2ndGearRubber
Caliper bracket pin bores, actually.
Often I have vehicles with frozen slide pins. So after I walk the pin out with an air hammer, I now have a very rusty hole, 8-12mm in diameter, 3" deep or less. I am typically cleaning with something like the link below. Flex hone, silicone carbide abrasive, lower thus more aggressive grit. I've used this brand, and McMaster-Carr, both work well.
I'll fill the bore up with PB Blaster (supplied from employer), cycle the hone up and down for 10 seconds or less, rinse with brake clean. With a fresh hone, one pass like this is normally enough. With a worn hone, sometimes 3 passes isn't enough and rust remains. Problem is as the hones wear out, I need to buy more. And that's where I am in this cycle.
Is there a superior method to cleaning such holes back to fresh metal? Drill bits are a pain and often remove metal, plus the tendency to self-feed and snap off. I need to keep the bore size as close to stock as possible. Would honing oil improve life of the hone? I don't care about keeping the hones clean, they stay dirty in a plastic container and the caliper bore is rinsed with brake clean before new pins/boots/grease. So unless honing oil will significantly extend hone life, I don't see a benefit from moving to that.
This is a very important thing for me, it saves customers a lot of money over buying a new caliper/bracket. I typically make a little money even with my cost of hones, but it keeps quality original calipers on the car and builds trust with the clients that we're looking out for them, which are really the priority here. Even if I broke even I'm still making something on the rest of the job.
I just need to restore the pin bore to clean metal, and am looking for alternatives or techniques which I may not have considered.
