Harbor Freight Coupon Thread
LoveOldIron
Starts on Aug 11 for ITC
IMG_8412.jpegLove these things, and that’s a great price. Besides the typical tools, they’ll also hold 2 “cordless hole punchers”, or 1 and an extra mag. Double them up, and they securely hold fully loaded, full sized mags. Cover with a strip or two of good duct tape to keep the metal off your slide, and you’re good to go. Waaaaaaay cheaper decent magnetic mount.
ATC
VA
Very interesting. I've never seen one of those magnets in person, but could you cut one in half? Not many places I'd want to mount it has 18" of space to work with...
mrvm
PA
Use a small recip or hack saw and split it any size. Stack mounted could almost double the holding ability or capability
soloz2
Western NY
Might have to grab a super duty jack. Only thing holding me back is wondering if the badlands would be better for me. Nothing is level, garages are old cement that need to be redone and driveway is old cracking/bowing/crumbling asphalt. I’ve got a 2 ton low profile long reach Pittsburgh jack now and it drags over and doesn’t roll easily. I think the super duty would be the better jack, but want a jack that will roll and I won’t have to drag it everywhere.
pbon
Could you put bigger wheels on the current jack? Not worth the effort given the price of a new jack?
LoveOldIron
I thought of cutting in half when I first thought to use them for this purpose but then you’d lose the second screw hole. Mounting under a busy tabletop, I wanted it as secure as possible. I imagine a chop saw would give an Easily cleaned up cut, and the single mounting point might work vertically, side by side.
  • Like
Reactions: ATC
flying eyeball
seattleish
Im torn between these two jacks as well...it would take a 30% to get me pickup the Badlands.
There is a company that sells off-road 'kits' for several different jacks, prices are steep imo.
toolman96
I've cut a few in half. Then drilled new mounting holes so there would still be 2 holes on each. The warrior step drill bits worked well for that.
mrvm
PA
Used the SD Daytona jack for several years in the garage but the Badlands bigger wheels have advantages for gravel, grass and soft asphalt. I find myself using the Badlands jack whenever the surfaces are less than smooth. The Badlands fixed wheels have another trick for maneuverability by rolling in 2WD
mikeinri
Are those ITC discounts limited to 5 items per day, or 5 items over the duration of the sale?
Mike
scottybk
frenchtown nj
I have a couple of the 18 inch magnets, back pre-Covid they often gave them away free. The magnet isn't the strongest, unless it is better now. Don't expect it to hold heavier/larger items.
tabs
wv
i hang hammers and other hand tools on mine and they work fine. not sure how heavy of items you're trying to hang, but i've got a 3lb sledge plus other things on one alone.
i've bought about 100 of these so far this year when they were on sale for $1.99. they are amazing. i've lined the backs of my tool cabinets so they don't get scratched against the concrete block walls in the garage, lined the drawers with them to hold my wrenches in place, and built pegboard specifically to screw these to the frame to hang most hand tools like pliers and screwdrivers and even hammers and pry bars on. love them so much.
i've used an angle grinder to cut them down but the magnets don't cut flush and kinda chunk off the ends. still works, just might not be the prettiest when you're done.
LoveOldIron
Nice. I appreciate the usage ideas
tabs
wv
examples of the above. again, these are very useful around the garage.
CZ Eddie
Austin, TX
wire
Anyone have a coupon to share?
I need to get the long-reach Daytona floor jack and the matching jack stands for a four-inch lifted truck.
Not quite the ones you wanted but on sale starting today for ITC
wire
Today only
CZ Eddie
Austin, TX
Those are too small, but thank you anyways!
I need the long-reach jack and the 6 ton stands for my lifted truck.
And will also be buying that nice $109 30" pedestal fan and a few other items.
If anyone has a coupon for $ off, please share? :)
Or knows how I can save on my purchase?
EDIT: That floor jack is actually only like a ~1/2" shorter max height than the long reach, so it looks good. Thanks!
Matt XYZ
Germany
I’m flying to the US tomorrow, just in time to miss the 40% deal on icon sockets. I also wish there was a reasonable way to get a 5 drawer service cart to Germany. I don’t think it will work as a checked bag. I’ll still spend a few hours looking at tools at HF and the box stores.
BWWgarage
2 buys at sidewalk sale yesterday ...
1. Icon big meme tool. I have the small orig and really like it. I’m mixed on the big version at $48
2. Quinn 1/2 master socket set, 83pc (This master socket set comes with a full assortment of deep and standard sockets in sizes from 3/8 in. to 1-5/16 in. and 10 mm to 32 mm, no skips. The set includes an ultrathin 90-tooth ratchet for easy access in tight spaces.) Very nice set and very heavy. Worth the $90.
Mandres
If you see one of these in your travels or own one its worth $319 + tax to return the bottle jack part to HF, there is a recall. I bought one new years ago at a heavily discounted price and returned it recently. No receipt is needed, just the bottle jack, they call it the Hydraulic Ram.
Wow, thanks for the info. I've been tripping over one of these in my garage for years now. I'll be glad to be rid of it and put the funds towards something more useful.
wire
