Harbor Freight Coupon Thread
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
Ah ha I miss interpreted.
Sent from my SCH-I545 using Tapatalk
this is the new one
And the old one
I can't find a picture any where.
The old one was wider, and I understand heavier. It had the push side to side speed and direction control like a IR 231.
Jasonfi
this is the new one
And the old one
I never owned the old one but I have this one and I love it. I feel it uses less air then my old impact that is only 250 foot pounds.
oldeerslayer
SW Wisconsin
I've been looking at the HF 12" SDCMS for months because as soon as the ground thaws we'll be starting a new 24 x 32 x 12 garage. Below is the best coupon that I've found. While researching it I found that Menards sells the same saw under the name Performax (different color plastic) with a 2 yr warranty for $279. Think I'll pay HF the extra $19.99 for a 2yr replacement plan and save myself $129.02.
Some of the reviews that I've read complain about it needing adjustments out of the box, but what brand wouldn't. Besides, you are going to take the time to check everything, anyway. The other 2 complaints are that you should open the gear box and add some grease, since the Chinese children are a bit conservative with grease and that the belt runs hot. I looked into the belt issue and found that while HF offers no replacement parts for this saw, the manual does give the generic belt part number (10PJ560). The number interchanges with Gates, Goodyear, etc. 220J10.
Easily available online from Amazon, eBay, and V-Belt supply from $9 to $30.
These are a common belt also used on treadmills.
Jasonfi
Looking for a coupon for a auto darkening welding helmet that brings price to 35.99. Anyone have one?
oldeerslayer
SW Wisconsin
What magazine or paper did that come from? I get HF's mailers every month and the best price they had was $42.99. I know they print better deals in magazines and newspapers than they mail to me. It might be worth subscribing to the right publication, particularly something like "Family Handyman" even though most of the articles would be below the ability level of most people on this forum.
Orionrising
Western Maine
I Have one, never bothered to adjust it much for anything, would probably not try trim work, but works just fine on dimension lumber
macgee
Sepulveda Pass, CA
Question: Can you use a 25% off coupon on US General Pro tool chests?
(I'm sure this has been asked a million times already but couldn't see while searching).
I'm specifically looking at the 26" wide, top chest and bottom roller cabinet combo.
Thanks
upgrading
Massachusetts
Jasonfi
Thanks
Yeah, it really ***** HF excludes most all of it's big ticket items from the percentage off coupons.
Jasonfi
Anyone have a coupon for the 90 amp wire feed welder making it 79.99?
macgee
Sepulveda Pass, CA
oldeerslayer
SW Wisconsin
Thanks for the reply and info.
I picked the saw up yesterday and the blade appears to be parallel to the slide
so I won't have to make the most difficult adjustment. The fence is a bit off according to my framing square, but that's an easy one. Had to tighten a number of loose nuts and bolts. I also plan to replace the sorry looking blade with a Diablo. Home Depot has them for $36 and I'll try flashing a Harbor Freight 25% coupon to see if they will take it. Since they a literally across the street from each other, there's a good chance they'll honor it.
macgee
Sepulveda Pass, CA
I would recommend to stay well clear of any Diablo blade sold at Home Depot now made in china. Since Diablo is no longer made by Freud (Italy) they have gone way down hill and not worth the price they charge for them.
I would recommend Oshlun blades on Amazon, one of the best blades for the price for the price and excellent quality.
Having said that, 12" miter saw blades are pricey compared to a 10" size blade.
HF does have one worth trying ($24 w/disc. & good reviews) and probably works way better than the HD Diablo blades:
http://www.harborfreight.com/12-inch-96-tooth-alternate-top-bevel-crosscut-blade-46235.html
Your best bet is to use a blade with a negative hook angle with your sliding saw.
BillD
3 ton Heavy Duty Low Profile Floor Jack with Rapid Pump
Item# 61253
Any coupons for this? Something like $69.99 would be awesome! :shocking:
CheckeredFlag
Mid Michigan
I see one for a 3 ton Heavy Duty Low Profile Floor Jack with Rapid Pump
item numbers 68048 / 69227 / or 62116
reg 159.99 - coupon price 79.99
use 39371341
(coupon ends today 2/28)
not sure if those item numbers are close enough to the one you were asking about, but ....
Duker
Livingston, TX
Has anyone seen a sale coupon for the 20 Ton Shop Press? Need to try out my new swag finger brake on a project. Thanks.
Jasonfi
Look back on this thread someone posted a coupon for 149.99 for that press.
Jasonfi
Use coupon code 39695725 that will make in 149.99. Sorry I forgot I had it written down.
trunxgp1224
I've been lurking on this site since probably highschool and only registered to look at pictures awhile back but decided I could be of some use in the HF threads since I'm there a few times every week and spend $,$$$ there. I saw a Thread somewhere for rating HF tools somewhere that I could add dozens of reviews to.
As far as the jacks go I would recommend the 2 1/2 ton over the 3 ton any day. Unless you absolutely need that 1/2 ton it's not worth it. The 2 1/2 is usually $10 more with coupons but gets lower than the 3 and also raises higher than the 3ton. It is lighter and easier to maneuver.
I have one 3 but needed something lower and got the 2 1/2. since then I haven't bought another 3ton and now have 3 or four 2.5s running around. I use these to lift riding mowers, machinery and up to 1ton trucks for maintenance, even skid the skid steers.
oldeerslayer
SW Wisconsin
Orionrising or macgee - got a question for you.
These parts came in a little bag with the saw.
Do either of you have any idea what they are or supposed to be used for?
They are not mentioned in the "manual" (if you can call it that) or the parts diagram.
Maybe I could mount them on the stand somewhere to hold my index fingers when I cut them off?
One pleasant surprise, the saw came with an extra set of brushes.
Does HF seriously think it will last long enough to need them or do they eat brushes?
Ross/Kzoo
Richland Mi.
I haven't needed any of the brushes but at least they are stockpiled.
PS on many small motors I've had bearings go out first.
BillD
use 39371341
Unfortunately I wanted specifically item #61253. Your code is for non-low profile jacks. Even the two 3-ton low profile jacks HF has are not equal. #61253 has a fraction inch better spec in both lowered and raised positions. Maybe latest updated version?
Anyway, I just went on Ebay and found a coupon for that jack #61253 for $71.99. I always thought making money from selling non-1-time-use coupons is kind of a ******* thing to do. :mad:
http://www.ebay.com/itm/Steel-Floor...61408953762?pt=US_Coupons&hash=item3cdd3015a2
Well this seller didn't block out the bar code completely, and knowing how bar codes work, I just photoshopped it a little and scanned it with my cell phone.
And the coupon code is: 81119069. :D
macgee
Sepulveda Pass, CA
That's pretty funny.
macgee
Sepulveda Pass, CA
I have no idea what those hooks would be for but your suggestion to use them to display your index figure is probably better than just letting them sit the random tool drawer.
RDH
Williams, AZ
I know I recently saw a 25% coupon which if read closely, DOESN'T have printed in the exclusions, the towable ride on trencher, item 65162. I was surprised to see it, as I was begining to consider purchasing one. Now I'm in need and can't find that specific coupon. Any help out there? Make an old man happy. Thanks.
