How to increase reach on a bearing puller
OccupantRJ
Eastern North Carolina
I needed to pull this bearing off a motor shaft, but the bearing was so close to the fan that I could not get any puller I had to get underneath the bearing. The only puller I had out of several that had thin pull hooks would not assemble without leaning outward too much to get underneath the bearing. After studying this quandry a bit, I came up with this solution. I used the pull hooks and side links off one puller, and pulled that one with another one. I left the side plates slack so that they would be able to surround the shaft. With this rig, I was able to pull the bearing up enough to switch to the standard puller to finish the job. Sometimes you gotta get creative!
O
OccupantRJ
I wore a face shield when doing the job, but that 6203 bearing did not take a great amount of force to remove. It was just difficult to get hold of.
metaleltr
Western Ohio
That's very creative!
The background has intrigued me, whats up with the tool storage in the background? I would love to see more pictures of the tools stored on the wall.
diesel research
gulf coast, TEXAS
So what about a bearing splitter and the typical bar-type push/pull puller? That would allow you to use threaded rod of whatever length.
I understand the task is already accomplished, but I mean for "next time" :D
O
OccupantRJ
Click on my screen name, then statistics, then all threads started by me. You will find various threads on my tool hanger designs, among other things.
