Check your local Pep Boys. They have some deals on those portable jump starters / air compressors.
Only downside is you have to do the mail-in rebate thing.
Prices are after rebate:
300A without compressor $15
300A with compressor $22
450A with 260psi compressor, USB charging port, light $40
They all have 12V plugs
I think these prices are better than Harbor Freight
300A has a 8Ahr AGM battery, says it is not replaceable, warranty is 90 days requires receipt and shipping to IL.
Says to charge 8 to 12 hrs, but never longer than 24 hrs, which means you need some kind of timer I guess?
Do no crank for more than 6 sec, wait three minutes between starting attempts.
***** not the same battery, but I think same type for comparison
Specifications
* Volts: 12
* Amp Hours: 8
* Length (in): 5.94
* Width (in): 2.56
* Height (in): 3.94
* Weight (lb): 4.96
HF cheap one, Aaaack, looks much better, warranty 30 days, but likely cheap for extended.
# Automatic cutoff prevents overcharging
# Charge/battery level indicator
# 400 amp boost rate/900 amp peak
# Maintenance-free, 17 amp hour battery
# 12v power port for powering 12V accessories
# Easy-to-read charge/battery indicator
# Work light
I can't believe how I am flip flopping about wanting one of these.
