Bigblue&Goldie
I'd buy a used IR for the same money. If it's tired, a rebuild is quick and cheap.
Who runs an impact at 90 psi? I have the same HF 1/2" earthquake and 3HP 60 gallon Puma compressor and this thing busted a Honda crank pulley bolt without much trouble.
Every time you shop at Harbor Freight a communist prospers. This Forum would roast you if you didn't Snap-On. Why do they defend the Earthquake? The Ingersoll Rand 231 is not much more than an Earthquake.
http://www.amazon.com/dp/B0002SRM3I/?tag=atomicindus08-20
Ingersoll Rand 231c is 109.00 shipped. Not much more than the 85.00 that the Earthquake costs today.
I would rather have a flea market 231 ingersoll rand than a new Earthquake.
Where does one find a quality rebuild kit for an Earthquake?
Where does one find a rebuild kit for the Milwaukee 2763-20? Better not buy one of those either.
So you are set to 90 at the gun with it running wide open?Ok, so this thread went overboard.
Anyways, issue has been corrected. And the gun works great. I upped the pressure at the regulator, and hooked up a gauge at the gun. I was only getting around 70psi at the initial setting of 90psi at the regulator. So, I jacked up the psi, and tried it again. Gun works great.
Thanks for your help guys.
