Same experience here: the Wera keys rust more easily than almost anything else in my toolbox.
Often there is a trade-off between corrosion resistance and strength (e.g. stainless steel). Perhaps this rust reflects that?
I rate these Allen keys better than the alternatives because the Hex-Plus feature works and, being still under patent protection, is not available elsewhere. You can think of Hex-Plus as the male version of Flank Drive.
Here are some photos of one of my Wera Hex-Plus keys, a 4 mm key to match the photos by the original poster. It’s interesting that the machining is a bit different from the OP’s key, especially on the tip face. Mine are probably ten years old.
The photos show the interesting design features – long round shank, visibly modified hexagon tip shape, labelled sleeve – and their effect.
Note that the Hex-Plus shape is not applied to the ball end, which is nonetheless better made than most ball ends. The ball end of my key below has never seen more torque than can be spun in my finger tips. I cringe when I see people put 5 Nm into the ball end of a 4 or 5 mm key. That’s not what they are for.
I take uncommonly good care of my tools, wiping them down with an oily rag regularly, using them carefully and correctly, and storing them in a dry location. And yet you can see several rust spots on the metal and the fading labels on the sleeve.
Note the beautifully wide wear marks on the faces of the modified hex. That’s what Hex-Plus does: it presents a subtly convex shape to the nominally flat faces of the inside of the fastener head. When you crank on the tool, this slightly convex shape deforms elastically (as does the flat of the fastener) to produce a broad contact patch (times six, of course). The risk of plastic deformation (damage) to tool and fastener is therefore reduced.
The marketing material for Hex-Plus is misleading. The promotional pictures show pointy star-shaped tips with concave ‘flats’. As you can see from my photo of the tip end-on, the reality is that the shape bulges outward just before the corner of the hex, to produce the convex shape just off-corner that I mentioned in the previous paragraph. This is the essential feature of the design. But since even professional mechanics don’t always seem to understand that steel is elastic and half of the mechanical world relies on that elasticity to function (e.g. fasteners in the first place), I guess Wera thought the reality would be too hard to explain to your average Amazon shopper. Or maybe their marketing agency didn’t understand the physics of the design.
One key benefit of this arrangement, as with Flank Drive sockets, is that it greatly reduces the downside of a sloppy fit between tool and fastener. And indeed the Wera Hex-Plus keys have a pretty sloppy fit compared to other expensive Allen keys. Don’t mistake that for poor quality. It makes for faster insertion of tool into fastener without much of a downside.
Does anyone know if Wera makes Hex-Plus bit sockets WITHOUT the stupid spring-loaded ball bearing that causes failures? I would love to buy some Hex-Plus bit sockets that don’t have that ball bearing.
