The diagonal on your square nut is longer than the diagonal on a hex, even if the "across flats" distance is the same. You'll probably find a larger 12-point will fit, more or less.
It gets talked about on here from time to time.
12 point socket for 1" square nut
So, right tool for the job and all aside, what 12 point socket size fits 1" square nuts best? I've got an 8 point socket on order but I need to pick something up local tomorrow and I don't have the nut with me to try sockets at the store.www.garagejournal.com
You are correct that an 4 or 8 point socket is the correct tool. If you have the access then a large adjustable might be the tool your looking for. A 15" size will open to that large, but check the specific tool as some may not.Thank you for the quick reply. Any idea which size to go up to on the 12 point? I bought the one in the photo and I’ll have to buy the next. I also have my eye on a 1 11/16 8 point socket. I’m sure that’ll work, right?
Unless your attached image is deceiving me, it looks like you accidentally started at the 1/16" tick mark on your ruler and then measured to the 1-11/16" tickmark. It looks to me like you actually have a 1-5/8" square nut, so you would need to buy a 1-5/8" 8pt socket or slug wrench for it.
Here's a couple on ebay.
Grey Pneumatic 4552S Socket 729440478063 | eBay
Find many great new & used options and get the best deals for Grey Pneumatic 4552S Socket at the best online prices at eBay! Free shipping for many products!www.ebay.com
1-15/16 would be real close.Any idea which size to go up to on the 12 point?
Yes. You might be able to use a larger hex size to turn a square fastener in a pinch but it's never going to fit correctly and may damage it depending upon the force applied. 6/12 point tools are designed for hexagons with 60 degree corners while 4/8 point tools are designed for squares with 90 degree corners.1 11/16 is technically too large to fit, but it’s still too small to fit on the square nut. I assume that’s because of it being a 12 point.
Either of those options or just an open end wrench with flat jaws will work fine.So, now if I make sure I buy either a 4 or 8 point socket at 1 5/8 it should be cut and dried.
Except that it's a 12 point socket and the wrong toolThis one is affordable. A decent brand as well. You need a 3/4 drive tool.
8 Point would be the best option but if 12 is all you can get according to my calculations a 2 1/4 12 point might do it. But you could round it off.
We build custom wrenches everyday. I can send you a DXF of a wrench and you can have sendcutsend.com cut it for you. PM me...
OK. Technically you are right. The OP is not giving us any context to the application and situation. In the picture The nut is off what ever it is use on. Why not just buy a new and correct fitting hex nut? How tight does it need to be? Is it on a museum piece or an functioning machine? Is the cost reimbursable or it is out of pocket?Except that it's a 12 point socket and the wrong tool. I get using a hex tool on a square fastener if that's all you have but if you are going out to buy something specifically for it, just get the right one.
I think I have all the spline sockets from snap-on. Took a long time to hunt all those down on the used market. Lol.OK. Technically you are right. The OP is not giving us any context to the application and situation. In the picture The nut is off what ever it is use on. Why not just buy a new and correct fitting hex nut? How tight does it need to be? Is it on a museum piece or an functioning machine? Is the cost reimbursable or it is out of pocket?
Assuming he can measure the thread accurately. Get a hex nut of the correct thread and not spend $65+ on the ideal 8 pt or 4 pt. socket.
That nut is huge and beefy. You could use a pipe wrench to tighten it, if it will fit in the existing space. As suggested earlier. Any open end 1 -5/8".
A little more context may help to come up with a reasonable solution.
As a side but related issue. Spline sockets are advertized to work on square nuts. I know some people will say do not do it. I have on smaller sized wtih good results. But they never give you a chart to convert the size stamped on the socket to the square nut application. You just have to use the tightest fitting socket you have.
OK. Supply him a DXF so he can have it build.My calculations show this is incorrect.
A 2-1/4” bi-hex should fit a 1-7/8” square.
1-7/8” is too snug. 2” is too loose. 1-15/16” or 50mm is the best fit.I would like to see your math/model.
I grew up near a trolley line as part of the Boston T. I use to see maintenance guys walk the tracks with a long open end wrench retightening the nuts on the rail. It was something like 3 or 4 foot long tool.If it's railroad the original tool used on them was probably just a long, probably 3 foot minimum (see a bunch of the 6 footers for sale occasionally) open end wrench. You have the across so you should be able to find a cheap open end with the same measurement new or used.
Not to threadjack, but I believe triple square/XZN is more of a German thing. Normal 12 point aka double hex is used in some Toyota and Honda applications like head bolts or flywheel bolts. Some Toyota head bolts are also female 12 point and take a male double hex key.This discrepancy reminds me of Toyota head bolts. They are double hex and NOT Triple Square (XZN). The difference is the angles. That's why the 12 point wrench will not fit.
I like your CAD program. (Cardboard Aided Drafting)1-7/8” is too snug. 2” is too loose. 1-15/16” or 50mm is the best fit.
It sounds like he has a lot of them, and he wants them to be period correct.Since it's no longer on the bolt, so getting it off is not an issue, can you just substitute a hex nut on whatever it came off of?
Of course, I'm always in agreement if it's being used as justification for a new tool.
The female head bolts are what I was referring to. That's where many get confused and think that they are XZNNot to threadjack, but I believe triple square/XZN is more of a German thing. Normal 12 point aka double hex is used in some Toyota and Honda applications like head bolts or flywheel bolts. Some Toyota head bolts are also female 12 point and take a male double hex key.
You might have missed the discussion, but the OP measured incorrectly. The nut is 1-5/8.Ok now that I am in the Plant and have access to the good software (I am caught up for the day, shh don't tell anyone).
Assuming a 1-11/16 Nut as shown.
I gotta go with a 55mm 12 Point as the best fit:
1-7/8 12 Point:
Hydraulic Press at about 198 Tons.
2-1/16 12 Point:
5 lb Maul maybe?
2-1/8 12 Point:
Too tight.
55mm 12 Point:
Tight but I think doable.
Oh Chit...You might have missed the discussion, but the OP measured incorrectly. The nut is 1-5/8.
