Thank you Paulsomlo for the quick reply! Just to make sure I understand correctly:
What you're looking at, as far as the overload, is the top of a rubber plug. Under that, is the actual overload mechanism. The adjustment screw for the overload takes a special splined driver. The slotted head plug you've removed is just to close things up - it doesn't affect functionality. I would bother messing with the overload."
That's what I thought, thank you for confirming. Just to make sure, you meant "I would not bother messing with the overload", correct?
Yes, I meant "would not".
"The only part of the release valve you need to be concerned with, is the tip of the needle valve and the seat. What you're showing in the picture, is inconsequential. There should be a metal thrust washer and a rubber washer in the assembly in picture 5 - I'd say one is missing from the looks of it. The assembly in pic 5 should just come apart - there's nothing threaded to anything." Are the two washer's you are referring to the same as #23 & #24 on the diagram (please see screenshot below)? That's precisely the seal (rubber washer) that I'm trying to replace, the reason I would like to separate the parts. I believe seal seats inside of the parts assembled shown on Pic # 5 which should be parts 22, 25 and 26 in the diagram. They are somehow "stuck" together, I thought they would be threaded one to another (22 and 26). I'll keep trying to separate them, any advice on how to do so will be greatly appreciated.
Yes, 23 and 24. I misspoke - 22 and 26 are threaded together, of course, trapping 23, 24, and 25. I suppose you could wrap a piece of leather around 26, secure it in a vise and put a wrench on 22, or find something square that will fit the hole on 26.
"Sure, hang on to that leather cup - you never know when you'll happen on another WS that someone's throwing away, and just needs a new cup."
As far as you can tell, you do agree with me that it looks in excellent condition?
Thank you again for all your help, I sincerely appreciate it!
View media item 100417
