Hot Dawg 45K Heater Install
sweetk30
finger lakes area upstate ,ny
in almost any basement . . . best not to put in a closed off to acssess area like behind a wall or celing . . .
as always disclamer : check local building codes . . . internet info not 100% true all the time.
D
D45
NW INDIANA
All of this piping is exposed, nothing will be hidden, concealed, or covered up
From the looks of things, I will need one union to be used
matt_i
What I do with the gas pipe is to shut it off and then leave on one or more "pilot light" devices and let that burn up the last available gas in the line.
Then cut it.
Make sure you allow a window of time when the hardware store is open :) that way you can get there and back a few times to account for the inevitable parts shortage and/or things that weren't immediately apparent. With the main goal of having heat back on in the house without having to wait until the next day.
I recall as a kid having no water for a day when my Dad was working on a project and got into a parts need outside the window of hours for the hardware store. Of course in those days there was no big box and I think almost everything was closed on Sunday with short or half day hours on Saturday.
D
D45
NW INDIANA
I picked up a union, but now I have to find a solution for another issue:
4-1/2" long ******, then the valve, another 4-1/2" long ******, then an elbow........it sits about 3/8" too low (to line up with the 3/4" pipe on the right in the pic)
I think using a 5" long ****** will make it too tall, but I might need to try the longer ****** today
D
D45
NW INDIANA
Another solution will be to ream out the hole where its coming out of the crawl space and see if I can raise it up slightly
D
D45
NW INDIANA
Easily solved.........used a 4-1/2" ******, valve, and a 5" ******........all put together in the garage so I could really crank down on it
It is spot on
naturalgas
Metrowest Ma.
It is spot on
Good looking job! You wouldn't have made any money on that install though. Just kidding . [emoji482]
D
D45
NW INDIANA
I am going to shut off the gas tomorrow, and remove the original line that needs to be cut down, for the T fitting to be installed
I bought a pipe plug, so I can I can work as my leisure and turn the gas back on until this last portion of the install is done
Very exciting, hopefully I will be testing for leaks this week and have heat by mid week
D
D45
NW INDIANA
18" ******, to get past the copper water line and to work in a less confined space
I was going to use a 12" ******, but the 18" worked out better
I attached another elbow and bought a 5-1/2" ****** and a T fitting, which I will thread into the eblow (when I shut off the gas to cut the gas line)
I also bought two unions, which I will have to use when re-installing/replacing the cut pipe sections
Then, that's it.......
LX-Markham
Markham, Ont.
Been following this thread since I've been installing a 45k Hot Dawg also. Finally got it fired up today! I did the install, the electrical, and the venting, but I had somebody in today to run the gas line and fire it up.
Hope you get yours going soon D45. It's getting cold out there!
D
D45
NW INDIANA
I had to take a week off of working on it, because of being sick and having a rather crazy work schedule
Tomorrow morning I plan on finishing up the install, in the basement and checking for leaks
Yes, it is getting cold out there...........too cold
So far, my garage has held a temp about 17-20 warmer than the outside temps
Hopefully I can fire up the heater tomorrow afternoon
D
D45
NW INDIANA
Up and running........
Cranked the heat up to 75 in the house and shut off the gas at the meter
I ran the stove and dryer to help purge the line and got out the hacksaw
There was still some pressure in the line, because it hissed when it cut through the original 3/4" line, that was about 7' long
I added a 10" ******, union, and another 8" ****** between the original elbow and the new T fitting
The I had the section of ole 3/4" cut and threaded down to 52-3/8", connected it to the union, and used an 8" ****** to connect it to the T
I also picked up some more pipe hangers and one bracket for the 1/2" pipe, that feeds the dyer (it was just dangling in place)
I turned the gas back on, opened the two valves (in the basement and one in the garage) and began to check each joint and fitting for leaks
No leaks so I think I am all good
I plug in the heater and switch the gas valve to on, and turn the tstat to "HEAT"
The green light on the gas valve (inside the heater) is blinking..........6 total in each sequence. Bottom burner will light and shuts right back off within 5 seconds
The blower fan and exhaust fan I can hear (and see)
So I start doing some online research and finally just let the heater run for 20 minutes, just blowing cold air
I believe I just had air in the new line (???), because it then fired all three burners and was throwing heat. Very pleased
It is currently around 23 degrees outside and within 30 minutes my garage was mid 50s and within an hour temps were 65 inside
Here is what I ended up with in the basement:
D
D45
NW INDIANA
Prices:
Heater: FREE
B Vent Kit: $63.75
Thermostat: $20.05
Tstat Wire: $8.00
Black Roof Caulk: $6.00
Clear Silicon: $5.00
Ground Wire: $3.00
Plug: $6.00
Black Pipe/Flex Line/Fittings/Dope/Valves/Hangers: $405 :shocking:
Total: $516.80
I was hoping to do it for more near $400, but the quality USA made black iron pipe and USA made black iron fittings really hit me hard. But I felt the added cost and quality was well worth it
I am going to monitor the utility bill and see how the NG consumption is affected
D
D45
NW INDIANA
Start this thread on 4/12/16 and finished the job on 12/10/16
Pretty funny, but I did it myself and did not have to hire anyone
Beats the $2,500 installed priced I see people paying on here
sweetk30
my mom has not said a word yet about the gas bill . . . . I have had my unit for just over a year working . it is just to keep the shop @ 50* all I use it for . and its 125k btu unit.
so you should be just fine.
matt_i
Looks good, biggest thing is bring your biceps when doing a black pipe install. Fittings are pretty "tough". If you are breaking a sweat you generally won't have any leaks :D Always good to test for peace of mind.
D
D45
NW INDIANA
After some returns and looking through the receipts, I think the figure will be a tad under the above posted price............right around $498 for everything
I can definitely see how having the heater wired into a dedicated switch would be helpful, rather than into a ceiling mounted outlet, like I have
I will see how things go this winter and if its that much of a PITA, its an easy fix
My thermostat has a two position switch, either "HEAT" or "OFF"
I plan on leaving the heater plugged in all the time, and just using the tstat switch.........acceptable or?
D
D45
NW INDIANA
It was around 20 degrees this morning outside and my garage was 37 degrees, with the heater off
Decent amount of heat retention, but I know I am losing a lot through the roof
This winter I might have a project on my hands
D
D45
NW INDIANA
I've also read through many posts, claiming that the heater will not fire when the temp is under 50°
Definitely not the case, was 37 in the garage tonight and mine came right on
matt_i
If you have no icicles hanging off the lower edge of the roof then its my opinion you are probably doing OK in the insulation department. (Usually room to improve but that's a good first check) I can see the difference as I drive around the area I live, usually the older houses are the ones with the icicles hanging off the soffit.
A sectional garage door is always going to be leaky compared to what you'd accept in your house. What i see in my brand new door is the valleys of the "woodgrain" texture that's embossed into the metal skin is the part that's leaking light past the gasket. Its relatively small, but its there. Also consider what your house temp would be if you moved the thermostat to "off" position overnight....
My existing shop is 2x4 walls (fiberglass) with 2x10 ceiling (cellulose), if I ramp it up to 50F air temp then it will hold at or above 40F thru 2-3 days of ~20F outdoor temps. It might do better if I held it at setpoint longer, the 30 tons of iron that's out there is slow to gain thermal inertia.
D
D45
NW INDIANA
Ok.....is there a way to "turn up the heat" on these heaters?
While mine blows WARM air and heats up the shop nicely, I feel that some heaters blow HOT air
naturalgas
Metrowest Ma.
No. 45k btu heater is on the small side. How do the burners look? Your sure it is set up for nat. gas and not LP? If it heats up the shop that's good. The more BTU's the more gas you burn and the higher your gas bill.
csp
Franktown, CO
The temp of the air it's blowing is entirely dependant on how cold the air is when you turn it on. The colder it is to begin with, the less heat you'll feel after it passes by the heat exchanger.
toyotadriver
I have an 80k heating my 30x40x10 shop. When it's 40* in the shop and I turn the heater on, it definitely isn't blowing as warm air as it does when it's 65 degrees in the shop.
D
D45
NW INDIANA
Makes sense, thanks
After running the heater on and off for a few weeks, I am anxious to see what the gas bill is
Hopefully I can leave it running more, if the bill isn't too too bad
D
D45
NW INDIANA
I am going to buy a Hot Dawg 75k heater......same identical heater as mine, just a 75k unit
This 75k heater should be an easy swap and hookup, since both heaters use a 3" vent
Hope its not too much, but I just felt last winter that the 45k unit took too long to heat up
D
D45
NW INDIANA
I initially thought about adding a second, smaller heater and just tap into the 3/4" line by adding a T fitting
Then I thought, just sell the 45K and buy a larger heater.............which I did
I ended up getting another Hot Dawg, just in the 75,000 BTU version (HD 75AS-0111)
Some comparison specs for the 45K vs the 75K
45K FAN SIZE: 10"
75K FAN SIZE: 14"
45K INPUT: 45,000
45K OUTPUT: 36,000
75K INPUT: 75,000
75K OUTPUT: 60,000
45K HEAT THROW: 27 feet
75K HEAT THROW: 38 feet
45K AMP DRAW: 3.7
75K AMP DRAW: 2.5
The added BTUs and the longer heat throw will be perfect.......hopefully the heater will be here next week
I sold my 45K for $400 and bought a new 75K for $575 shipped......a good price I think, plus I got the initial 45K heater for free
66% increase in BTUs should be perfect and the heater will run less and take less time to heat up the shop!!
D
D45
NW INDIANA
Well the new heater is arrived, just need to get some springs for the airflow louvers..........which the selling business said they will order and ship to me for free
The new 75k heater has 5 louvers, compared to the 45k which has 3
It should be a simple swap, just might need to adjust the B-vent somewhat to compensate for the larger overall heater
The flex gas line will easily adjust
This install, I might just hardwire it with the switch on the side of the heater..........rather than the plug-in route I used with my 45k
The one thing I did notice it the larger increase in the rear fan size
What is the transformer looking square on the backside of the fan, the 45k heater did not have this
Neat reference guide and decoder:
D
D45
NW INDIANA
Tubular Power Vented Propeller Unit
75,000 BTU
Aluminized Exchanger
Direct Spark Ignition
115V Single Phase
Single Stage Natural Gas
D
D45
NW INDIANA
You mean the capacitor? It's just because the fan has a bigger motor.
Nice!
45K FAN SIZE: 10"
75K FAN SIZE: 14"
45K AMP DRAW: 3.7
75K AMP DRAW: 2.5
45K Motor HP: 1/15 HP
75K Motor HP: 1/12 HP
45K Motor AMP: 2.40 AMPS
75k Motor AMP: 1.95 AMPS
Larger fan and less amp draw......but more power?
i8iridium
45K FAN SIZE: 10"
75K FAN SIZE: 14"
45K INPUT: 45,000
45K OUTPUT: 36,000
75K INPUT: 75,000
75K OUTPUT: 60,000
45K AMP DRAW: 3.7
75K AMP DRAW: 2.5
I've been lurking around for a while and finally decided to register. I've been looking at installing a HD60 in my 3 car garage. Do you mind telling me where you found yours for that price? That's pretty good compared to what I've been finding around.
D
D45
NW INDIANA
I bought the HD 75K on Ebay, from a salvage freight dealer
Brand new, never installed
It was a good price, for sure........$575 shipped
D
D45
NW INDIANA
when i got my 125k unit these guys were the best price i could find at the time and great to deal with . sold me everything in 1 package deal . heater / exhaust pipe kit .
http://shurailhvac.com/categories/Unit-heaters-/
Those are great prices for sure
The HD 75K I just bought is $650, but they will also charge freight shipping....which could add $100+ on to the price
Mine was shipped via FedEx, as a "Heavy" and "over sized" box, so I am sure it cost a pretty penny to ship this
So, for $575 shipped I am happy with it
