anndel
Previous Owner was my Mom! Good at chocolate chip cookies and making teddy bears, not so much at wheel bearings.
Mmmmmm, chocolate chip cookies, major yum!
I'll admit I'm not familiar with the vehicle in question, but here's a thought:
If you removed the rotor and dust shield, would that allow better access from the back to get penetrating oil, even heat, etc?
Sometimes it takes time for that penetrating oil to do it's job. I'm just thinking I'd rather do the job with the steering knuckle on the car instead of on the bench, but again, I'm not there, haven't done one, etc.
On some vehicles one side has normal right hand threads on the lug nuts,but the other side is left hand threads......
Impact wrenches should be banned! Or you should have to take a test to buy one, or maybe they should only work in the Loosen direction, not the tighten direction!
I spent a few hours battling the wheel hub bearing bolts on my Jeep Grand Cherokee, the right sides came off with a minimum of swearing, Kroil, and a blowtorch, the left side still hasn't come off so I will probably need to grind them out. Some dummy installed them with an impact wrench.... I will probably have to replace the whole steering knuckle just because some gorilla overtightened the darn things!
This is why I have to work on my own vehicles, can't trust mechanics (especially chassis mechanics) to not mangle parts.
If the last tech used an impact to install it,..... It seems he had access you do not.
FYI, using extensions on impacts reduces their power to the point of them being worthless.
This is the difference between a "tech" and a mechanic. A tech will fitz around trying for hours to get a proper tool on a fastener. A mechanic will try 3 or 4 different approaches and then pull the damn hub off the vehicle. With the proper tools you would have that part on the bench in 45 minutes and that is taking your sweet *** time.
You can't break it loose on the vehicle? then remove the whole damn assembly. Getting in and using an Oxyacetylene torch is the true sign of a cobby hack that could not give a **** they are destroying parts all around the area they are working.
I would not let you work on my wheelbarrow
The compact one is new even, I bought it specifically for this job. It is supposed to have 700 foot pounds of breakaway torque.
If an impact gun will not remove it, a cheater will just twist off the head.
Doesn’t Jeep use torx bolts on their unit bearings, to be removed with an e torx socket? Some posters have referenced 12 point, or triple square. I haven’t seen that on Jeep’s. Just curious.
https://www.amazon.com/dp/B01CIOC66Q/?tag=atomicindus08-20
Yeah, look like 12 point to me. I know I have removed and replaced these hubs before.
This whole thread makes me laugh. Thanks everyone![]()
Don't laugh, this thread is serious. No hand over your impact until you get your licence. The OP has certificates and stuff.
exactly what i was thinkingOr, you could just buy a good impact wrench.
Correctly used there is nothing wrong with an impact wrench.
Make sure the nuts/screws are undamaged, get the correct torque stick and socket and tighten up.
The torque stick gives very consistent results. Used them for years in the assembly of EHV GIS switchgear. Post assembly 10 % quality check of the fasteners ( many thousands, all critical) always came out right.
Ola
This is hilarious there is 4 pages of this guy getting roasted.
How tight can someone really tighten a lug nut without snapping the stud? We snapped a lug nut when I first got my Snap-On ct3850 and that puts out maybe 240 ft lbs.
Just wait until he goes to separate the hub from the knuckle.
Ban impacts?![]()
Obviously what is being overlooked here is:
"Righty tighty, lefty loosey".
NO! Actually what is being overlooked here is: most people who post on here do not know the difference between "lug nuts" and a "wheel hub bearing bolts"
