How to set up a mobile platform for vise?
qqzj
Sadly my garage is too full to make room for a workbench. But I do want to set up a vise in the backyard from time to time. I am wondering whether someone with more experience can figure out a solution to make it possible? It is mostly for auto application, like using slide hammers, or using bearing press. Thanks!
Sent from my Pixel 3 XL using The Garage Journal mobile app
AngryBeaver
Lake Milton Ohio
Vises are not presses.
any mobile stand is not going to be effective for that kind of vise work.
I don't care how small your garage is, you have room for a bench
rsanter
visalia ca
Basic steel plate at the bottom with a column welded to it.
Sink anchors into the driveway, garage floor or patio to bolt it down when you really needs to crank on something
astroracer
Mid_Michigan
Set a 6 x 6 PT post in the ground and add a receiver hitch mount to it. That way you can haul the vise or any other tool that needs to be hard mounted out there and just plug it in. Bring it back into the shop when done.
I just built a receiver mount for my bead roller that will attach to my jig tables or the big tool post that floats around in my shop.
Here is my build thread for the bead roller. The receiver build is outlined in post #6:
https://www.garagejournal.com/forum/showthread.php?t=470362
BD1
north side
I have a couple of vises mounted on large rims for a base. They can be moved with a two wheel hand truck. My largest is on wheels and easily movable. It's setup for my outside work mostly on gravel. I can add a couple of 100 pound front tractor weights if needed.
American Locomotive
Rhode Island
I second the post welded/bolted to an old car rim. I've seen that a few times, and it works well.
The hitch mount isn't a bad idea either. Bit more portability that way (but might be a bit wobbly in the receiver)
Vises can be used for whatever one wants to use them for.
WhoWhatNow
Collegeville, PA
A post welded to a steel plate large enough to allow you to stand on it. This setup uses your weight to keep the vise from moving when in use so it can be light enough to move around easily.
gnpenning
I have more questions than answers.
Along with the other suggestions a square receiver hitch cemented in the ground vertical. You can add several in the area for other tools. Make sure the hole can drain.
As a side question, where do you store the vice when it's not in use?
speed bump
Butte Montana
My mobile vise is on a stand on an old medium duty truck wheel.
It isn't perfect for getting crazy but it does the job most of the time.
