
Grade will be brought up, need to get some fill but I'm waiting on a friend who digs for my highway department to bring it for free.
Cant bring it up much in the back because i already buried a propane tank in the ground so I didn't have to look at the ugly thing.
pgreenwood
I-80 at the Missouri
Agreed. Based on what I can see, my objection would be to the rear garage door placement. (It's too low.) I would have planned to add fill in the garage and for the garage floor grade to be about 2 steps lower than the house floor grade; adjusting the exterior grading accordingly.
doctordirt
Wall is not too high, it is the garage floor is too low. You needed more fill for proper drainage.
