Hellfire floor coating experience
CS223
Got the opposite side of the building done this weekend, 4 coats. Once again, my associate did a great job of laying it down. His technique seems to be a heavy wet roller, about two 10’ strips then load the roller again. Not much effort spent back rolling. For those of you getting ready to use Hellfire, don’t panic when you put the first coat down, it will look pretty ugly due to the concrete sucking it up. We waited 2 hours between coats and it was plenty dry to walk on, we wore those cheap disposable slip on clean room shoe covers changing them each time we crossed onto the fresh floor. Another tip, if you have spider cracks and imperfections, daub Hellfire into them in advance of rolling that section.
Tip of the hat to Legacy, they were spot on as to the amount of product require to do the job.
View media item 95727
View media item 95726
jlewis45236
attached
Found your product through Shea's excellent website. Last weekend I cleaned and acid etched the garage. It has been drying all week and I plan on applying Hellfire tomorrow. I received my 4 gallons of Hellfire yesterday along with a bottle of the pigment. What would be the best way to mix that in? One gallon at a time with the two ounces or do I need to combine everything into a 5 gallon bucket and do a good mixing with 8 ounces of the pigment and a drill on low?
I will post some pictures and things I encountered during the process once I finish. I ran into a problem with fiberglass hairs but I plan on using a torch to burn those off tonight.
papp101
Nice. How'd it go? Any pix?
Sent from my Pixel 2 using The Garage Journal mobile app
Shea
California
No, you will need to grind first to provide the proper profile and remove the upper layer of sealer. 8505 will effectively block proper penetration for adhesion if you don't do this.
Black300zx
Elkton, Md
I did my 1200 sf with the single head grinder. It took me almost 4 hours. So, a dual will probably cut that in half.
Just curious, was that new uncoated concrete or were you removing a previous coating? It took me probably 6 hours to do my 400sf, but I also was removing concrete paint
indoyota
Hollywood MD
It was a fresh slab and the concrete guys didn't burn it out to a smooth finish like they normally do.
macs shop
Louisville KY
I just pulled the trigger on 7gallons of HellFire for my new 800sq ft floor. It has no sealers on it, but it was machine trowled, probably a little too much. Pour a little water on the floor, and it sits on top of the concrete for minutes before absorbing. I am hoping just an acid etch will open the pores enough.
phtcbra
Neon hell
We can supply additional tint that you can use to darken.
Pic shows standard (lower), tint added (upper).
Send me an email for more info
Question, is this picture with 2oz of pigment added or 4oz of pigment added?
countrybumpkin
Cherry Valley IL
Bumping it back up!
I don't see anyone mention heavy machinery?
I will be occasionally moving heavy machinery on casters or dragging when necessary. Milling machines, lathes, industrial equipment, loader buckets etc etc.
Anyone have any experience with how it holds up to something like that?
I am very rough on floors and up until this point, I have wrote off all finishes. It seems like this one may be able to take the abuse from what I've read.
Sent from my LM-V405 using Tapatalk
Shea
California
Nothing is going to hold up to heavy machinery being drug across a coated floor. Your best bet is going to be the bare concrete with a penetrating sealer if it's going to see that kind of use.
bulletpruf
San Antonio
Agreed. The Hellfire coating is tough but it's not indestructible.
jbass350z
I have a couple questions. I have a 680sqft space i want to coat. There is a 4inch tall lip around the entire perimeter that was painted by the home builder. I have no idea what it was painted with, but I want to coat up that lip as well. I plan to etch the floor, but what do I need to do about the paint?
How many gallons needed for 3 and 4 coats?
jbass350z
5 gal for 3 coats.
Can you comment about my other question ? There is a 4inch tall lip around the entire perimeter that was painted by the home builder. I have no idea what it was painted with, but I want to coat up that lip as well. I plan to etch the floor, but what do I need to do about the paint?
Sumboodie
AK
My apologies, I have not seen any of these oil cleaners except Pour n Restore. I would use 400 sq ft avg. for a three coat process.
The primer is on our site, works well.
Actually gels the oil in place, keeps it from surfacing.
http://www.legacyindustrial.net/products/primer-coatings/hd820-oil-stop-primer.html
So for 1200 sq feet and 3 coats it would take about 3 gallons? I looked to order 4 gallons and it's showing shipping as not costing anything. Is that correct?
Sumboodie
AK
Whatever they used in the warehouse I work in works fine. Has held up decent to forklifts, dragging metal totes (about 4000lbs), pallets, etc.
LegacyIndustrial
deerfield, IL
It may peel/curl the paint. Solvent base. You are welcome to test it. Worst case may have to sand off. Also keep your eye on it because it has metal additive in May like to drop off of the verticals. Go light.
