metlmunchr
- Joined
- Sep 10, 2011
- Messages
- 1,288
What do they call 3/4" copper pipe?
They call it 3/4 copper tubing since that's what it is and that's what the manufacturers call it. It is not pipe. The word pipe implies a specific set of outside diameters. For example, 3/4 pipe implies an OD of 1.050" Doesn't matter if its mild steel, alloy steel, brass, any of of several grades of aluminum, inconel, titanium, pvc, or any of a number of other materials including "iron pipe" as the home center cowboys call it even though iron pipe hasn't been produced since the late 50's when A M Byers discontinued its production. If its sold as 3/4 pipe then the OD is 1.050". To my knowledge, no one makes actual copper pipe.
Do you have some logical explanation of why manufacturers would adhere to industry standards specifying OD regardless of material type for pipe, and yet decide to ignore those standards for copper and call it pipe when its OD doesn't conform to the standards? Hint..... They don't. They call it tubing.
The only common "pipe" that doesn't conform to OD dimensional standards is CPVC. That's done to prevent inadvertent mixing of CPVC and PVC in situations where PVC would fail, such as excess temperature.
Re your claim that there's some magic situation where ID is pipe and OD is tubing, that's another load of ****. Pipe up thru 12" nominal has an ID approximately equal to the nominal size, but 14" and larger pipe has an OD equal to the specified size and an ID substantially smaller, depending on wall thickness. Yet the manufacturers don't refer to 14" and up pipe as tubing even though its specified by OD.
Take a look at this tech info sheet from Mueller and see if there's anywhere they refer to any standards for "copper pipe". http://www.muellerindustries.com/uploads/pdf/Copper Tube Standards.pdf
How do they refer to 1/2" tubing and compression fittings with 1/2" ID to fit that tubing size? Compression fittings are called out in the ID of the fitting, which is the OD of the tubing they fit.
I'm fairly sure any competent fitter knows the OD of 1/2 copper tube is 5/8 and that he'd need 5/8 compression fittings. But I'm sure there's also plenty of people who wouldn't know that. Perhaps those people should call someone who does know the trade and the sizes of common materials, or, alternatively, they could measure the OD of the tubing since its fairly obvious that's the part of the tube that's going into the fitting.
Do they call 1/2" copper sweat fittings 5/8" fittings, or 1/2" copper pipe fittings?
Most of the hundreds of boxes of fittings I've bought over the years are marked with both nominal size and OD size. However, I've never seen any of them marked as "copper pipe fittings", regardless of size.
The point being, it doesn't matter what the box store crowd calls it. The manufacturers call it tubing. The trade calls it tubing. And the wholesalers call it tubing. Homeowner oriented websites likely call it pipe because the stores figure that will make it easier for their customers to find it.
Yep, I was at the tire store the other day and sure enough, they had round things with holes in them. " Pipes", I guess. So I bought some rubber "pipes" for my truck. Then on the way home I stopped at Tractor Supply for some nuts and bolts. Turns out the washers are called "pipes" now 'cause they are round with holes. So I got some "pipes" and nuts and bolts. Then we went shooting and made some "pipes" ourselves from round targets. Maybe I'll plumb the house with a stack of those round things that we used to call donuts. Yep, round with holes in them, same as water pipes 'fur as I can tell.
Your posts in this thread already indicate a fairly thorough ignorance of the subject without any need for extra effort.
Sorry, but I could not have worked in the industry as long as I have without figuring out how to navigate the common names of things. Or the accurate names of non-standard things I'm looking for. I bet the next time I ask what time it is, someone will impatiently explain how a clock works. Or accuse me of asking a Lowes employee what time it is. Ouch!
