This is something I don't understand, so if someone would explain it to me, I'd appreciate it.
Most build Pole barns to save money, but if you go back and have to build walls anyways, why not stick build the building in the first place? How much do you actually save by going with a Pole vs. Stick?
Is it the fact that you don't need a foundation BUT could go with a slab, or is it easier for a DIY'er to frame it himself? I know a few others that have done the same thing...build a pole building, then basically frame up a complete garage on the inside.
Don't get me wrong, I'm not trying to sound like a smartass, but I'm just curious.[/QUOTE
As discussed many times, if you use a commercial/ bookshelf girt install initially there is no need to reframe for interior walls. Less labor, less materials and a sturdier building.
